erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Mon Sep 27, 2021 8:03 pm Post subject: Re: 1Z TDI Westy - Build Thread |
I had that dead pedal issue until I hooked up the cruise wiring. AHU TDI
Neil makes a great point about cruise being an option. I wonder how the automatics are wired? It's been a while, but I think it's the brake light circuit that's the main issue. Mine is currently working, but the brake sensor doesn't shut it off, just the clutch and the stalk. This was a roadtrip repair and I'm pretty sure I just grounded the brake switch.
Good luck with the transmission work! I don't think there are any US suppliers for the input shaft. Maybe Chris at T3 had them at some point, or maybe one of the rebuilders has one on the shelf. Shipping from Brickwerks has been really fast for me though. Same as any of the other stateside vendors.
.75 4th with the 4.57 seems good. I have the .85(?) stock vanagon 4th and (straight cut from gears) and the 4.14. I was worried it would be revving too high on the freeway, but it's fine. Maybe I said that already. Similar ratio. I think you'll be happy with that gearing. |
valvecovergasket Samba Member
Posted: Mon Sep 27, 2021 8:40 pm Post subject: Re: 1Z TDI Westy - Build Thread |
Vanagon Nut wrote: |
would grounding various switches or sensors to that ECU 33 wire some how mess up that ground path as it was originally intended to be used? Is that a reference ground to the sensor inputs as seen by ECU ? IOW, the sensors themselves have their own ground wire likely to engine block?
everything is actually meant to come back to that ground, then the ecu has a main out to the block/battery.
but all the inputs ground to that brown/blue reference line, sensors, those switches, etc
heres a snip from the 1Z wiring, thats the sensor return highlighted
erste wrote: |
Neil makes a great point about cruise being an option. I wonder how the automatics are wired? It's been a while, but I think it's the brake light circuit that's the main issue. Mine is currently working, but the brake sensor doesn't shut it off, just the clutch and the stalk. This was a roadtrip repair and I'm pretty sure I just grounded the brake switch. |
yeah that makes sense - the 1z/ahu have the brake light, then the brake and clutch switches. i assume all cars non CC or otherwise have the light input, with the others using CC? i probably wont bother testing each individually but will run the group to the ground.
the later alh and beyond setups seem to have a more clever NO/NC combo on the brake pedal rather than the lights but this early stuff looks quite simple.
i was just surprised that malone either forgot or wasnt able to clear out that fuel cut reaction.
i didnt see a reference to the auto only install for those switches in the wiring diagrams i have, but i assume in the NA market it was just dropping the clutch switch - this ecu came out of a manual car in any case.
erste wrote: |
thanks!
looks like brickwerks will be the ticket, we had great luck with them on some of the random install parts for this motor but with shipping these days i figured id check...
looks like 0.85 and 4.14 is ~2800 at 62, like you said not far off from my 0.75 and 4.57, so thats great to hear! _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
erste Samba Member
Posted: Mon Sep 27, 2021 8:59 pm Post subject: Re: 1Z TDI Westy - Build Thread |
valvecovergasket wrote: |
i assume all cars non CC or otherwise have the light input, with the others using CC? |
I'm wondering about all of the military and industrial variations of this engine and what's happening there. Engines meant as generators that have no brake light input. It's an interesting topic, but yeah - just take them all to ground and that should fix the dead pedal. Or wire up cruise like anyone who's not a masochist and enjoy the loooong road trips |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Mon Sep 27, 2021 9:01 pm Post subject: Re: 1Z TDI Westy - Build Thread |
It was 2013 that I reworked my wiring harness for my 1Z, but I am 99% sure this is correct...
The ECU looks for the clutch pedal switch to make a connection to ground when it is NOT depressed, and for the brake pedal to make a connection to ground when it IS depressed (brake lights on). OR, with both pedals at rest, the ECU sees a ground from the clutch and no ground from the brake. If I recall correctly, this represents a change from the older cruise control systems, where the power for the system ran through both the clutch and brake switches, so tapping either cut power to the cruise ECU and turned it off briefly and until set or resume was pushed again.
In my Bus, I used a relay for the brake pedal input. Brake light energizes the circuit, and completes the connection of 87a to 30. In this case, 30 goes to ground and 87a goes to the ECU.
Eventually the switch I used for the clutch pedal got flaky, so I just wired that wire to ground... Not the "safest" but it works ok. I just remember to tap the brakes before hitting the clutch if cruise is set. It's pretty rare that I wouldn't do that anyway. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Mon Sep 27, 2021 9:14 pm Post subject: Re: 1Z TDI Westy - Build Thread |
I just went out and pulled the relay and verified that I had connected 30 to ground, and the other wire goes to 87a.
So if you just simply connect both the wire for the clutch switch and the brake switch to ground, the engine will think the clutch pedal is at rest and the brake pedal is depressed. That may not cause any running issues, but it wouldn't quite be correct either.
Also, you can use VCDS to enable/disable cruise control. So I bet if you simply disabled cruse control, it wouldn't matter what happened to the two wires. That's also probably what is done with the industrial engines and the like.
But as I said earlier, you're this far in. Just get the cruise control working! Worth it! _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Mon Sep 27, 2021 9:21 pm Post subject: Re: 1Z TDI Westy - Build Thread |
Good deal, appreciate the info!
vwwestyman wrote: |
But as I said earlier, you're this far in. Just get the cruise control working! Worth it! |
Haha maybe later! I don't have a speed input anyway, but I'll leave my breakout connector for whenever I do end up crossing that bridge _________________ MegaSquirt resource - SpitfireEFI.com
Vanagon Nut Samba Member
Posted: Mon Sep 27, 2021 9:26 pm Post subject: Re: 1Z TDI Westy - Build Thread |
Ah yes. I recall that 220 ground. My thinking was sort of reversed on this.
I recall sweating details over various ground junctions and what not while home brewing new shielded RPM and knock sensor cables. But yeah, they all terminate to ground. Neeeever mind.
1988 West DIY 50º ABA
VE7TBN |
Posted: Fri Oct 08, 2021 2:24 pm Post subject: Re: 1Z TDI Westy - Build Thread |
still working with malone on a reduced fuel tune.
testing out the first update still, seems like EGTs are a bit lower but havent spent enough time driving during the day to really judge the smoke - its still smoky, less so, but how much less than the previous is tough to say yet.
grounding all the clutch/brake stuff fixed the hiccup on launch, so thats all sorted!
and i got my first UOA back from blackstone. seems so far so good.
though its going to take me years at this rate to accumulate enough miles for the next oil change
Quote: |
This rebuilt motor looks how we'd expect in testing at this stage. Iron, copper, and silicon are the
classic hallmarks of an engine going through wear-in, and we expect all of them to decline as oil changes
take place. The metals are elevated from the parts carving out working clearances, and the silicon is from
the new seals, gaskets, assembly lubricants, etc. Over the next few oil changes we'll look for the wear
profile to start looking more like averages, which are based on mature VWs of this type after ~8,300 miles
of oil use. You can try 4K mi before checking back.
Zeitgeist 13 Samba Member
Posted: Thu Dec 23, 2021 1:00 pm Post subject: Re: 1Z TDI Westy - Build Thread |
and finally the dash build.
i used the cracked and kind of messed up cluster frame that the van came with as practice on how to clearance appropriately for the speedhut gauges to be mounted on new frames up near the front.
kourt had a really slick install with them recessed into the original mounting near the rear of the frame but i wanted to use the spin rings and bezels they came with so thought id try this.
using some scrap abs i had it took a few tries to get the right fit with all the curves going on here but im happy with how they came out. jb weld plastic epoxy holds it all together and feels pretty darn sturdy. the frame didnt seem to lose any rigidity with the clearancing needed to accommodate the spin rings.
finally the new center stack LEDs with the smallcar logo panel that has a glowplug and MIL on the bottom row.
so far in the bit of driving its seen, no issues with the speedhut fuel level, including some intentional swerving to induce slosh... but ill update after its been on the road a bit. even in that situation id hardly call it so noisy its unreadable, as others have posted.
Hey, I'd like to follow your lead and install these exact gauges in a Syncro cluster. Do you have an estimate for how long this mod took you? Does anyone know if the Speedhut tach will work with the W-signal off the alternator?
Also, how were you able to order a custom 80mph and 6k rpm speedo? That doesn't seem to be an option on their site.
Also also, which sending units did you use? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Thu Dec 23, 2021 6:56 pm Post subject: Re: 1Z TDI Westy - Build Thread |
For the work time modding the cluster, maybe 3 hr? Was just a lot of mocking up and test fitting the little panels otherwise it's not too bad of a job. Little tiny belt sander was helpful to fit the sides of the panels and get them nice and flat
That speedo and 4 way gauge were straight off their site, off the shelf combo for tach and mph combo at the time. They're "custom" but really only for font/color/graphics, but if they don't list it I bet they could make it for you...
I remember asking about the W terminal... And as I recall that tach only works off of a digital signal, they have a specific tach (or had, at that time) that was for W diesel input but it wasn't possible to get that version with the speedo combo 2 gauge setup.
Sending units all come with the gauges, the speedo/tach really only has the gps puck - thats magnetic, and I hid under the dash mat - otherwise no other senders. The four way only has a couple since I'm reusing the stock van fuel level and the volt meter comes off the harness. The only pain was adapting the rest at the motor end since they're SAE thread but that's not rocket science. _________________ MegaSquirt resource - SpitfireEFI.com
Posted: Thu Dec 23, 2021 7:32 pm Post subject: Re: 1Z TDI Westy - Build Thread |
Thanks, that feedback really helps. This phase of the project just blew up this morning, and I need a fairly quick turnaround. I see that Northwesty has an adapter for a 1/8" NPT to VW coolant sender insert for the temp gauge.
https://www.north-westy.com/parts/volkswagen-audi-coolant-temp-sensor-adapter-m10x1-1-8npt/
I'll follow up with an email to Speedhut.
Thanks again,
Casey _________________ Casey--
y u rune klassik? |
Posted: Thu Dec 23, 2021 7:36 pm Post subject: Re: 1Z TDI Westy - Build Thread |
Their gauges were 2-3 months out when I ordered pre covid craziness, so heads up on that end.
I don't think they stock anything until it's ordered given the infinite color/font/style combos _________________ MegaSquirt resource - SpitfireEFI.com
Posted: Thu Dec 23, 2021 8:20 pm Post subject: Re: 1Z TDI Westy - Build Thread |
Their site claims two to three weeks out, but we all know that's a dicey proposition right now. I sent them an email. As a backup, I'm contemplating a 3 3/8" speedo on the left and the same size quad gauge on the right, with a 2 1/16" tach and clock stacked in the middle. _________________ Casey--
y u rune klassik? |
Posted: Thu Dec 23, 2021 8:39 pm Post subject: Re: 1Z TDI Westy - Build Thread |
Edit - went back and looked through my order history and it was about a month,.3 weeks ish, from order to delivery
If they fit your application they're definitely worth waiting for! I'm really happy with ours _________________ MegaSquirt resource - SpitfireEFI.com
Posted: Fri Dec 24, 2021 12:19 pm Post subject: Re: 1Z TDI Westy - Build Thread |
Sorry to keep pestering you, but this is such a cool project. Do you have a good source for a 14 pin Molex/Deutsch type plug, or did you make do with a more common 12 pin? _________________ Casey--
y u rune klassik? |
Posted: Fri Dec 24, 2021 12:37 pm Post subject: Re: 1Z TDI Westy - Build Thread |
I use Delphi gt series connectors for most things including everything on this van and they've got a 10,12,14, etc larger capacity versions
You can get em at mouser and digikey, I can get you p/ns for the pins and connectors but probably not until Monday or so when I'm not on my phone..
They're Delphi Gt 280 series If you're googling though... _________________ MegaSquirt resource - SpitfireEFI.com
Posted: Mon Jan 17, 2022 9:52 am Post subject: Re: 1Z TDI Westy - Build Thread |
trying to keep this updated as i find things that would be worth doing differently if i were to do it again - the topic of turbo oil drains
ill preface this by saying i didnt drive the van much last winter so most of the miles have been during warmer weather.
originally i started the motor and put the early miles on with 15-40 but that seemed a bit thick given the drain arrangement.
im running 5-40 in it now, which combined with a little porting of the drain flange seemed to help any oil backup/smoke i was seeing in warmer weather, so no real complains when warm with the current arrangement.
but with some more miles on it in colder weather this year it seems things arent flowing quite as well as they need to, most noticeable at cold idle for obvious reasons!
i think ive seen waldo mention (maybe not in this thread?) that 3/4" oughta do the trick.
plan is to upsize from the current -8 drain arrangement, and i hope to have the parts here within the next few weeks assuming no shipping calamities
will take lots of pictures and report back, luckily its all easy to access and assembly should be pretty trivial. _________________ MegaSquirt resource - SpitfireEFI.com
DuncanS Samba Member
?Waldo? Samba Member
Posted: Mon Jan 17, 2022 10:18 am Post subject: Re: 1Z TDI Westy - Build Thread |
I had to look back through your thread a bit to find where you show the oil return line. You've got several things going on that I would do differently.
I prefer using the Jetta/Golf manifold and turbo placement rather than the Vanagon/Quantum placement. You get more vertical drop for the turbo drain. The Vanagon turbo position can obviously work but is worse IMO. In your situation, I don't know that I would make that change considering the amount of reworking of intake, exhaust and oil lines required.
Your center cartridge is not 'clocked'. That places the offset from vertical at ~35°. Garrett specifies a max of 15° from vertical for proper drainage. VW did not clock the center section of the stock Vanagon turbo either, so again, it can work, it is just not ideal. To clock the center section, you would need to adjust the oil supply and return. Darkside offers custom oil supply lines with banjo fittings which can make that easy. I would make that change.
I don't like the aluminum fittings that you (and most people) used for the oil return. As I said earlier in the thread, they are weak, prone to leaking and other failure, and they are typically quite small ID. I prefer using steel or brass barb fittings and getting oil return line that is rated for hot oil. Summit has oil return hose that has the braided stainless outer sheath for strength. I typically use AN10 braided stainless Aeroquip hose from Summit with 5/8 barb and clamp well. Tape around the end of the cut hose reduces the number of needle pokes and curses. The end result is actually stronger, more reliable, and larger ID than the AN fittings.
