greggearhead Samba Member
Joined: June 20, 2004 Posts: 535 Location: Colorado Springs, CO
Posted: Fri Dec 06, 2019 11:03 am Post subject: Dual Weber IDFs fit on a 412 Fastback? |
I may have fried my aftermarket injection, so wondering if I can slap a pair of Weber IDF carbs on the 2.1L in my 412 fastback, or if there isn't enough room?
I searched - and I'll try to take a manifold and carb home tonight to visualize it on the engine but wondering if anyone knows for sure. _________________ 1972 Porsche 911E
1973 Porsche 911T
1973 VW 412
1982 VW Caddy
1991 Vanagon
2002 Eurovan (Manual Swap)
Period Lights, VW & Porsche wheels and Recaro/Scheel Seats for sale
https://www.facebook.com/greggearhead
http://greggearhead.com/soco-swap---september-vw-swap-meet.html |
Joined: August 31, 2013 Posts: 10583 Location: North Carolina
Posted: Fri Dec 06, 2019 12:22 pm Post subject: Re: Dual Weber IDFs fit on a 412 Fastback? |
I don't know about a kit for the Type IV but the Type IIIs usually used dual ICTs or dual two barrel DCNFs. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
GOFUNDYOURSELF, quit asking everyone to do it for you! |
Posted: Fri Dec 06, 2019 3:00 pm Post subject: Re: Dual Weber IDFs fit on a 412 Fastback? |
TDCTDI wrote: |
I don't know about a kit for the Type IV but the Type IIIs usually used dual ICTs or dual two barrel DCNFs. |
OK, I didn't ask about ICTs or DCNFs. I appreciate your input but unless you can answer the question asked, please be quiet. _________________ 1972 Porsche 911E
1973 Porsche 911T
1973 VW 412
1982 VW Caddy
1991 Vanagon
Posted: Fri Dec 06, 2019 3:40 pm Post subject: Re: Dual Weber IDFs fit on a 412 Fastback? |
There is not enough room for the IDAs or IDFs in the Type IV bay, unless you ran it without the engine cover. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
TDCTDI wrote: |
There is not enough room for the IDAs or IDFs in the TypeVI bay, unless you ran it without the engine cover. |
Its a fastback, not a wagon. _________________ 1972 Porsche 911E
1973 Porsche 911T
1973 VW 412
1982 VW Caddy
1991 Vanagon
Posted: Fri Dec 06, 2019 3:45 pm Post subject: Re: Dual Weber IDFs fit on a 412 Fastback? |
The Fastbacks still had the same engine cover as the wagons, so the rear trunk was useable, that's why I said "unless you ran it without the engine cover" not "Unless you ran it without the rear trunk lid." _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Dec 06, 2019 4:02 pm Post subject: Re: Dual Weber IDFs fit on a 412 Fastback? |
My fault, I was thinking that they would be the same as the TypeIII Squareback vs the TypeIII fastback. Looking at the pics, there's more than enough room for the IDFs in there. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Tvättbjörn Samba Member
Posted: Sat Feb 22, 2020 11:23 pm Post subject: Re: Dual Weber IDFs fit on a 412 Fastback? |
greggearhead wrote: |
I searched - and I'll try to take a manifold and carb home tonight to visualize it on the engine but wondering if anyone knows for sure. |
Old post, but maybe there is still an answer needed?!
It will most likely not work with tall american manifolds. However, you can buy real short manifolds in Germany and they should work with a low profile air filter. They also come in 40 / 44 / 48 mm diameter to match the carbs. They are being made since the late 80's . CSP has some listed, but I am not sure if they are the really short ones. I have a set of the short manifolds and can measure them ( if I find them ) if you like. |
Posted: Sun Feb 23, 2020 7:34 am Post subject: Re: Dual Weber IDFs fit on a 412 Fastback? |
Thank you - yes! I haven't mounted my manifolds and throttle bodies yet, but really would like to. Just need to find the time. If they are too tall, I can get or make short ones I guess. _________________ 1972 Porsche 911E
1973 Porsche 911T
1973 VW 412
1982 VW Caddy
1991 Vanagon
