VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sat Dec 07, 2019 2:51 pm Post subject: Exposed wires at wiper motor |
Anyone run into this? And if so, how hard to replace the wires that (I assume) run to the brushes?
Me and the eldest child were driving to the coffee shop in Seal Beach this morning. It started to sprinkle and I turned on the wipers. They worked for three minutes, then stopped. Blew the 15 circuit fuse which feeds several accessories!
We ended up having coffee. Then we drove back home and I went to work. Found the two wires coming out of the motor cover exposed. They were not like that several months ago, THAT I noticed. But sometimes I have tunnel vision.
Anyways, anybody changed these wires out, or is there a rebuilder out there. I am just being lazy. I will most likely remove and rewire the motor, but was interested in knowing if someone else successfully accomplished this task?
_________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
vamram Samba Member
Posted: Sat Dec 07, 2019 2:58 pm Post subject: Re: Exposed wires at wiper motor |
Jimbo - there's a seller on thesamba called "wiper guy". He rebuilds wiper motors and assemblies like Tim does carbs. In other words, you get basically a new wiper motor ready to go, no issues. I bought one from him for my '74 2+ years ago, worth every penny.
Víctor _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Dec 07, 2019 3:34 pm Post subject: Re: Exposed wires at wiper motor |
That's some rough looking soldering, this pic from the gallery shows how it should look:
I wonder if you could get away with detaching each wire and sliding some heat shrink or vinyl tubing down it? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Dec 07, 2019 4:37 pm Post subject: Re: Exposed wires at wiper motor |
vamram wrote: |
Víctor |
Thank you Victor. I figured there was someone rebuilding these units. But, I am going to try repairing it myself before I go that route. I just never have went any further than removing and replacing, so was curious what the overall opinion of the community was.
I actually did a search on the subject but found no useful information regarding the exact variables.
I will continue to keep this all updated as I work through it. Maybe I will do a wiper motor refresh thread, with new brush wires installed! _________________ Jimbo
TDCTDI wrote: |
Posted: Sat Dec 07, 2019 4:45 pm Post subject: Re: Exposed wires at wiper motor |
busdaddy wrote: |
I wonder if you could get away with detaching each wire and sliding some heat shrink or vinyl tubing down it? |
That’s what I was thinking. It looked as if a previous PO had soldered the wires. But I could not remember exactly. Been too long since I had to actually look at the wiper motor itself! Funny how things you stop doing, get fuzzy.
The heat shrink idea sounds good. I am just fearful that those wires may have a similar issue at the interior of the motor, so was really wondering if anyone knew for sure before I go removing the motor. That’s a load of work that I do not want to do twice.
Thanks for the idea! _________________ Jimbo
TDCTDI wrote: |
vamram Samba Member
Posted: Sat Dec 07, 2019 6:45 pm Post subject: Re: Exposed wires at wiper motor |
In case the repair doesn't go as planned...
https://www.thesamba.com/vw/classifieds/detail.php?id=1086158
Click to view image
Save the Supers!! |
Posted: Sat Dec 07, 2019 7:09 pm Post subject: Re: Exposed wires at wiper motor |
Thank you Victor! _________________ Jimbo
TDCTDI wrote: |
bomberbob Samba Member
Posted: Sun Dec 08, 2019 7:30 am Post subject: Re: Exposed wires at wiper motor |
If you don't want to disturb the wires but want to cover the bare copper, liquid tape may be an option. Its like liquid electricians tape. _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
johneliot Samba Member
Joined: August 29, 2005 Posts: 2189 Location: Chico, CA
Posted: Sun Dec 08, 2019 8:30 am Post subject: Re: Exposed wires at wiper motor |
I agree. If you're worried about water shorting those wires, I'd use liquid tape too. They make it in brushable and spray. _________________ John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost" |
vamram Samba Member
Posted: Sun Dec 08, 2019 9:32 am Post subject: Re: Exposed wires at wiper motor |
johneliot wrote: |
I agree. If you're worried about water shorting those wires, I'd use liquid tape too. They make it in brushable and spray. |
Just my 2C's - here. I had used liquid tape on the crimps of my horn wires a couple of years back and found in recently trouble shooting recurring horn problems, that the liquid tape had run thru the wire before curing, in such a way as to individually insulate each strand of the horn's hot wire, for close to 1/2" back from the crimp. YMMV but I'd go w/out liquid tape for the repair. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Sun Dec 08, 2019 9:37 am Post subject: Re: Exposed wires at wiper motor |
That's interesting. I've used it quite a bit and I've never run into that problem. _________________ John
Mark Twain
bluebus86 Banned
Posted: Sun Dec 08, 2019 10:26 am Post subject: Re: Exposed wires at wiper motor |
busdaddy wrote: |
of course the over heat could have caused the solder to melt. maybe?
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sun Dec 08, 2019 10:36 am Post subject: Re: Exposed wires at wiper motor |
bluebus86 wrote: |
busdaddy wrote: |
Bug On! |
Thank you! I was so wrapped up in fixing the wires, I did not add up the two visible byproducts of what took place!
Motor is coming out. I will rewire it and internally rebuild it! Thank you!
This is why I posted it up. It was a situation I have never seen before. We get rain, maybe four times a year! Not very common to work or to overhaul this system or its components.
Again, thank you for those 12 words! _________________ Jimbo
TDCTDI wrote: |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1382 Location: Wichita, KS
Posted: Sun Dec 08, 2019 12:59 pm Post subject: Re: Exposed wires at wiper motor |
Yeah, definitely looks like it shorted somewhere — one or both of those two wires are normally hot w/ the ignition on, I think.
I tore apart, cleaned, and relubed both the gearbox and motor on mine a while back. It’s a bit finicky on couple points (especially w/ the 3 brushes for the motor, when reassembling everything), but certainly doable if you take your time & work carefully. Mine runs much faster and stronger now.
Also, make sure to check the base of the main drive gear (for the wiper arms — it’s some sort of white nylon, or similar polymer I think) closely for cracks before reusing —they’re supposedly prone to that sort of thing there. _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Sun Dec 08, 2019 1:02 pm Post subject: Re: Exposed wires at wiper motor |
johneliot wrote: |
If you're worried about water shorting those wires, you should probably fix whatever water entry issue you have. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Sun Dec 08, 2019 5:12 pm Post subject: Re: Exposed wires at wiper motor |
Agree. _________________ John
Mark Twain
