vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Sun Dec 08, 2019 6:10 pm Post subject: How much lift |
Whats the max runnable cam lift you'd run with a 40mm valve and an 87mm cylinder, 69mm stroke, normal aspirated.
specifically with panchito ports, out of the box
street engine
.500", .550", .600"??
Is there a lift where CFM becomes irrelevant to the cyl /stroke size? |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Sun Dec 08, 2019 6:22 pm Post subject: Re: How much lift |
14 is a good general rule, where the flow gains begin to taper off based on the valve size. So for a 40mm valve, about .560" is where there are still gains to be made, but they become less and less, AND reliability continues to decrease (40x14=560). CNC'd Panchitos are about done at .600", but unmachined Panchitos are around .550".
A 87mm bore is small. Unless you're aiming for some high HP number at a very high rpm, I'd keep it at or below .500". _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Sun Dec 08, 2019 6:28 pm Post subject: Re: How much lift |
vwinnovator wrote: |
street engine
.500” imo is the best choice. Higher lifts will have a Deminishing return on power and will reduce train life.
Dan |
Posted: Mon Dec 09, 2019 6:11 am Post subject: Re: How much lift |
Thanks guys,
I was thinking .500"ish would be about it as well. |
Posted: Mon Dec 09, 2019 9:25 am Post subject: Re: How much lift |
Your engine will be down on low end torque unless you add a bigger bore or run smaller heads like the Tims super stocks. What cam and rockers are you thinking about?
Dan |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Mon Dec 09, 2019 9:53 am Post subject: Re: How much lift |
street engine
What duration are you running? I am running a web 218 with 1.25's with my 050 Rassers in my car so that's a .516 lift, which works VERY well. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
