Dan2973 Samba Member
Posted: Mon Dec 09, 2019 5:19 pm Post subject: Wet sanding single stage paint |
Hey guys I’m restoring a 1966 beetle. I did new heater channels and other replacement panels as well. The body is on a dolly and is also in primer. I am planning on painting it Fontana grey single stage ppg. My question is how many coats will I need to put on so I make certain not to burn through the paint when wet sanding orange peel. Thanks 🙏 |
jspbtown Samba Member
Posted: Mon Dec 09, 2019 9:12 pm Post subject: Re: Wet sanding single stage paint |
Well this might sound a wee bit sarcastic but its not.....it all depends on how bad the orange peel is.
So...normally I like to do a light coat and then two medium wet coats of single stage. If you have a lot of peel you might want to go for another medium wet coat |
Posted: Tue Dec 10, 2019 11:33 am Post subject: Re: Wet sanding single stage paint |
jspbtown wrote: |
. Gotcha. Thanks. I was told that single stage paint overspray get everywhere. More so than two stage is this true? I had planned on painting this in my garage and just putting plastic around the walls |
Posted: Tue Dec 10, 2019 1:13 pm Post subject: Re: Wet sanding single stage paint |
I think the basically all produce the same amount of over spray.
I have painted many cars in my garage. I drop blue tarps from the ceiling and I make sure the floor is wet down to reduce dust. Make sure you have good airflow and a respirator.
Some plastic sheeting is fine to control over spray |
