wccdavehamby Samba Member
Joined: October 24, 2016 Posts: 2 Location: Washougal, WA
Posted: Tue Dec 10, 2019 9:54 am Post subject: Custom Pre-Heater hoses? |
So, after 3 decades of dealing with crappy foil hoses and spending a fortune on single use only products, I am at my wits end. Has anyone come up with a full proof option for the pre-heat hoses from the fan shroud to the heater boxes? I am looking for something that can be used over and over without having to treat it like a delicate flower and something that is one piece. Let the responses commence.
thank you, |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Dec 10, 2019 10:18 am Post subject: Re: Custom Pre-Heater hoses? |
Get original style German hose like this
https://www.mtmfg.com/part/view/oem-german-heater-...129-087AGR _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Xevin Samba Member
Posted: Tue Dec 10, 2019 10:41 am Post subject: Re: Custom Pre-Heater hoses? |
I hate those aluminum hoses. They dent easy and collect dirt. I agree with the German hoses above. That’s what I run. However the plastic ones in this link are nice. I think they look pretty good too. Durable and easy to clean.
https://www.mtmfg.com/part/view/fresh-air-hose-to-...gL5BPD_BwE _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31274 Location: Hot Arizona
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11739 Location: Redding, CA
Posted: Tue Dec 10, 2019 11:19 am Post subject: Re: Custom Pre-Heater hoses? |
I bought new black paper-reinforced aluminum fresh air hose about five or six years ago. After removing the engine four or five times since, the hoses still look great and continue to hold their shape.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
AlmostHeavenWV_VW Samba Member
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Tue Dec 10, 2019 12:48 pm Post subject: Re: Custom Pre-Heater hoses? |
I'm not entirely sure what you are asking. I think what you're talking about is a solution for the hoses beneath the tin.
I don't have a one-piece solution, or one that contributes to the overall heating, but at least I don't have to change hoses very often.
Pls forgive the dust, my projects take a long time.
I think CSP has some sort of one-piece solution:
https://www.csp-shop.com/en/exhaust-heating/heater-hose-fitting-csp-255-165-csp-27591h.html
Hope that was of some help... |
Posted: Tue Dec 10, 2019 1:00 pm Post subject: Re: Custom Pre-Heater hoses? |
I am amazed that someone hasn’t come out with an industrial strength solution (1 piece) that has that tight bend around the header, up through the tins and into the fan shroud. The German ones are the best, but still have issues when bending around headers. Maybe time to fab up a solid part that attaches to the heater box and punches through the tins. |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2379 Location: Seekonk,Massachusetts USA
keg184 Samba Member
Joined: July 03, 2016 Posts: 83 Location: Mountville, PA
Posted: Tue Dec 10, 2019 5:36 pm Post subject: Re: Custom Pre-Heater hoses? |
I used a radiator hose down to the tin. I to got tired of denting the flimsy aluminum ducting.
VW_Buggsy Samba Member
Posted: Tue Dec 10, 2019 7:50 pm Post subject: Re: Custom Pre-Heater hoses? |
I've used 2" flexible steel exhaust tubing before. It's stiff and a little hard to make sharp bends but very durable and doesn't crush. Not too spendy either.
https://www.jegs.com/i/Dynomax/289/46973/10002/-1
You can also find it in local flaps sometimes.
It's galvanised so it doesn't rust, but not sure if it gets hot enough to release any harmful zinc from the galvanised metal. Probably fine from the shroud to the apron tin. |
Posted: Wed Dec 11, 2019 3:28 pm Post subject: Re: Custom Pre-Heater hoses? |
Those would eventually saw through by rubbing on the tin. |
Posted: Wed Dec 11, 2019 3:32 pm Post subject: Re: Custom Pre-Heater hoses? |
wccdavehamby wrote: |
Berg had something like that, on type 3 exhausts. I share your frustration, and it would be a bonus to build it to go around the exhaust, to pick up some heat, like stock. Keep us posted. |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1596 Location: The South Zone
Posted: Wed Dec 11, 2019 10:09 pm Post subject: Re: Custom Pre-Heater hoses? |
FreeBug wrote: |
That's funny, I did this very thing just last summer. I did a write-up on a couple weeks ago. Here ya' go:
https://www.thesamba.com/vw/forum/viewtopic.php?t=728036&highlight=
It wasn't exactly one piece, but I don't mind. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5593 Location: 37.5N 77.1W
Posted: Fri Dec 13, 2019 8:05 am Post subject: Re: Custom Pre-Heater hoses? |
This tread reminded me of my first Bug, '63. The PO had used an oxygen hose off of a fighter pilot's mask for the pre-heater hose. Very flexible and tough. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
RA 70 Samba Member
Joined: May 16, 2009 Posts: 1092 Location: Sacramento
Posted: Fri Dec 13, 2019 8:32 am Post subject: Re: Custom Pre-Heater hoses? |
Floating VW wrote: |
FreeBug wrote: |
It wasn't exactly one piece, but I don't mind. |
Yeah, I read your thread, I figure with an afternoon or two, I can reproduce what you have done. Easy....
There's something that occurred to me: the question is it's own answer: "custom" implies bespoke, one-off. So the title acknowledges that there are no industrial one-piece solutions...
but there should be. |
