case ID
desert westy
desert westy is offline
PostPosted: Tue Oct 15, 2019 1:54 pm    Post subject: case ID Reply with quote
Can anyone tell me if case #w0014515 is from a Porsche? If it is, what size motor is it and what model/year Porsche would it have come from? Thanks.
raygreenwood
raygreenwood is offline
PostPosted: Wed Oct 16, 2019 1:34 am    Post subject: Re: case ID Reply with quote
It could be from a 914 or a VW 411.
The VW 411 used the W case from the tail end of the Z series in 1969. It would have been a 1.7L engine.
Ray
[email protected]
dr914@autoatlanta.com is offline
PostPosted: Wed Oct 16, 2019 7:57 am    Post subject: Re: case ID Reply with quote
certainly a 1700 cc engine
desert westy
PostPosted: Wed Oct 16, 2019 4:22 pm    Post subject: Re: case ID Reply with quote
Are these motors worth screwing with? I bought this case with rebuilt crank, rods, heads, etc... about 15 years ago. Also came with a set of Weber 44 IDFs. Plan was to build the motor and put it a VW, not a Porsche. Is it worth the time, money and effort?
[email protected]
PostPosted: Thu Oct 17, 2019 8:12 am    Post subject: Re: case ID Reply with quote
Probably should buy the factory 2.0 version with factory fuel injection Far superior. 44s are too much carb for these engines unless heavily modifed for racing
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Thu Oct 17, 2019 2:58 pm    Post subject: Re: case ID Reply with quote
It doesn't have to stay a 1.7L. Big bore kits are readily available - easily upgraded to 96mm-104mm for larger capacity. Unbreakable bottom end on the T4 engines.
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
malcolm2
malcolm2 is offline
PostPosted: Mon Dec 23, 2019 11:52 am    Post subject: Re: case ID Reply with quote
The 1.7 case is a bit beefier and will need some clearancing to handle a 96mm jugs. and even more to handle a 71mm crank. But it will still be the preferred case to make a 2056cc or a 1911cc.
My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing)
