virusdoc Samba Member
Joined: August 13, 2018 Posts: 525 Location: Durham, NC, USA
Posted: Thu Dec 12, 2019 7:56 am Post subject: Full flow oil filter setup compatible with stock exhaust? |
Title says it all. I am having my case align bored and I'm interested in installing a full flow oil filter system. But I will be running stock exhaust and I understand that some of the available full flow systems aren't compatible with that. Can anyone recommend a solution that is? Thanks! _________________ 1976 Convertible Super Beetle, "June Bug".
FI-->34PICT3 carb conversion-->now dual 40 IDFs
Self-rebuilt 1904 (after totally botching a 1641 rebuild, cussing a lot, and throwing lots of cash in the fire) |
Zundfolge1432 Samba Member
Posted: Thu Dec 12, 2019 8:05 am Post subject: Re: Full flow oil filter setup compatible with stock exhaust? |
I used factory Mexican oil pump w/filter, these are still available
Technically not full flow but it works well. CB makes an in and out cover but you’d need to drill and tap then run all the lines. Cost goes up.
I’m thinking [email protected] |
windfish Samba Member
Posted: Thu Dec 12, 2019 8:38 am Post subject: Re: Full flow oil filter setup compatible with stock exhaust? |
Oh hey you're local. Who's doing your machine work?
Only guy I found was King's over in Burlington.
I'm running a CB Performance Maxi2, same design as the Mexican version but with stock-sized gears; so much easier than a remote filter setup.
Only issue is some of the aftermarket mufflers have the heat riser on the 'wrong' side, like mine -
There are some other work arounds, but the simplest is to just replace the muffler
A note that if you go with the Maxi2 it requires you to shave the top fin for clearance to the pulley tin
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Thu Dec 12, 2019 8:47 am Post subject: Re: Full flow oil filter setup compatible with stock exhaust? |
as they just showed you , the clearance issues arise with the pump/filter combos and the heat riser tube...if you're drilling and tapping for full flow the hoses will clear any exhaust |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4407 Location: Stuck in Ohio
Posted: Thu Dec 12, 2019 9:11 am Post subject: Re: Full flow oil filter setup compatible with stock exhaust? |
I used an EMPI full flow and it has no interference with a stock muffler/heaterboxes.
It did, however, have some interference with the lower pulley tin, so I rounded the corners a bit with a grinder and pounded some relief shape into the back of the pulley tin.
When I replaced the stock muffler with an EMPI GT style stainless muffler, I had some interference with the brass outlet fitting and the header tubes, so I replaced the straight brass outlet fitting with a 45 degree brass fitting to point the hose a little down and towards the engine and that worked great.
I really like the full flow and I mount the spin-off filter under the fender behind the driver's rear wheel with an EMPI bumper bracket. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
bluebus86 Banned
Posted: Thu Dec 12, 2019 9:27 am Post subject: Re: Full flow oil filter setup compatible with stock exhaust? |
full flow system should clear the exhaust system just fine. a plus of this is a larger filter is possible than the pump mount filter. if you need more cooling the full flow also lends itself easy to add a cooler to it. this maybe the case for bigger more heat producing engines, or severe uses.
pump mount filters can have issues with certain mufflers.
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Thu Dec 12, 2019 7:17 pm Post subject: Re: Full flow oil filter setup compatible with stock exhaust? |
volksworld wrote: |
Thank you--this is very clear. I am going to go with the full flow hosed setup! _________________ 1976 Convertible Super Beetle, "June Bug".
Posted: Thu Dec 12, 2019 7:19 pm Post subject: Re: Full flow oil filter setup compatible with stock exhaust? |
windfish wrote: |
I shipped my case to Keith's in WV.
http://keithsautoparts.com
I couldn't find anyone in Raleigh or Durham. Does King's do engine balancing?
I really don't want the on-pump filter. I like the idea of having the filter remote so I have more flexibility with filter size, and the option for an additional cooler in the future. _________________ 1976 Convertible Super Beetle, "June Bug".
Posted: Thu Dec 12, 2019 7:23 pm Post subject: Re: Full flow oil filter setup compatible with stock exhaust? |
windfish wrote: |
Looks like they do almost everything, and they're only 40 minutes from me. Wish I'd found them before shipping off my case! Are you happy with the quality of their work?
I mostly use Hick's VW in Durham. They have an impressive parts selection, mostly good German or Brazilian parts, but they can't do machining. And since they can't balance an engine they've told me balancing a mostly-stock 1600 isn't necessary. But if I'm going to invest this much time and money on a rebuild, I think balancing it only makes sense. I don't ever want to crack that case again! _________________ 1976 Convertible Super Beetle, "June Bug".
Posted: Thu Dec 12, 2019 8:10 pm Post subject: Re: Full flow oil filter setup compatible with stock exhaust? |
virusdoc wrote: |
windfish wrote: |
I mostly use Hick's VW in Durham. They have an impressive parts selection, mostly good German or Brazilian parts, but they can't do machining. And since they can't balance an engine they've told me balancing a mostly-stock 1600 isn't necessary. But if I'm going to invest this much time and money on a rebuild, I think balancing it only makes sense. I don't ever want to crack that case again! |
Hah, I did the same thing.
Shipped my case off to Keith's for an align-bore then found King's, who did the balancing and assembled the new crank.
..And that was my thought as well, I'm this far in what's a couple hundred more in balancing.
Guy at King was super nice, this is my first rebuild and I ended up just bringing him everything and asked him to balance it, assemble the crank, and whatever else he thought needed doing.
A bit more expensive than Keith's, but no shipping.
I'm happy with both shops.. though honestly I have no way to verify any of the work. Both seemed competent.
But yeah, I've used Hicks for a couple things, Lonnie's has gotten more of my repair business 'cause he's more conveniently located. Great to have two shops in town.
I'm in final stages of engine assembly now, ish (slowest rebuild in the world)
Hope to see you on the road |
Xevin Samba Member
Posted: Fri Dec 13, 2019 1:49 am Post subject: Re: Full flow oil filter setup compatible with stock exhaust? |
windfish wrote: |
Not even close to my “Slowest engine build in the world” 11/2017- 09/2019 Wait a minute! Yours is a rebuild, maybe it is Good luck to you both. Make it fun. And remember, “While you doing this you might as well do that” _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Fri Dec 13, 2019 4:55 am Post subject: Re: Full flow oil filter setup compatible with stock exhaust? |
windfish wrote: |
I hope to see you on the road too! My target completion date is early spring, but I'm also re-doing my entire interior and a new convertible top.
Lonnie is a professional, old-school VW mechanic. He'll do it right, won't cut corners, and charges reasonable prices for high quality work. He redid my entire front end right after I got June Bug. But he left a completely rotten steering rack bellows on it (despite telling me he'd replace it) and didn't tell me when I picked it up. Turns out he couldn't get the part on time, but if he'd told me that I'd have waited gladly. Now I have to drop the front end again at some point to install that.
With Hick's, you get a more pragmatic approach to getting on the road again. They don't believe in going original stock. They laughed at what I spent on a rebuilt 34PICT-3 and SVDA distributor, because they think they can just re-jet a Chinese clone carb and get it running great with a cheap 009 (and I'm sure they usually can). They frown at balancing engines and they think full flow oil coolers are a waste of money. I get their perspective, which is to get it running for minimal investment, drive it, and rebuild it when it needs it. But their parts supply for RDU area is unmatched, and they'll shoot the shit all day with you and show you how to do stuff right there in their shop.
Both are great resources for different reasons, and you're right it's awesome to have two in the area. I'm sorta surprised there isn't also a shop in Carrboro with all those damn UNC hippies... _________________ 1976 Convertible Super Beetle, "June Bug".
texastomeh Samba Member
Joined: November 20, 2018 Posts: 291 Location: Dallas, TX
Posted: Fri Dec 13, 2019 8:57 am Post subject: Re: Full flow oil filter setup compatible with stock exhaust? |
Quote: |
“While you're doing this you might as well do that” |
Those words are emblazoned upon the "Event Horizon" of the Black Hole that is VW rebuild/repair/restoration!!!!
Tom |
