CanadaGhiadude Samba Member
Joined: September 30, 2019 Posts: 49 Location: Canada
Posted: Sat Dec 14, 2019 11:11 pm Post subject: 62 Ghia Bumper Overriders aluminum or pot metal? |
On my 1962 Ghia coupe I removed the bumpers to have them ready to be re-chromed and noticed I have a mismatch of overriders. One overrider (guard) from the front & rear bumpers is definitely steel and the remaining three appear to be poor quality pot metal and/or aluminum. I would not suspect this mismatch could be original stock and likely the PO replaced those..maybe.
According to the chrome shop they may have an issue rechroming if pot metal and aluminum is not a concern.
Would anyone know from the below photos if these non-steel overriders are stock and I'm assuming they would are aluminum?
Steel overrider on the left- non-steel overrider on the rt
Backside of steel overrider
Backside of the non-steel overrider
Lars Neuffer find in the forums: Not sure what the material is as per the below?
[img]https://www.thesamba.com/vw/gallery/pix/1979381.jpg[/img] |
Posted: Sat Dec 14, 2019 11:12 pm Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
Viktor Cz. Samba Member
Joined: July 08, 2009 Posts: 68 Location: Sweden / Jönköping
Posted: Sat Dec 14, 2019 11:32 pm Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
According to Neuffer catalog (and my picture) it looks like the ‘non’ steel is the correct one if your car is a -62.
_________________ // Viktor
Karmann Ghia coupe 1966
VW ID.4 2023 |
Posted: Sun Dec 15, 2019 10:31 am Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
Thanks Viktor for the reply..
Still have a few questions:
1. Were the bumper overriders manufactured and installed up to 1962 aluminum or pot metal?
2. Since VW only manufactured the non-steel bumper overriders up to 1962 and switched over to steel, do you think a 62 Ghia could have both types of overriders installed at the factory? |
Burman Samba Member
Posted: Mon Dec 16, 2019 2:04 am Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
CanadaGhiadude wrote: |
1. Were the bumper overriders manufactured and installed up to 1962 aluminum or pot metal? |
They were made in the same material as the door handles which I guess is called "pot metal". It´s not aluminium anyway. And I know...they are hard to chrome since the material leak gases and could cause air bubbles in the chrome.
2. Since VW only manufactured the non-steel bumper overriders up to 1962 and switched over to steel, do you think a 62 Ghia could have both types of overriders installed at the factory?[/quote] I would say no. One of your overriders is most certainly changed sometime over the years. |
Posted: Tue Dec 17, 2019 12:01 pm Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
Well the bumpers are over at the rechroming shop so will see what the manager comes back with on the cost and hopefully not an issue with pot metal overriders..
Any other comments/suggestions greatly appreciated. |
Posted: Tue Dec 17, 2019 11:37 pm Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
According to the plating company I shipped my bumpers to for re-chroming, the overriders as shown in the photos above are NOT pot metal but they are aluminum hence not an issue with chroming.
The insane quote I received for re-chroming complete both the rear and front bumpers is $2000cdn/$1500usd/1360euro.
Now the dilemma of either coughing up the $2k for the re-chroming.. sticking with the solid original bumpers or go with the $1k SS OEM from Vietnam! |
Burman Samba Member
Posted: Wed Dec 18, 2019 12:26 am Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
Not a bad price for the rechrome. Lots of pieces on an american bumper
after all. Thats what I paid for a rechrome last year here in Sweden. Also american type and considered a good price..
I would go for the rechrome.
Still a better fit but also a nice feeling to know they are the originals to the car.
Pay once...cry once
Ok...aluminium they said. Thanks, good to know.
Good luck!
/Jonas |
theghiagirl Samba Member
Joined: February 15, 2004 Posts: 537 Location: Near Portland, OR
Posted: Fri Dec 20, 2019 7:08 pm Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
The bumper guards that I've seen on earlier Ghias are cast (pot metal) and later they used steel, not aluminum.
The other pieces of the bumpers (blades and overrider tubes) are steel and should be chrome plated. If they were aluminum why would the chrome shop plate them instead of polishing them? As far as I know if a piece is made of aluminum it should be polished or anodized depending on its use.
The quote that you got is very reasonable if the shop does a good job of straightening and plating. I've gotten recent quotes from several shops and they range anywhere from $2,000USD-$4,000USD for both bumpers (16 pieces). I'd go with chrome plating the originals all day long if they're in decent condition. |
Posted: Sat Dec 21, 2019 12:00 pm Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
Thanks for the replies...
Phoned my plating guy once again requesting he moves forward with the re-chroming on the bumpers. Mentioned that the overriders are very likely pot metal and not aluminum according to ghia owners/gurus. He indicated they are definitely al and he does buff out and/or repair all the al imperfections prior to chrome plating. He tells me the weight of the overriders in question are about 30% lighter compared to the steel overriders hence al and not pot metal. Either way they handle the plating..
When I have the bumpers back i will post photos of the results.. Totally agree 'now' that sticking with the original bumpers is the answer and not going with the knockoffs.. Lets see how they turn out! |
berliner Samba Member
Joined: December 27, 2006 Posts: 440 Location: west coast canada
Posted: Tue Dec 31, 2019 8:56 pm Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
On my 64 I replaced the mystery-metal parts with steel ones.Turned out really nice when replated,glad I returned the Viet Nam ones. _________________ I'm part of the problem. |
Posted: Fri Mar 12, 2021 8:14 pm Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
I have added a few 62 Ghia finished product bumper photos including the mismatch of overriders as discussed in this forum.
Overall I couldn't be happier with the final outcome from my local Chrome Plating shop. Although going with a plating shop to re-chrome vs a purchase of stainless bumpers it worked out to approximately 35% more cash but worth every penny.
The original bumpers re-chromed look to me like 'factory fresh' & were a breeze to reinstall back on the car for obviously reasons! And to boot supporting a local business is a plus.
Good Luck
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Fri Mar 12, 2021 9:30 pm Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
They look lovely. Now, you need to wax them to seal moisture at the microscopic level. There will remain tiny holes that water will get in, start rust and ruin the lustre. Aruba wax will fill that in and you can top it up every year or so to keep the brilliant shine.
Fabulous result with the OG bumpers
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
obus Samba Member
Joined: March 08, 2001 Posts: 11069 Location: just off Garden State Parkway Exit 81
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3818 Location: Georgia
Posted: Sat Mar 13, 2021 6:45 pm Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
https://www.thesamba.com/vw/forum/viewtopic.php?p=9247501#9247501
Original is the way to go. I sent mine to Advanced Plating in Tennessee. They took all the old stuff off and triple plated them. Expensive? You get what you pay for. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Sun Mar 14, 2021 11:09 am Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
sputnick60 wrote: |
Nicholas |
Thanks for the advise regarding using Aruba wax on the bumpers, I'll add that task to my spring routine. |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Sun Mar 14, 2021 1:51 pm Post subject: Re: 62 Ghia Bumper Overriders aluminum or pot metal? |
Can you advise where to get "Aruba Wax" or does it go by another name? When I google it, I get a bunch of body waxing places, which sounds kind of fun , but probably won't work on my bumper chrome. Or would any other type of common wax work on the bumpers?
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Marcdeb Samba Member
obus Samba Member
