fuel pump interchange
ghiafreek
ghiafreek is offline
PostPosted: Sun Dec 15, 2019 8:58 am    Post subject: fuel pump interchange Reply with quote
I have a '59 36hp fuel pump that is no longer working. Bought a kit but will need time to rebuild. I have a '58 ghia with the original motor on ground. Will that fuel pump work on my '59 bug? Can I just remove and install on bug?
thanks.
gt1953
gt1953 is offline
PostPosted: Sun Dec 15, 2019 9:54 am    Post subject: Re: fuel pump interchange Reply with quote
Do they look the same.
72 type 1
72 Squareback
PostPosted: Sun Dec 15, 2019 10:12 am    Post subject: Re: fuel pump interchange Reply with quote
Yes, they should work exactly the same, even if they look slightly different.
(It may or may not have the removable filter on top)
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Dec 15, 2019 12:03 pm    Post subject: Re: fuel pump interchange Reply with quote
thanks.
If that engine has been sitting long the rubber diaphragm is likely hardened up and ready to split open pouring fuel into the crankcase. Probably better to rebuild the fuel pump, it should only take about an hour to do.
In Stereo, Where Available!
ghiafreek
PostPosted: Sun Dec 15, 2019 1:50 pm    Post subject: Re: fuel pump interchange Reply with quote
Thanks. Was believing it to be a lot longer . Guess I watched the wrong video.
Thank you for your replies.
