virusdoc Samba Member
Joined: August 13, 2018 Posts: 525 Location: Durham, NC, USA
Posted: Mon Dec 16, 2019 6:26 pm Post subject: Flywheel: resurface or replace? |
I'm rebuilding my '76 vert engine, and the flywheel I pulled off is very heavily glazed, has some pitting, and also was clearly parked for some time in direct contact with clutch rivets (leading to worse pitting in those contact areas). So I guess now I know why my clutch shuddered miserably when engaging first gear!
I believe it is the original flywheel for this engine. Should I resurface it, or invest in a new one? If the latter, I'd welcome recommendations for high quality balanced flywheel vendors. Thanks!
_________________ 1976 Convertible Super Beetle, "June Bug".
FI-->34PICT3 carb conversion-->now dual 40 IDFs
Self-rebuilt 1904 (after totally botching a 1641 rebuild, cussing a lot, and throwing lots of cash in the fire) |
Dan the workingstiff Samba Member
Joined: July 03, 2006 Posts: 824 Location: Downriver, MI
Posted: Mon Dec 16, 2019 7:55 pm Post subject: Re: Flywheel: resurface or replace? |
I agree that "seems" fairly pitted. What are specs on it? |
Posted: Mon Dec 16, 2019 8:15 pm Post subject: Re: Flywheel: resurface or replace? |
Dan the workingstiff wrote: |
Its appearance was so striking I haven't measured anything on it. Not sure what I should even measure, although I imagine Bentley has something to say about that. What is most important? _________________ 1976 Convertible Super Beetle, "June Bug".
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon Dec 16, 2019 8:22 pm Post subject: Re: Flywheel: resurface or replace? |
It's burnt and checked... replace it. _________________ Glenn
Member #1009
#BlueSquare |
wcfvw69 Samba Purist
Posted: Mon Dec 16, 2019 8:24 pm Post subject: Re: Flywheel: resurface or replace? |
Glenn wrote: |
It's burnt and checked... replace it. |
Agree but I'll add I'd source an original used German made flywheel still in good shape and have it machined.
I just...don't.. trust... many "new" parts sold today. _________________ Contact me at [email protected]
The Samba member since 2004.
Glenn Mr. 010
windfish Samba Member
Glenn Mr. 010
Posted: Tue Dec 17, 2019 4:07 am Post subject: Re: Flywheel: resurface or replace? |
The "standard" version doesn't say forged, so it might be cast. _________________ Glenn
Member #1009
#BlueSquare |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Tue Dec 17, 2019 7:14 am Post subject: Re: Flywheel: resurface or replace? |
if you get it or another one resurfaced the shop doing the job has to be aware that the surface that the pressure plate bolts onto needs to be machined as well or the pressure plate wont apply sufficient clamping force...this additional cut makes them more expensive to resurface than "regular" flywheels.... |
Zundfolge1432 Samba Member
Posted: Tue Dec 17, 2019 8:27 am Post subject: Re: Flywheel: resurface or replace? |
It’s so easy to look at a picture and pronounce a part bad, I cannot. OEM flywheels are forged and they are tough and they can be rebuilt in most cases. It’s not the face that causes the problems but where it mates to crankshaft, wear at the dowels the seal area and runout. The face can be cut and an equal cut along the mounting surface to keep engagement within specs. The teeth can be machined off and a new ring gear pressed on. All of this can be done but who even rebuilds flywheels anymore? With every passing year less and less support for refurbished OEM parts and people hang more and more chinese junk. What you want to find is a stash of original flywheels. They are still out there gathering dust just like the ones you see here. Shipping costs eat up any chance of sending out to those in need.
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4421 Location: Stuck in Ohio
Posted: Tue Dec 17, 2019 9:21 am Post subject: Re: Flywheel: resurface or replace? |
Zundfolge1432 wrote: |
I agree with all this ^^. However, us older VW veterans who've worked on these VW's for decades know it's worth the extra effort, time and expense to source still in spec, original VW made parts.
To your point, there's still THOUSANDS and thousands of VW flywheels out there collecting dust that only need a light grinding to be reinstalled.
Not all VW engines had hundreds of thousands of miles put on them. Many engines didn't live long or the VW didn't before they were removed and stored. I still run across Bosch distributors when I buy a lot of cores that probably had less than 20k miles on them. Many look brand new internally and are still wearing original, date coded German Bosch condensers, points, and rotors.
My rambling point is while there is some worn out original parts out there, there's also a lot of original parts that were only lightly used. _________________ Contact me at [email protected]
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Tue Dec 17, 2019 10:05 am Post subject: Re: Flywheel: resurface or replace? |
I just took four flywheels into DPR in Santa Ana, CA to have them resurfaced. They came back perfect! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Glenn Mr. 010
Posted: Tue Dec 17, 2019 10:12 am Post subject: Re: Flywheel: resurface or replace? |
Shipping costs eat up any chance of sending out to those in need. |
Jim,
I once shipped 3 in a USPS Large Priority flat rate box for $18. _________________ Glenn
Member #1009
#BlueSquare |
scdevon Samba Member
Joined: October 18, 2017 Posts: 163 Location: Rockies
Posted: Wed Dec 18, 2019 7:13 pm Post subject: Re: Flywheel: resurface or replace? |
I haven't killed a German flywheel yet. The things seem indestructible even the ring gear teeth. The flywheel in the picture looks kind of whooped, but it depends how deep the heat checking and pitting on the face is. _________________ 1970 Beetle 1600 DP |
Posted: Wed Dec 18, 2019 7:49 pm Post subject: Re: Flywheel: resurface or replace? |
Thanks for all the perspectives and suggestions. I have decided to try to find a local machine shop that can resurface this, if it can still be within specs. That might be a challenge--there are no machine shops in the Raleigh Durham area that do VW work anymore. There is one about an hour from here that might--I have a call in to them.
If I can't get it resurfaced I'll buy one from DPR machine shop that Glenn linked above. _________________ 1976 Convertible Super Beetle, "June Bug".
RWK Samba Member
Posted: Thu Dec 19, 2019 5:41 am Post subject: Re: Flywheel: resurface or replace? |
Like mentioned above what ever they grind off clutch face should be removed from PP mounting surface. Some shops have a problem with this because of the recess the PP mounts on, I believe the depth number is around .825 +-, or 21mm, but don't hold me to it, I have a couple here, that's what is marked on them, number I gave to a local shop to grind them to. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Mon Dec 23, 2019 9:15 pm Post subject: Re: Flywheel: resurface or replace? |
virusdoc wrote: |
I'd say there is a 90% chance this wear is NOT causing shuddering. What causes shuddering is usually uneven clutch fork wear which holds the TO bearing at an angle (not parallel) to the flywheel surface. Or movement of the drivetrain as the clutch is released, bad mounts.
There IS a little wear and you could see it as a step on the original machined surface. Several thousandths of an inch. Can you hook a thumbnail on it?
And apparently the vehicle was stored where the clutch and flywheel surface rusted a lot. This is ugly and alarming, but I would predict it will make ZERO difference in performance in a stock situation. One could put a fairly coarse disc, like 60-80 grit on an air sander DA type and smooth it off to make it prettier. This would no doubt give your disc another 5000 miles or so of life. If you live that long!
These are STEEL, not cast. the best, strongest material for the job and almost impossible to break. It will not break if you laid it on the train tracks.
The fact that they are steel is a major factor in what created Hobert Kennedy's business of KEP making engine adapters. he would chuck them up, cut off the VW end and weld as needed. He told me this. (My CRS of an old brain might have changed a detail or two!)
I have dozens of type 1 flywheels. I'll try to take a couple pictures.
WRT balancing: save your money. I used to work at a Speed shop that did balancing. I don't think I ever saw a stock flywheel that needed it much, If you were drag racing and running 7000+ rpm, then balance it. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Tue Dec 24, 2019 7:37 am Post subject: Re: Flywheel: resurface or replace? |
USPS flat rate box to the rescue. One should fit in a medium. More than one will fit in a large. _________________ www.vwnos.com [email protected]
Posted: Tue Dec 24, 2019 7:45 am Post subject: Re: Flywheel: resurface or replace? |
Good news: I found a semi-local machine shop (less than an hour drive from home) that can properly machine both surfaces of my stock flywheel for $35.
He will also balance the entire rotating assembly for me (flywheel, pressure plate, crank, rods, pistons). The balancing may be unnecessary, but it's not that expensive and I've worked with too many unbalanced centrifuges in my career to be not do it. At 3000-4000 rpm, a small percent imbalance makes for a really rough spin. I have to imagine the same is true for the lower end of an engine, and that unequal force can't be good for bearings and other force-bearing parts. _________________ 1976 Convertible Super Beetle, "June Bug".
