andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Thu Dec 19, 2019 7:38 am Post subject: Easy way to cap off heat tubes in body if using J-Tubes |
Was not sure where to put this. but when you eliminate heat, you now have the bakelite tubes that run into the body that should be sealed. I found these plastic cap plugs on Amazon that is used for finishing off metal tubing ends. Cheap, works like a dream and looks decent.
https://smile.amazon.com/gp/product/B07DH7NS9F/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1 _________________ D-Dubya Manx clone - 63 Short pan,1914.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Thu Dec 19, 2019 7:58 am Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
I used 2.5" PVC caps.
I wrapped the inside with duct tape so it would be a "press on" fitting and then sprayed undercoat to do the final sealing.
_________________ Glenn
Member #1009
#BlueSquare
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Thu Dec 19, 2019 8:17 am Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
Glenn wrote: |
I used 2.5" PVC caps. |
Same. The ones that come with the hose clamps on them ensure they will stay in place. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
tattooed_pariah Samba Member
Joined: April 24, 2006 Posts: 2047 Location: El Cajon, CA
Posted: Thu Dec 19, 2019 8:37 am Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
I'm using the passenger side one to run my -6 SS AN fuel line through, and the leads for my CHT thermocouples..
the thermocouple wires come out the passenger foot vent and go up through a hole i drilled under the dash (i put a rubber grommet on it to protect them..)
I had a rust cancer spot just above the floor pan on the passenger side, i i brutalized it and poked a hole in the heater channel and ran the fuel line through it to the outside of the car..
it ain't pretty, but it works. Since then I'm put some rivnuts around the hole, trimmed some sheet metal to wrap around the hose (again, grommeted) and used something we call "Monkey shit" on ships (it's a duct sealing compound similar to silly putty) to keep water out of the channel.. _________________ -pariah (just a novice from "that other VW site")
'72 Volksrod "Effigy"
"Never worry about stepping on people's toes. People who get their toes stepped on are either sitting down, or standing still on the job."
-Admiral Arleigh Burke, USN(ret.) |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Dec 19, 2019 8:51 am Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
Maybe....
https://www.google.com/search?hl=en&biw=1680&a...amp;uact=5
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Thu Dec 19, 2019 8:57 am Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
That’s what I use...Home Depot and Lowes carry them. I believe they are actually 2” ferncos, but they stretch over them
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Thu Dec 19, 2019 9:47 am Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
I used spray paint can caps. Just because that's what I had laying around when I had it in the air. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Thu Dec 19, 2019 10:11 am Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
I'm sure someone make a beer can that will slide tightly over the tube. Take your time and experiment until you find just the right one. |
QRP Samba Member
Joined: April 27, 2008 Posts: 1710 Location: NORTH HOLLYWOOD,CA
Posted: Thu Dec 19, 2019 10:21 am Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
buguy wrote: |
That's what I did . . . LOL |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1213 Location: IRELAND
Posted: Thu Dec 19, 2019 10:36 am Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
I removed them completely and made 2 plates to cover the holes in the crossmembers that attach through the original threaded holes. Seam sealed the edges for water tightness.
Appreciate you need body off to do this but it's neat and frees up space under rear seat for extras like an ecu. |
74 Thing Samba Member
Posted: Thu Dec 19, 2019 11:07 am Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
I use Gorilla tape |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Fri Dec 20, 2019 10:21 am Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
I used nothing!!
The mice LOVE their new home under the back seat! _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
mark tucker Samba Member
Posted: Fri Dec 20, 2019 10:30 am Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
and the mice keep the cheetoos and chips&fries all cleaned up.!!! I dont have a clue what I used...hmm yes I do!! I removed the tube and bolted a plate there!! then on the dr side I routed it to the new oil cooler tin where I cut a big hole in it and cut at a anlgle ,then welded a ss tube to it so i could have heat in the car when I wanted it .works good, but takes longer to get heat than the ex does. but it is heat...to a degree it heats good. |
Posted: Fri Dec 20, 2019 12:10 pm Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
Lots of cool ideas....But on customer cars I spend too much effort making stuff that nobody will see look nice....so my idea looks more finished ... _________________ D-Dubya Manx clone - 63 Short pan,1914.
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3438 Location: San Diego
Posted: Fri Dec 20, 2019 12:57 pm Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
Freeze plug and a couple tack welds |
Glenn Mr. 010
Posted: Fri Dec 20, 2019 12:58 pm Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
chrisflstf wrote: |
It's Bakelite... good luck welding to it.
Member #1009
#BlueSquare |
c77owen Samba Member
Joined: July 07, 2017 Posts: 454 Location: Kansas City, MO
Posted: Fri Dec 20, 2019 1:54 pm Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
buguy wrote: |
Same here...and some duct tape....been on there for two years now |
Posted: Fri Dec 20, 2019 2:50 pm Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
Not all are bakelite, sorry dude |
Glenn Mr. 010
Posted: Fri Dec 20, 2019 2:52 pm Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
chrisflstf wrote: |
Pictures or it didn't happen. _________________ Glenn
Member #1009
#BlueSquare |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Fri Dec 20, 2019 5:05 pm Post subject: Re: Easy way to cap off heat tubes in body if using J-Tubes |
I used Great Stuff spray foam _________________ Volkswagen!
(Compression 8.7:1) |
