nemobuscaptain Samba Member
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2524 Location: Plattsburgh, New York
Posted: Mon Nov 30, 2020 10:51 am Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
nemobuscaptain wrote: |
oprn wrote: |
Now here is something that as an old body man and painter gets my ire up constantly. There is rarely ever a need to take any car totally back to bare metal. The original prep and primer is VERY durable and an excellent base for a refinish.. |
exactly what I thought as I was seeing that, and exactly what my autobody instructor taught us. no primer we install can be as good as the factory stuff, e-cote or whatever.
I hope it was epoxy primer. |
A lot of times I end up taking an entire panel down to mostly bare metal if it needs filler or work. If possible I leave the original paint intact as it is hard as nails and chemically inert. It really depends on what I’m working on. |
SLVRSRFR Samba Member
Joined: October 02, 2008 Posts: 154 Location: Guelph, On, CANADA
Posted: Wed Jan 13, 2021 1:52 pm Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
I've been wanting to do an early Euro style metal dash for awhile now - some of the pictures I have seen of them look really good, and some look really bad...
I didn't want to be locked in to the idea so I left my original dash the way it is and picked up another one to mess around with.
Here it is stripped down - I peeled the padding off and then brought it over to my powder coater friend to strip in his oven - came out nice and clean.
I then took it over to my buddy Wes's place - dude does amazing sheet metal work (check him out on Instagram - vintage_tin) and he shaped and welded in patches for me. We got rid of the obround holes on the ends, a bunch of the small switch holes along the bottom, and the radio hole.
I got the pieces back from paint and started to put them together this past weekend - I am super happy with how it is coming out - can't wait to see how it looks installed in the bus!
_________________ Brian
'78 westy, '64 sedan |
Posted: Wed Feb 17, 2021 9:18 am Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
Some more bracket fabrication...
I made both early and late model alternator brackets
I was missing some exhaust brackets, so I made some of those as well.
The bends on these are not parallel with the ends of the brackets, so I had make a sacrificial tab for alignment on the back stop of the press brake.
If anyone needs any of these, they are available from Scott at German Supply. _________________ Brian
The Volkswagen Ranch Samba Member
Joined: November 24, 2002 Posts: 698 Location: Arizona
Posted: Sat Feb 20, 2021 7:57 am Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
Brian, doing a fantastic job! I am in the process of restoring a 76 Westy, and also purchased the access door kit for the fuel sending unit. My motor is still out, and I am in the process of restoring the engine compartment and fuel tank areas. Did you possibly save your measurements for where you located the opening hole for the kit? Would be MUCH appreciated !! Thanks, Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Mon Feb 22, 2021 6:39 am Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
The Volkswagen Ranch wrote: |
Brian, doing a fantastic job! I am in the process of restoring a 76 Westy, and also purchased the access door kit for the fuel sending unit. My motor is still out, and I am in the process of restoring the engine compartment and fuel tank areas. Did you possibly save your measurements for where you located the opening hole for the kit? Would be MUCH appreciated !! Thanks, Bob |
Thank you! Yes, I have some measurements - they are on page 9 of this thread...
https://www.thesamba.com/vw/forum/viewtopic.php?p=9380126&highlight=#9380126 _________________ Brian
Posted: Mon Feb 22, 2021 3:34 pm Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
Brian , thank you VERY much! Going to go out and hopefully spend some time in the garage tomorrow at last. Just got too cold the past couple of weeks, and had to let my hands heal from “cracks “ on most of my fingertips. Even though used the Buddy propane heater to bring it up to 60 degrees.... everything is still cold!
zoobum Samba Member
Joined: June 09, 2015 Posts: 211 Location: Los Angeles
Posted: Mon Feb 22, 2021 9:53 pm Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
Great work and photos. I'll be following to see the final result.
I have so many of those damn Kirkland rags, I get one free every time I go to the carwash. lol _________________ -Zach
1979 CA Riviera 2.0L FI |
Posted: Tue Feb 23, 2021 8:16 am Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
zoobum wrote: |
I have so many of those damn Kirkland rags, I get one free every time I go to the carwash. lol |
Thanks! Final result still seems so far away - I am hoping to have it ready to go for June or July, but there is so much left to do, its a little overwhelming at times...
Those rags do come in handy! _________________ Brian
calvinater Samba Member
Posted: Wed Feb 24, 2021 4:49 am Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
Try corn huskers lotion for you cracked finger tips. _________________ "Albatross"! |
Posted: Wed Feb 24, 2021 6:55 am Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
Calvinater, I used to use that many , many years ago! Totally forgot about it. Thank you ! Going to see if I can find some today. Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Fri Feb 26, 2021 1:44 pm Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
I cleaned up the steering column (more zinc plating!) - replaced the coupler and had the column tube and cover plate powder coated...
Question - is there supposed to be a seal of some sort between the column tube and cover plate? There wasn't one when I disassembled, but there is a bit of a gap there.
germansupplyscott Samba Member
Posted: Fri Feb 26, 2021 2:07 pm Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
No seal. Earlier years have a plastic bushing there but not your year. _________________ SL |
Posted: Fri Feb 26, 2021 2:23 pm Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
germansupplyscott wrote: |
No seal. Earlier years have a plastic bushing there but not your year. |
Beauty - thanks Scott _________________ Brian
Posted: Thu Nov 18, 2021 11:52 am Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
After several months off - I am back at it...
New goal is to have it on the road for summer 2022.
Couple of more parts cleaned, re-plated, re-assembled.
Also got the engine in a couple of weeks ago.
Currently working on wiring.
Posted: Tue Nov 30, 2021 12:51 pm Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
Just finished up my engine bay lighting project...
Drew everything up in cad and laser cut out of .060" aluminum.
Epoxied the 2 panels together and then had them powdercoated the same grey as the firewall panel.
Wired up the 12v LED lights and riveted the panels into place.
Should make breaking down in the middle of the night a little more enjoyable!!
crownline Samba Member
Joined: September 10, 2010 Posts: 588 Location: Northwoods of WI
Posted: Tue Nov 30, 2021 2:31 pm Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
Beautiful. Now you need a lexan deck lid. _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL] |
Mberglo Samba Member
Joined: January 13, 2020 Posts: 381 Location: Huntsville, AL
Posted: Tue Nov 30, 2021 3:09 pm Post subject: Re: from Silver to ? - a '78 Westy refresh story... |
This is the nicest bus restoration I've seen. You are extremely detailed and it shows. Your bus is going to be a showstopper. I don't think I could drive it after what you've done. |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1763 Location: Newmarket, ON
