Repainting Licence Plate frames
harrymarlin
harrymarlin is offline
PostPosted: Thu Dec 19, 2019 8:36 pm    Post subject: Repainting Licence Plate frames Reply with quote
I have an original license plate for the dealer my car was purchased from I would like to restore. I've been working on setting up painting it, but I can't seem to get to a place I feel comfortable with, and I wanted to see if there are folks out there would may be more willing/able than I am to repaint license plate frames. Searching the forums, I see a fair amount of posts about rechroming them (which mine does not need), but not very much about paint.
Any recommendations of folks who are up for painting these on a commission?
-Harry
1967 Ruby Red Convertible Beetle ("Becky")
ISO Albuquerque "Imported Motors" dealership paraphernalia
RareAir
RareAir is offline
PostPosted: Fri Dec 20, 2019 1:11 am    Post subject: Re: Repainting Licence Plate frames Reply with quote
I’ve painted over 40 frames for personal use, friends & customers. As you can see, I didn’t bother replating them. Here’s a few samples of my work:
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
harrymarlin
PostPosted: Fri Dec 20, 2019 5:46 am    Post subject: Re: Repainting Licence Plate frames Reply with quote
Nice! After spending weeks going through several prep methods, I just don't seem to be doing it right, so I'll PM you. Mine is below - I believe both the top and bottom sections were dark blue (like in one of yours). I thought I would just use a chrome polish to shine up the rest of the plate pretty well, and then spray a clear protectant over the final product.
Thoughts?
-Harry
harrymarlin
PostPosted: Sat Dec 21, 2019 9:53 am    Post subject: Re: Repainting Licence Plate frames Reply with quote
Any aspiring painters who would like to paint this frame on commission? Everett - do people post want ads for services? Any particular places good to look for someone who might do this (perhaps I should look for a lo al art achool...)?
-Harry
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Dec 21, 2019 9:57 am    Post subject: Re: Repainting Licence Plate frames Reply with quote
Contact Rareair.
Glenn
Member #1009
#BlueSquare
62DoKaGuy
62DoKaGuy is offline
PostPosted: Sat Dec 21, 2019 10:06 am    Post subject: Re: Repainting Licence Plate frames Reply with quote
On the topic of refurbishing plate frames, what’s the closest-to-original blue paint people have found and used? I need to do some touch-ups and would like to go into it prepared. Thanks.
,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there...
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold)
harrymarlin
PostPosted: Sat Dec 21, 2019 1:05 pm    Post subject: Re: Repainting Licence Plate frames Reply with quote
Glenn wrote:
Contact Rareair.
I have, but I am hedging my bets in case he doesn't answer or is not interested.
-Harry
PostPosted: Sat Dec 21, 2019 3:45 pm    Post subject: Re: Repainting Licence Plate frames Reply with quote
Yes, there is a services category in the Classifieds where you can post a WTB (Want To Buy) ad, although I don't know how successful it is for Services Wanted
I'm guessing getting a recommendation here might be better in this situation.
Typ3nut
Typ3nut is offline
PostPosted: Sat Dec 21, 2019 6:41 pm    Post subject: Re: Repainting Licence Plate frames Reply with quote
harrymarlin,
The license plate frame you have is aluminum and not an embossed style frame, the lettering was probably screen printed. The best suggestion would be to do it in vinyl. Take to a vinyl sign shop, show them what you have and what your trying to achieve. They could print or vinyl die-cut these for you.
harrymarlin
PostPosted: Tue Dec 24, 2019 10:17 am    Post subject: Re: Repainting Licence Plate frames Reply with quote
Typ3nut wrote:
harrymarlin,
Good point! The letters are not embossed enough to lend themselves to be painted by a paint roller, but I don't think they are screen printed (the letters are *very* slightly raised, and rougher than the rest of the metal). I'll try the vinyl sign shop, and I'm checking on a custom stencil, as well.
Thanks!
-Harry
hitest
hitest is offline
PostPosted: Tue Dec 24, 2019 10:58 am    Post subject: Re: Repainting Licence Plate frames Reply with quote
Go to a sign shop that does the good ole-fashioned cut and weeding method If you want to make stencils. The newest sign shops digitize and print logos and letters with ink on a vinyl backing (think car wrapping).
If I had your frame- I'd stencil the background, paint it, let it CURE. Then I'd lay down a stencil of the lettering and lightly paint them in, remove the stencil and admire your work!
FU#5
Jos.Hall
Jos.Hall is offline
PostPosted: Mon Dec 30, 2019 3:01 am    Post subject: Re: Repainting Licence Plate frames Reply with quote
Harry, I'm just now seeing your thread here. If you want, I have a vinyl cutting machine. If you have the ability to scan your frame, send me the file and the measurements, I can send you vinyl to use as a stencil.
PM ME TO ADD YOUR '67 TO THE '67 BUG REGISTRY!!!!
https://vintagejalopy.com/67bugregistry/vwbugregistry1967_view.php
'67 L41 Sedan 117333192
'67 L41 Vert 157343589
'67 L19K Vert 157452166
'67 L19K Vert ??????
'67 L282 Vert 157419653
'67 L620 Sedan 117534350 (Sold)
'67 L54 Vert 15745800 (Parted out)
'52 Split based Devin
harrymarlin
PostPosted: Mon Jan 06, 2020 1:37 pm    Post subject: Re: Repainting Licence Plate frames Reply with quote
Thanks, guys! Excellent suggestions! Jos - I'll send you the file with dimensions, soon, if you are up for it. I apologize for the delay in posting back to this. I hope you all had a wonderful holiday!
-Harry
