Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Fri Dec 20, 2019 6:43 am Post subject: Do lash caps result in non-standard geometry? |
Hi
I've bought a set of pre-assembled, stock style, EMPI 1600 dual port heads as part of my engine rebuild.
While checking some other info in the EMPI catalogue, I've noticed that they state that lash caps are also necessary because the valves are stainless steel.
Does that also mean that I'm going to have to sort out the rocker arm geometry as well because the valve stems will effectively become longer by the thickness of the caps?
I'm trying to build this engine as close to stock as possible and only make modifications to improve longevity and simplify maintenance etc., so I'd rather not mess with making custom push rods.
Is it acceptable to shim? I've seen posts against shimming, but I'm not sure if it's 'acceptable' or 'normal' practice in this case? _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Fri Dec 20, 2019 7:31 am Post subject: Re: Do lash caps result in non-standard geometry? |
Unless these heads are made with a stock casting machined exactly the same as stock.....same spring seat pocket machining, same cylinder seat depth machining etc. Etc. Etc.......I would think there "could" be a decent amount geometry change required.
Yes.....you "CAN" fix it with shims....but only by so much. Shims move the rocker arms toward the valve cover. At some point tbey either start to ding on the cover or you hsve to start thinking of lengthening the push rods.
Personally....if I were going to go the route you planned to go.....I would have looked for a complete head that has valves with chromed stems and stellited tips. No lash caps required.
And.....the difference in cost for valves like that.....is probably about the same as the cost for a new set of custom pushrods (depending on what you use). Ray |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Fri Dec 20, 2019 9:16 am Post subject: Re: Do lash caps result in non-standard geometry? |
Check if the valves have hardened stems by using a magnet on the tips. If they stick you don't need caps. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Fri Dec 20, 2019 9:31 am Post subject: Re: Do lash caps result in non-standard geometry? |
Who.Me? wrote: |
Hi
Is it acceptable to shim? I've seen posts against shimming, but I'm not sure if it's 'acceptable' or 'normal' practice in this case? |
The answer is.......no one knows until you actually assemble your engine. There are too many variables. Yes, use a magnet to check the tips of the valves. You shouldn't need lash caps(I have never used them with the quality stainless steel valves I use in my heads) Nothing wrong with using .015 to .060 in rocker stand shims if necessary. If you need more than they, it's time to cut push rods. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
mark tucker Samba Member
Posted: Fri Dec 20, 2019 10:34 am Post subject: Re: Do lash caps result in non-standard geometry? |
you should "sort out" the rocker geo weather you use them or not. I use them on every build I do. and yes they do change it. also the adjusters you use can/will also change it. and depending on the adjusters you use the rockers may need some machining to work right and help put the geo where it needs to be. if you want it to last do it right, do it 1 time and be done with it. |
Posted: Fri Dec 20, 2019 10:43 am Post subject: Re: Do lash caps result in non-standard geometry? |
mark tucker wrote: |
He is building a stock 1600 for the street.....it doesn't have to be that complicated.
I mean, if he's going to do all that, he may as well slap an 84 stroker crank in there too _________________ Please "LIKE" us on facebook to see what we are working on.
www.mofoco.com
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Fri Dec 20, 2019 12:23 pm Post subject: Re: Do lash caps result in non-standard geometry? |
What is complicating things are those EMPI (empty) heads.
If they say they require lash caps, why wouldn’t they come as a kit?
Are they supposed to be stock replacements?
It seems odd that they would make a stock replacement part that would require you to modify other parts of your engine but it is EMPI after all. _________________ Volkswagen!
(Compression 8.7:1) |
c77owen Samba Member
Joined: July 07, 2017 Posts: 454 Location: Kansas City, MO
Posted: Fri Dec 20, 2019 2:00 pm Post subject: Re: Do lash caps result in non-standard geometry? |
I can tell you that with those heads you DO need lash caps. I currently have a customer's engine torn apart with less than 500 miles that someone else built with no lash caps and these heads. Among many other build issues, a couple of the valve tips already have razor sharp edges. It would just be a matter of short time before catastrophic damage. I agree they should come with the heads when purchased, just like all of the studs, but none the less, they don't. |
KROC Samba Member
Joined: February 20, 2006 Posts: 359 Location: Vancouver B.C.
Posted: Sat Dec 21, 2019 9:55 am Post subject: Re: Do lash caps result in non-standard geometry? |
I believe Empi is assuming you would be using stock adjusting screws. If you use swivel feet adjusting screws instead of stock ones you do not need lash caps with stainless valves. ( just another option ) |
Posted: Sun Dec 22, 2019 9:31 am Post subject: Re: Do lash caps result in non-standard geometry? |
[email protected] wrote: |
I mean, if he's going to do all that, he may as well slap an 84 stroker crank in there too |
I like everything I build to last. no reason not to do it right nomater what it is going into. after all it's not a funny car thats going to get tore appart every week or run. |
Posted: Mon Dec 23, 2019 1:55 pm Post subject: Re: Do lash caps result in non-standard geometry? |
That's not far off what it was before I finally decided to dig in to this engine.
Thanks all for the additional comments. I've been in touch with the vendor here in the UK, and they've confirmed that lash caps are needed, and that they hadn't been told by EMPI.
The vendor also sells EMPI's lash caps and it says they add .060", so apparently at the top end of shimming. I'll get a set of caps and shims and see whether that works out. If not, I guess I'll have some reading to do on custom pushrods.
I agree with the comment that it's daft selling 'complete' stock (their description) heads and then saying they need additional parts that will leave you with non-stock rocker geometry. That's not 'stock'.
At least they're decent castings. Much better than the Auto Linea heads that I'm scrapping. _________________ Andy
NJ John Samba Member
Joined: September 21, 2007 Posts: 2222 Location: HdG, MD & NJ
Posted: Tue Dec 24, 2019 2:24 pm Post subject: Re: Do lash caps result in non-standard geometry? |
Rocker arms with the adjuster on the pushrod side can get a groove worn in them from the valve. Probably from a forged valve and non forged rocker. Not sure about forged on forged.... _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Posted: Sun Feb 23, 2020 11:20 am Post subject: Re: Do lash caps result in non-standard geometry? |
I knew these lash caps would be a pain in the arse, but it the whole lot seems out of whack.
Even without the lash caps, the rocker arms push on the valve stems with the adjusters fully wound in, so the valves never fully close. It's obviously worse with the lash caps on.
I measure the lash caps as 2mm thick, so going to have to shim a lot to get enough clearance to use the caps and get any adjustment. Not sure whether that's achievable without the adjusters contacting the valve covers.
I can understand the clearance issue with the lash caps on but the fact that the arms contact the valve stems even with the adjusters wound fully in seems odd. There was plenty of clearance and adjustment with the old heads.
The rocker pedestal heights are the same, and the brackets that hold the shafts are the same as another set I have. It looks like the valve stems in the new heads are about 0.5mm longer though.
To add to the annoyance factor, the head studs also contact the edges of the inlet valve rocker arms. Hopefully shimming will get enough clearance to sort that though. _________________ Andy
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sun Feb 23, 2020 11:50 am Post subject: Re: Do lash caps result in non-standard geometry? |
Let's clear a couple things up.
Are the rockers, adjuster over the valve stem?
Or are they adjuster over the push rod?
What type of adjuster? Elephant foot? Ball? Stock adjuster pin type? Cup over the PR?
Are you trying to use the stock push rods while attempting to get the rocker geo figured out?
Post a pic or 100 of what your dealing with. It can help with understanding what you're up against.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Feb 23, 2020 12:56 pm Post subject: Re: Do lash caps result in non-standard geometry? |
67rustavenger wrote: |
Good Luck. |
Stock VW Type 1 rocker assemblies with stock pin(?)-type adjusters. I refurbished my old ones with new shafts and adjusters. This is/will be a stock engine.
The pushrods feel correctly seated in the cups on the rocker arms. Yes, I'm using the stock rods that came out of this engine.
I didn't take many pics after I started to hit these problems because I was assembing and dissassembling to try and find the problem.
This is the clearance between the #1 exhaust rocker arm with the lash cap removed, adjuster wound fully in and a 0.03" shim under the pedestals. Engine is at TDC on #1...
And this is the interference between the stud and the edge of the rocker arm. You can see where it cut a groove before I worked out what was going on and added the shim.
Posted: Sun Feb 23, 2020 1:48 pm Post subject: Re: Do lash caps result in non-standard geometry? |
Andy,
There's no real way to soften this.
But you may have to pull the heads and cut the head studs. So they clear the rocker assembly. You can pull the studs one at a time and cut them. Then reinstall them too.
Also, it appears that you are gonna need to make a custom set of push rods for your new heads. This could be caused by the fly cut on the cylinder side of the heads. It causes the rocker adjuster tips to be too close to the valve stem. Then the problem is compounded by the lash caps added thickness.
Do the push rods after you have the rocker geo figured and set. Then the PR length can be measured. You can cut the PR's yourself or if your confident that you have the length correct. Order a set from various vendors. Like ACN, Dan Ruddock, Smith Brothers.......
You'll need an adjustable PR to get the length figured out.
Sorry if it sounds like I'm raining on your parade. But this is what I'm observing from your pics.
Buy Once, Cry Once!
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun Feb 23, 2020 3:11 pm Post subject: Re: Do lash caps result in non-standard geometry? |
You might be able to fix it by adding swivel feet or elephant feet.
You may or may not have to grind/sand some off the bottom of your rockers on the adjuster side to make room for the swivel/elephant feet.
You will still need to do a geometry check but by adding lash caps, swivel feet and some shims under the rocker shaft you can move everything up and still get decent geometry without changing pushrods.
I did it on my heads with stock pushrods. I put 27,000 miles on it and saw no ill effects from it.
I ground I think about .050-.060" off the bottom of the rocker to move the adjuster up higher.....I never used lash caps at that time but I managed to use the stock pushrods with a higher lift cam.
Just check your half lift and pushrod angles to the adjuster and see if you can get something close with shims and adjustments.
It's not too hard but it takes a little time and a few setups in a bunch of different ways to find the best scenario.
Swivel adjusters are cheap and do work without lashcaps.
You will need a micrometer and magnetic stand to measure all this. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Mon Feb 24, 2020 6:57 am Post subject: Re: Do lash caps result in non-standard geometry? |
Thanks both.
Pulling the heads to shorten the studs isn't the end of the world. I reckon I could get them off without disturbing the barrel-to-case seal. Although I wonder if I'd be better off doing it in-situ with a dremmel cut-off wheel, if I mask the heads up leaving just the studs projecting? Less chance of metal flakes ending up in the cylinders?
I think my biggest concern is whether there's physically enough 'headroom' under the valve covers to shim the assemblies high enough to set the geometry. If it's a direct relationship, then I reckon I need to raise them off the pedestals by at least 3-4mm, which would risk them hitting the valve covers?
Unfortunately, I can't test that at the moment because the powder coater shipped my valve covers out with another customer's order by mistake. I may have to find some cheap ones just to mock it up to avoid delay.
If I have to arrange new pushrods, then so be it. I'd probably get them cut by someone else though. It seems pretty critical that they're all exactly the right length and I only have hand tools.
I've considered swivel- and elephant foot adjusters as others have said that they negage the need for the lash caps altogether. But again, it looks like they need to be precisely ground and I only have a basic, hobby bench grinding wheel.
If I know that shimming by that much is doable clearance-wise, then at least I could get on with the rest of the build and sort the geometry last.
Oh, and these heads weren't fly cut. I decided to stick with stock VW compression ratios. _________________ Andy
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Mon Feb 24, 2020 8:41 am Post subject: Re: Do lash caps result in non-standard geometry? |
Stainless valves needed lash caps is an old wives tail.
Do whatever makes the geometry correct.
In order to do that, you need to know what to look for.
Lots of folks will have differing opinions on what correct geometry looks like.
Especially with stock rockers..
Especially with swivel feet...
Correct geometry may be hard to see thru the mess. |
ekacpuc Samba Member
Joined: December 08, 2010 Posts: 1414 Location: ketchikan alaska
Posted: Mon Feb 24, 2020 9:36 am Post subject: Re: Do lash caps result in non-standard geometry? |
Ohio Tom wrote: |
Totally agree. That’s why instead of just reading what people have to say here it’s always best to search elsewhere as well. The theory on geometry is the same with plenty of water cooled motors and those guys tend to be more up to date on things. Nothing wrong with the samba just easier to learn the theory behind geometry by reading about it from multiple places.
To the OP. You can’t just get an adjustable pushrod and measure then order one already cut to length in the UK? Don’t be scared about geometry. It’s really about valve guide wear. I use the half lift theory as it makes the most sense. Good luck! |
