Peter - Belgium Samba Member
Joined: December 22, 2003 Posts: 762 Location: Brussels - Belgium
Posted: Sat Dec 21, 2019 10:41 am Post subject: 912 at lowest position... I think... how to go lower? |
looking at lowering the 912 about 5cm just to eliminate the gap I now still have above the top of the tire and the bottom of the wheelwell... but seems like the adjustment is already at the lowest setting?
i understood the front is a bit like a T3 and I shouldbe able to trake it apart and rotate splines? but sofar I do not see immeadiately how to do?
What about the rear? Looks like not much there anymore so will be readjusting splines?
I checked the pelican parts site, but did not see clear pics explaining? Anyone that can guide me on what to do here?
Thanks!!
Peter _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
Starbucket Samba Member
Posted: Sat Dec 21, 2019 11:27 am Post subject: Re: 912 at lowest position... I think... how to go lower? |
This may help. |
Joined: December 28, 2016 Posts: 280 Location: atlanta ga
Posted: Sat Dec 21, 2019 12:05 pm Post subject: Re: 912 at lowest position... I think... how to go lower? |
take the weight off the car, remove the screw, remove the cap and reposition |
Posted: Thu Dec 26, 2019 11:27 am Post subject: Re: 912 at lowest position... I think... how to go lower? |
Managed to lower the 912 thanks for the help!
Just one question still left.., the rearward part with the screw is really not foxed at all to the torsion bar? It just sildes over... and this is supposed to stay in postion like this? Seems bit strange? I would have expected some kind if locking? Now there is only a circlips at the end to prevent the toraion bar geom moving out, but the part itself is not locked in the bracket?
Thbaks! _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
PCHOutlaw Samba Member
Joined: December 03, 2015 Posts: 2 Location: Huntington Beach, Ca.
Posted: Mon Jun 08, 2020 6:12 pm Post subject: Re: 912 at lowest position... I think... how to go lower? |
I’m sure this isn’t what you were asking, but... all the way to the floor!
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Mon Jul 13, 2020 3:53 am Post subject: Re: 912 at lowest position... I think... how to go lower? |
PCHOutlaw wrote: |
Ithink you're cheating, looks like a Volskwagen beam in front
But supercool!!!
Did you put a full VW pan underneath? _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Posted: Wed Aug 26, 2020 12:27 pm Post subject: Re: 912 at lowest position... I think... how to go lower? |
just a little cheating. Yes everything was rotted out, has a Ghia pan and lower structure blended into it. |
tisius Samba Member
Posted: Thu Aug 27, 2020 6:48 am Post subject: Re: 912 at lowest position... I think... how to go lower? |
PCHOutlaw wrote: |
That makes sense, well done!! _________________ drive it like you just robbed the bank
