fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Sat Dec 21, 2019 11:47 am Post subject: Installing 45l Reimo grey/fresh water tank |
Mrs fxr is delighted with her birthday present - a 45 litre Reimo fresh/grey water tank. The intention is to use it as a fresh water tank when travelling where water is scarce (e.g. Baja) and as a grey water tank when in places where dumping grey water is frowned upon (bear country, some BLM land).
We'd be cleaning it out between trips, and altering some simple plumbing when changing roles. But first - to fit it in place! It is intended to fit between the frame rails on the passenger side. However, on inspection, there are a couple of studs which stop it even locating in place. Are these studs for some other accessory that I haven't come across?
I'll cut them out anyway - but I'd like to know what they were originally intended to do.
More in days to come. _________________ Jim Crowther
Vespa GTS 300 |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Sat Dec 21, 2019 11:59 am Post subject: Re: Installing 45l Reimo grey/fresh water tank |
Don’t know use of those studs. They are big!
I had other 1/4” studs I cut off that were located more towards the center of the space. I thought they were holding ac or wiring clamps.
I have a similar water tank that I’m going to mount with flat steel straps. How does yours mount?
Any idea what the plastic is so I can figure out how to modify and glue?
Tia _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Zeitgeist 13 Samba Member
Posted: Sat Dec 21, 2019 12:08 pm Post subject: Re: Installing 45l Reimo grey/fresh water tank |
I can only assume you plan on filtering the freshwater feed after using the tank for grey water purposes. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
SyncroBouree Samba Member
Joined: August 25, 2017 Posts: 26 Location: Alongside Monterey Bay
Posted: Sat Dec 21, 2019 12:11 pm Post subject: Re: Installing 45l Reimo grey/fresh water tank |
If I recall correctly, others have pointed out that their alignment supports the mounting of a second propane tank... _________________ --Liam
1990 Vanagon GL Syncro Westy VW1.8T Triple-Knobber
1975 911S Widened Turbo/RSR Hybrid
1979 Harley Lowrider -- Donated to a good home
1969 Ford Bronco Half-Cab 351W, Toploader, Dana 44 FE, Detroit Locker, Duffy’s Suspension – wish I still had it
1962 GMC 3/4T Fleetside, V6<-Chevy 409 w/factory headers, Camper/Tow Rig – ditto |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Sat Dec 21, 2019 12:28 pm Post subject: Re: Installing 45l Reimo grey/fresh water tank |
I have this very same tank under my van at the moment. I use it strictly as a grey water tank (BTW- it's ABS plastic). I have it mounted on the drivers side, towards the rear of the cavity. (For whatever reason, my van has a door track on the left, but no door.)
I fit the tank into place (it's a tight fit), then drilled upwards and used long carriage bolts and big fat washers to bolt it into place.
I would never even consider using it as a fresh water tank. (ABS as opposed to Polyethylene) white plastic.... _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
fxr Samba Member
Posted: Sat Dec 21, 2019 12:56 pm Post subject: Re: Installing 45l Reimo grey/fresh water tank |
rmcd wrote: |
Tia |
I'm still working out how I want to mount this. It's obviously designed to have four bolts come through the floor - but I might use straps between the frame members instead.
No idea on the plastic - but if it's OK for potable water in the EU then at least it won't be poisonous! _________________ Jim Crowther
Vespa GTS 300 |
fxr Samba Member
Posted: Sat Dec 21, 2019 12:58 pm Post subject: Re: Installing 45l Reimo grey/fresh water tank |
Regarding fresh water use - we wouldn't be drinking it anyway (we have separate tanks for that) but using it for washing up or the (very) occasional shower. Easy enough to flush out after grey water use. _________________ Jim Crowther
Vespa GTS 300 |
fxr Samba Member
Posted: Sat Dec 21, 2019 4:43 pm Post subject: Re: Installing 45l Reimo grey/fresh water tank |
OK, so the remains of the cut-off studs and two of the welded-on nuts are clear of the tank - but one nut just hits the front round bit on the top of the tank. A heat gun and a small hammer dealt with that.
Now drilling holes for some 4" coach bolts. _________________ Jim Crowther
Vespa GTS 300 |
VeeDubDaySpa Samba Member
Joined: February 29, 2008 Posts: 368 Location: Bend, OR
Posted: Tue May 26, 2020 2:21 pm Post subject: Re: Installing 45l Reimo grey/fresh water tank |
To mount these tanks, we use 14" Quick Fists. Works really well.
_________________ North American Hightop Installer/Distributor
Current stock (5)
Hot Water Systems
90 Syncro NAHT Vanagon RHINO
86 "Syncro" Van DIAMOND
87 Syncro Hightop WestyCamper ROCKY (for sale soon)
79 bay window OLIVER |
candersenortiz Samba Member
Posted: Thu Jan 13, 2022 7:30 am Post subject: Re: Installing 45l Reimo grey/fresh water tank |
VeeDubDaySpa wrote: |
This mounting idea looks awesome and easier that the others!
Do you think you could share how did you actually attached the Quick Fist clamps to the frame? What hardware did you use? Pictures would be really helpful!
Much much appreciated. Greetings from Chile, south america! |
Schnippzle Samba Member
Joined: February 04, 2021 Posts: 288 Location: Swede in London, UK
Posted: Thu Jan 13, 2022 8:51 am Post subject: Re: Installing 45l Reimo grey/fresh water tank |
To mount these tanks, we use 14" Quick Fists. Works really well. |
Are you not concerned that rocks or debris will damage the tanks when driving at highway speeds? _________________ 1988 Caravelle - FB25B - Syncro converted
2016 MB E63 AMG S - The daily driver
2019 Harley Davidson FXFBS Fat Bob - The leisure |
Posted: Thu Jan 13, 2022 11:30 am Post subject: Re: Installing 45l Reimo grey/fresh water tank |
These tanks are THICK ABS plastic!
You can wail on it with a hammer till your arm falls off, it won't notice! _________________ 1990 Feldjäger Syncro AAZ
Click to view image
rmcd Samba Member
leecat Samba Member
Joined: September 13, 2012 Posts: 773 Location: Regina
Posted: Fri Jan 14, 2022 4:05 am Post subject: Re: Installing 45l Reimo grey/fresh water tank |
Nice tanks! How are you guys filling them - cutting a big hole in the floor to access the top filler? Or dropping them to fill (can't imagine) and/or filling through the tiny end hoses?
Also - re: the cut-up-tank photo...I assume that tank is upside-down? Or is there that large internal flange around both orange caps? If so, how would you completely drain it?
As to gluing them, if they're ABS plastic then plumber's ABS glue (the yellow stuff) should work, that stuff is wicked and gives you a literal 3 to 5 second working window before it melts the ABS together. |
Posted: Fri Jan 14, 2022 4:07 am Post subject: Re: Installing 45l Reimo grey/fresh water tank |
Team WorldTour wrote: |
You can wail on it with a hammer till your arm falls off, it won't notice! |
Sweet, thank you. _________________ 1988 Caravelle - FB25B - Syncro converted
Posted: Fri Jan 14, 2022 7:48 am Post subject: Re: Installing 45l Reimo grey/fresh water tank |
This is a GREY WATER tank. It's where your sink drains to. You can buy a tap to mount for drainage. As for the *two* large lids, mine has only the bottom lid. I use it for cleaning. I have holes drilled for the drain (through the floor). Easy to mount. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Fri Jan 14, 2022 11:36 am Post subject: Re: Installing 45l Reimo grey/fresh water tank |
I got the 60L as well, with a cap on each side, bc they're built to be used on either side of the van.
The drain from the Westfalia tank feeds into the Reimo tank by gravity, so it's just one big 100L tank in 2.
Pumping is done from the lowest tank (Reimo)
Venting is a 1/2 hose that goes up in the engine vent pilar. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Fri Jan 14, 2022 3:11 pm Post subject: Re: Installing 45l Reimo grey/fresh water tank |
This one is used as a fresh water tank, often holding 115°F water for showers/dishes etc. - it has seen many miles and adventures on and off road since those pics above. The quickfists are still doing their job perfectly and have been in use for about 7 years.
We fill using the hookup box on the side of the van(same hookup box is also the outlet for showers/outdoor water depending on the direction the switch is flipped)
Winter is the only downside to this setup, but I have another one that is now fully insulated and ready to roll with hot water but haven’t gotten to use it yet. _________________ North American Hightop Installer/Distributor
Current stock (5)
Hot Water Systems
