DeadSetMonkey Samba Member
Joined: April 15, 2010 Posts: 532 Location: Denver, CO
Posted: Sat Dec 21, 2019 5:41 pm Post subject: Battery Post Bolt trouble |
Today I messed up.
I wanted to add an eyelet connector to those already attached to the POS terminal in my 1990 Westy. Simple enough, unless you cross thread the bolt the eyelets are held by
Anyone know where I can get a new bolt?
See photo. Stripped bolt was in large square end.
_________________ ----------------------------------------------------
'90 Syncro Westy 2.5Subi Turbo, BFGs 215/75/15 Rheins |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9940 Location: Orbiting San Diego
Posted: Sat Dec 21, 2019 6:13 pm Post subject: Re: Battery Post Bolt trouble |
It looks to be no longer available but,
VW part number N0174071
Mark |
Posted: Sun Dec 22, 2019 10:39 am Post subject: Re: Battery Post Bolt trouble |
Any ideas about best plan for my problem?
Do not want construct a new battery terminal, with a new distributor terminal.
Maybe an extender? If there is room? like this:
https://www.amazon.com/gp/product/B000CQBNJ4/ref=ask_ql_qh_dp_hza
Or maybe I upsize the ring terminals to simply slide onto the current bolt?
Or maybe I find a shop to drill it out and re-tap it? _________________ ----------------------------------------------------
Abscate Samba Member
Posted: Sun Dec 22, 2019 11:12 am Post subject: Re: Battery Post Bolt trouble |
Put a Dremel onto your Christmas wish list and take care of this your self
The Dremel will cost less than the shop, and you will learn how to fish forever _________________ .ssS! |
Posted: Sun Dec 22, 2019 11:35 am Post subject: Re: Battery Post Bolt trouble |
I'd guess a 15 minute fix. Clamp in a vise. Drill it out from the other side so it unscrews as it is drilled. Try cleaning up the threads from the back side with an M6 tap. If not good enough, tap it oversize to 1/4-28, or M7 if needed.
Send it to me if you can't find another way. I'll fix it or send another in it's place.
Mark |
jlrftype7 Samba Member
Posted: Mon Dec 23, 2019 1:57 pm Post subject: Re: Battery Post Bolt trouble |
I went a different way courtesy of someone here posting about MIL-Spec battery terminals as a replacement kit for stock ones that are worn, loose, or in my case, had split in half and was luckily still hanging onto the Negative Battery Post enough for my Vanagon to keep running.
I bought mine off Amazon, both Negative and Positive. I'll try to post a link in a bit, very beefy and they allow you to add eyelets/wires easy enough. Comes with protective boots for the cable ends as well and eyelets to crimp onto your stock cables once you remove the old terminal ends.
In my case, I was replacing the entire Ground cable with new, and will shortly replace the Hot/Battery cable and install that new terminal as well.
Fastronix Military Spec Battery Terminal Top Post Kit https://www.amazon.com/dp/B00X36RILW/ref=cm_sw_r_cp_api_i_p7saEb1S5YDS5
_________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Dec 24, 2019 7:22 am Post subject: Re: Battery Post Bolt trouble |
D@mn . . . those ^^^ look absolutely bombproof...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
GreggK Samba Member
Joined: May 17, 2008 Posts: 898 Location: Colorado/Philidelphia
Posted: Tue Dec 24, 2019 1:00 pm Post subject: Re: Battery Post Bolt trouble |
If you don't have any luck PM me your address and I'll send you one. I've got some extras.
GreggK Samba Member
Posted: Tue Dec 24, 2019 1:05 pm Post subject: Re: Battery Post Bolt trouble |
Hey rmcd I like what you did. Did you just cut off the connector from the battery to starter cable and crimp on the new connector?
They way mine is now, I can't shut the battery compartment lid anymore. |
Zeitgeist 13 Samba Member
Posted: Tue Dec 24, 2019 1:27 pm Post subject: Re: Battery Post Bolt trouble |
Here's another battery clamp failure mode:
That was on the underside, so it wasn't very obvious _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
rmcd Samba Member
Posted: Tue Dec 24, 2019 5:46 pm Post subject: Re: Battery Post Bolt trouble |
GreggK wrote: |
Basically yes. I probably should have replaced the a couple of the oem cables but given all the other stuff just decided to solder/crimp new terminals where possible. I also had new cables to connect to house battery, small car AC, and new ground cable. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
GreggK Samba Member
Posted: Tue Dec 24, 2019 9:02 pm Post subject: Re: Battery Post Bolt trouble |
I like that battery your using rmdc. I really like the fold down handles but it shows that it will not fit an '86 Vanagon when I look it up. Looks fine in your van, did you have to do anything to make it fit. Thanks, GreggK |
uberaudi Samba Member
Joined: June 24, 2013 Posts: 503 Location: Hi-top Country
Posted: Tue Dec 24, 2019 11:01 pm Post subject: Re: Battery Post Bolt trouble |
Battery terminals always seem to be wildly neglected, at least on all the POS' I buy, ha! I do as others above have done though, and use the military style terminals. They work anywhere and are easily adaptable to suit your needs. On some installs, I've even used bicycle seatpost skewers as the quick release mechanism. A nice option if you find yourself undoing terminals frequently. |
rmcd Samba Member
Posted: Wed Dec 25, 2019 11:51 am Post subject: Re: Battery Post Bolt trouble |
GreggK wrote: |
It doesn’t fit with modifying the cover hinge and notching the seat frame. Not super crazy or difficult. I will eventually notch more of each as I don’t like the cables being so close.
Tomorrow I can take more pictures at a different angle if want. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
GreggK Samba Member
Posted: Wed Dec 25, 2019 4:28 pm Post subject: Re: Battery Post Bolt trouble |
Sure rmcd show some more pictures. I'm getting ready to replace my battery and set up my AUX battery as well. I've been struggling on the cold morning starts with my recently added diesel motor so I thought something with higher CC amps than the 41 series might help. Thanks! |
Posted: Wed Dec 25, 2019 7:33 pm Post subject: Re: Battery Post Bolt trouble |
What would be nice is a sturdy plastic cover for the battery box. Something that locked into place well and that could withstand substantial abuse. The cover should give decent clearance for typical the H6 battery and of course work with all factory seats. |
rmcd Samba Member
Posted: Thu Dec 26, 2019 9:59 pm Post subject: Re: Battery Post Bolt trouble |
I trimmed the hinge and bent it up at a 45’ angle to widen the opening.
I trimmed down the cover plate To accommodate the new swivel. I glued and riveted a piece of 1/8” plastic to the underside.
Then I reinstalled the modified cover with new rivets in the hinge.
Hope this helps. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1488 Location: Wisconsin
Posted: Thu Dec 26, 2019 10:36 pm Post subject: Re: Battery Post Bolt trouble |
Wildthings wrote: |
What would be nice is a sturdy plastic cover for the battery box. ... The cover should give decent clearance for typical the H6 battery and of course work with all factory seats. |
Not especially sturdy, but an effective light-duty way of providing some coverage/protection of a Group 41 battery and connections. Made from a simple hanging file folder tote.
_________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com |
