hansie Samba Member
Joined: August 29, 2007 Posts: 476 Location: Beach Lake, PA
Posted: Sat Dec 21, 2019 7:43 pm Post subject: Installing a Subaru into a Auto Bus |
Installing a Subaru into a Auto Bus using a .003 trans. I need information on the swap , please. Any help Please.
Thanks Karl _________________ Karl Bower |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Sat Dec 21, 2019 8:03 pm Post subject: Re: Installing a Subaru into a Auto Bus |
it's a steep learning curve for a successful swap. the info is out there, just search a bit and see what you feel comfortable with. you are going to want to get that trans re-geared...Subaru's don't like being strung out at 4k+ on the highway.
search my name, I've done a bunch _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
hansie Samba Member
Posted: Sat Dec 21, 2019 8:19 pm Post subject: Re: Installing a Subaru into a Auto Bus |
Thanks Skills _________________ Karl Bower |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Sun Dec 22, 2019 11:01 am Post subject: Re: Installing a Subaru into a Auto Bus |
I helped a gentleman restore and convert a 78 riviera automatic. We put in a 2.2 from a 2000 outback. Used a kennedy engineering adapter. Small car did the wiring harness. I had a custom radiator built that just fits up in between the frame rails ( air ducts removed), the ports are one on each side pointing rearward. Used the suby fans on the bottom pulling air down. I made a shroud but we never used it as temps were good. I used marine grade rubber coolant lines to the engine. Used vanagon coolant tanks ( if doing it again probly go rmw tank). Once we turned our attention to the trans for a reseal we found his ring and pinion were toast. I cant believe how bad they were, that trans had to have been just screaming! Luckily for him I had an 87 auto parts vanagon. We resealed it and put it in. Had to change the front mount and removed the oil cooler looping it temporarily for a remote cooler later. It was nice to drive. I only drove it at highway speeds a bit during the month i drove it while finishing the interior. 18 miles to town half of which is on the highway, 55mph speed limit. Average temps 195. Im sure skilz is right about gearing, actually we never even checked the gearing in that trans as it was our best option at the time. Sadly that gentleman died before getting to enjoy the van. His widow now is starting to drive it in the summer, I go and give the van spring check up for her. Her brother visited from outside last summer, he's a mechanic. He took it for a road trip and said its great to drive. |
danfromsyr Samba Member
Posted: Sun Dec 22, 2019 11:37 am Post subject: Re: Installing a Subaru into a Auto Bus |
there are ALOT of vanagon automatics running around on stock gearing with engine conversions. the Subie is 'mostly' just fine with the RPMs of the 010.
you can get different R&P sets for the 1976-1991 010 automatic. I don't know if that also fit the 73-75 003. but you can get a T-III 003 with a higher R&P ratio.
you can make some adjustment with larger diameter tires. but not really a huge rpm drop like a R&P swap.
https://countryhomescampers.com/product-tag/automatic-transmission/ |
mike77777 Samba Member
Joined: May 13, 2009 Posts: 119 Location: portland or
Posted: Sun Dec 22, 2019 5:37 pm Post subject: Re: Installing a Subaru into a Auto Bus |
lived up by Epperson knob fr around 15 years. Remember a garage called "Wendys VW' right up the street from the NAPA in Homer. Mechanic named Jeff , from Cali. Real tough country on vehicles. Plenty of Subys around homer. _________________ patience and putty |
chittychittybangbang Samba Member
Joined: August 12, 2006 Posts: 194 Location: portland, or
Posted: Sun Dec 22, 2019 7:07 pm Post subject: Re: Installing a Subaru into a Auto Bus |
skills@eurocarsplus wrote: |
search my name, I've done a bunch |
Not true, I've owned a 1.6 EA71 and a 2.5 EJ251, ran them both at 3-4k on long road trips, the things are indestructible! They do get much better gas mileage at lower RPM's.
Also, what happened to people doing Corvair swaps? _________________ If your into busses youve got issues and you likely don´t know it yet. - El_Güero
The question of whether the resulting usage is "correct" or "incorrect" depends on one's notion of correctness. |
Posted: Sun Dec 22, 2019 7:48 pm Post subject: Re: Installing a Subaru into a Auto Bus |
chittychittybangbang wrote: |
Not true |
ok
there is a reason why Subaru's cruise at 3-3200 rpms @70. i'm not going to get into the argument this will eventually wind up in because this is where all the back yard guys that throw junk together that looks like this
Quote: |
DSC_0828 by jaycanode, on Flickr
DSC_0821 by jaycanode, on Flickr
DSC_0818 by jaycanode, on Flickr
DSC_0825 by jaycanode, on Flickr
DSC_0823 by jaycanode, on Flickr
[/img]http://www.flickr.com/photos/terravision/8926001841/[img]
In the above photos you can see the Saab 900 pressurized coolant expansion tank. This piece is vital for self burbing sytems. I pressurized this tank and forced coolant into the system for initial coolant bleeding. Note also the Fuel Injection "return" line penetrating firewall. This line goes into the stock VW "vent" gas line. Also note relocated igniter/coil to firewall.
DSC_0827 by jaycanode, on Flickr
The above spaghetti mess shows Walbro FI pump and stock Suby fuel filter. All emissions and evap stuff were removed. (I live in rural CO...no smog check) Also tapped into stock VW alternator circuitry here.
DSC_0815 by jaycanode, on Flickr
Pic above illustrates my Radiator setup. Crude and functional would be an appropriate description here. My radiator "cage" doubles as a very functional double bicycle rack. Coolant lines are 1 1/4" inch SS and follow much the same route as stock VW heater vents did. Radiator is a double row VW sirocco style radiator.
DSC_0817 by jaycanode, on Flickr
DSC_0837 by jaycanode, on Flickr
Above you can see those coolant lines as well as the retrofitted JC whitney style heater installed in the cab. The heater works great!
DSC_0835 by jaycanode, on Flickr
Above is the CPU "nest" below the sleeping area. Firewall is just behind it. This by far was the most daunting aspect of the conversion. Hours of internet research, diagrams, etc...Should I have just sent the harness out to Tom Shiels in Canada? Maybe, although my friend Chris Myles did a great job sorting and weeding! But heck if I didn't get a masters degree in Subaru electronics during this process! I also had to provide a vehicle speed sensor solution to make this engine happy. I first tried the SamllCar bolt on but it never worked correctly and then, because of its exposed position on the axle, was destroyed by a tumbleweed (Yes a tumbleweed) I ran over. I then opted for a VSS simulator provided by Enginewiring.com. (Works perfect!)
DSC_0833 by jaycanode, on Flickr
Currently 4000 rpm will get me about 65 MPH. My goal would be 75 MPH at 3500. I know, I know, buses should not break the 70 MPH barrier, but its nice to have this option. As you all know NO ONE likes to be behind a VW bus, its like an inferiority complex or something. It is soooo fun to leave tailgaters in the dust now, mouths agape. I feel I can't help myself given the importunity.
this is what the typical swapper ends up with. looks great, huh? I stand by my statement that subarus don't like to be strung out. it's all in the combination. I have a LOT of converted bays running around... _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Dec 22, 2019 8:42 pm Post subject: Re: Installing a Subaru into a Auto Bus |
really the DIY/junkyard swap quality has nothing to do with running rpms as much as just running. you're just poking fun at the lesser mechanically and financially qualified..
and if it runs/ran in that DIY 4th grade arrangement for any length of time or miles straight it's a TESTAMENT to how well the subaru runs and is adaptive.
most who lack the money or skills are over achievers in ambition
there's no and never will be a question to your skillset and level of quality.. but it's a small % of subie swaps in vanagons running around regeared..
as mentioned the vanagon AT has the same stock R&P as the 76-79bay AT.
and actually the same/similar as the 76-79 bay 4spd.
higher rpms can/will lead to increased oil consumption in some/maybe all subaru boxer motors.. I know some years were more of an oil issue from the factory in the cars even when new..
upgraded R&P solutions are available in 76-91 automatic and all years 4spd. I'm still not aware if the 73-75 AT can take the R&P upgrade. |
Posted: Sun Dec 22, 2019 9:16 pm Post subject: Re: Installing a Subaru into a Auto Bus |
i'm not making fun of anyone. the o/p and I spoke. I want him to succeed.
running a Subaru at 4k+ isn't doing them any favors...in wear, oil consumption and cooling.
go take an outback on the highway at 4k and map the coolant temp. I did. it wasn't pretty.
the vanagon can get away with that to a point...as it holds 87 gallons of coolant...so it masks the issues.
when posts go the way this one is heading, people wonder why i'm tight lipped about how I do what I do. I am willing to bet I spent more time money and effort into reverse engineering these to survive long term in a vehicle that had no cooling system, let alone gearing that matches that of the donor.
people get away with this shit all the time...I get it. but the vast majority come back an ask why they have this or that issue at the end of it.... when it's "too late" and they don't have the $$ for a re gear. even DIY is an ez 7-10k these days...
so...if you want to putt around on stock gearing...go for it. the timing components barely make it to the spec'd intervals anyway....the cogged idler sounds like grit at 100k....so 1/2 all of your service intervals if you want to keep one of these on boil all the time.
it all depends on the expectations of the swapper. this guy just about nailed it in my opinion
from his thread:
Vee Dub Nut wrote: |
No derail.. all good info. My trans was essentially free since I flipped a Bus in the process and swapped my stock trans for its re-geared 091. For the engine side, I bought a few things (engine hanger, oil pan, TB reverser, and header), but DIY'ed everything else. I did however do the new short block thing, so my engine swap all in was ~8.5k (not counting the duplicate cooling system parts I've purchased honing in on my final setup). |
so he had 8500 plus cooling system #2 and did horse trading for a reworked trans...because he found out the gearing sucked.
just putting it out there so the o/p has all the info before he gets balls deep and has to go backwards. sorry for calling it the way I see it.... _________________
Jake Raby wrote: |
Brian wrote: |
XXX/Rx/RnR Samba Member
Joined: March 01, 2008 Posts: 405 Location: valley of the sun
Posted: Mon Dec 23, 2019 3:45 am Post subject: Re: Installing a Subaru into a Auto Bus |
Your ATF will boil without a ATF cooler. When vanagons water cooled came out VW added a cooler to the auto box for a reason. I found a 090 and done the Audi upgrade cause my 010 was cooked after my first long trip with the Ecotec. Fan and T-stat on a big cooler that added almost 2 qts of fluid. More info in the Vanagon forum on automatics and Subi's. _________________ 78' westy, 2.4 195hp ecotec, audi turbo a/t, a\c, 2 1/2" lift spindles, index rear, 930 cv's & axles, 225x65x17 BFGs ## 77' hardtop 2.0 T-4 duel 44 weber's, 225x50x17s ## 74' baha bug |
Posted: Tue Dec 24, 2019 9:29 am Post subject: Re: Installing a Subaru into a Auto Bus |
mike77777 wrote: |
lived up by Epperson knob fr around 15 years. Remember a garage called "Wendys VW' right up the street from the NAPA in Homer. Mechanic named Jeff , from Cali. Real tough country on vehicles. Plenty of Subys around homer. |
I'm very close to there. I built a kitchen for one of the Eppersons in Anchor point. The N.F. is tough on cars, I know. Beautiful inlet view though. |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Tue Dec 24, 2019 9:49 am Post subject: Re: Installing a Subaru into a Auto Bus |
skills- 87 gallons of coolant? is that a fat-finger or exaggeration? It cant really hold 87 gallons! |
Posted: Tue Dec 24, 2019 10:11 am Post subject: Re: Installing a Subaru into a Auto Bus |
alman72 wrote: |
yes, exaggeration for sure. point being when you have a vehicle like a vanagon with 2x heater cores, piping that runs front to rear and a pretty large front mounted radiator cooling issues can be masked. a stock Subaru (car) holds just under 2 gallons from a dead empty fill.
remember the game excitebike? you could push the bike harder (more rpm's) and it would overheat.
every car on the planet has a "operating range" in terms of RPM's. same holds true with conversions. I kind of knew this going into my bus and opted for a 091 out of the gate, which led me to clutch and try to find 5th...which obviously wasn't there. proving that no stock bus trans is ideal in the gearing department
what works for an air-cooled spinning at 4500 doesn't work for many watercooled engines. when I did my swap, I learned a LOT about cooling strategies and how to find that balance.
one of the things I was able to get schooled on was nascar cooling. these engines run flat out at 7-9k for 4-500 miles depending on the race. old technology was restrictor plates in place of a thermostat and modern tech affords the luxury of PWM electric water pumps.
so, it's all in the combination. I try to advise the DIY'er as best as I can...I made all of the mistakes they are about to make. _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Dec 24, 2019 12:06 pm Post subject: Re: Installing a Subaru into a Auto Bus |
so a skills subie conversion is all B button with no side of the track timeouts. |
Gregg in the 603 Samba Member
Joined: April 13, 2013 Posts: 404 Location: New Hampshire, USA
Posted: Tue Dec 24, 2019 1:12 pm Post subject: Re: Installing a Subaru into a Auto Bus |
Excitebike was awesome _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Posted: Tue Dec 24, 2019 2:14 pm Post subject: Re: Installing a Subaru into a Auto Bus |
alman72 wrote: |
more like Up, Up, Down, Down, Left, Right, Left, Right, B, A, Start _________________
Jake Raby wrote: |
Brian wrote: |
