gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Sat Dec 21, 2019 9:04 pm Post subject: Differences between '49 and '50 cases |
I've noticed that the '49 case I'm planning on using is missing an important feature. I believe this feature was added in 1950. If you look at the picture below there's a little notch that allows oil poured down the generator stand to flow from the front of the case to the rear.
When oil is poured into my '49 case, it's deposited into the rear of the case. Moreover, this notch isn't present. Hmmmm. Should I notch my '49 case so oil flows freely between the front and rear sections?
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
kalymnos Samba Member
Joined: January 22, 2010 Posts: 112 Location: Hamburg/Germany
Posted: Sun Dec 22, 2019 4:42 am Post subject: Re: Differences between '49 and '50 cases |
Here is the situation in my case from 8.1950.
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 878 Location: Lanark County, Ontario, Canada
Posted: Sun Dec 22, 2019 10:18 am Post subject: Re: Differences between '49 and '50 cases |
PR entry reads: Jan 1950, from chassis 1-0138765, unit # 170086:
Crankcase: "Now: Oil can be completely drained off (passage through timing gear chamber)" _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
Bengt H Samba Member
Joined: September 11, 2005 Posts: 332 Location: Sweden
Posted: Sun Dec 22, 2019 1:26 pm Post subject: Re: Differences between '49 and '50 cases |
I have notched my 49 case, then you can use all oil in the engine. |
