Carb jetting? Car runs rough
Page: 1, 2, 3, 4  Next
txasylum
txasylum is offline
PostPosted: Mon Dec 23, 2019 4:18 pm    Post subject: Carb jetting? Car runs rough Reply with quote
I have a 61 completely stock, 1200cc motor with a 28PICT carb (not the 28PICT1). When I start the car and the choke is on the car idles and rev's up nicely, but as soon as the automatic choke kicks off it sounds like it is maybe misfiring (NOT positive not this), however, if I hit the throttle quickly it kinda sputters a bit before it revs up. If I slowly give it throttle it will Rev up.
The carb was cleaned, vacuum working, so I don't think there is a problem there.
I'm wondering if I should try a different main jet. Would that be the problem? What size jets should go on this carb?
Thanks
Eric&Barb
Eric&Barb is online now
PostPosted: Mon Dec 23, 2019 6:00 pm    Post subject: Re: Carb jetting? Car runs rough Reply with quote
Does the accelerator jet/nozzle spray properly or kind of dribble when the throttle arm on the carb is pulled back??
In Stereo, Where Available!
txasylum
txasylum is offline
PostPosted: Mon Dec 23, 2019 6:10 pm    Post subject: Re: Carb jetting? Car runs rough Reply with quote
Yes, I can see gas squirting in when I pull the throttle back.
It currently has the 55 jet in the carb. I tried a 60 and a 65, but there was no difference. As soon as I step on the pedal, it stutters until it hits a higher RPM. Once it gets to a high RPM it runs great. Only problem is on the lower RPMs.
Eric&Barb
PostPosted: Mon Dec 23, 2019 6:54 pm    Post subject: Re: Carb jetting? Car runs rough Reply with quote
Is the accelerator jet/nozzle aimed so it sprays between the throttle butterfly and carb throat wall, when that valve opens up?
Eric&Barb
PostPosted: Mon Dec 23, 2019 7:03 pm    Post subject: Re: Carb jetting? Car runs rough Reply with quote
Which jet?? Guessing the pilot/idle jet, and that one only affect the idle, not the just above idle.
Accelerator jet/nozzle is supposed to inject fuel in the small RPM range when going from idle to main jet.
Main jet has more to with how much power you have once you stop pressing the pedal down anymore.
Air correction jet is supposed to at higher RPMs to lean out the flow of fuel from the main jet, by letting air bubble into the main jet fuel flow.
txasylum
txasylum is offline
PostPosted: Mon Dec 23, 2019 7:10 pm    Post subject: Re: Carb jetting? Car runs rough Reply with quote
It looks to be in the correct location. I looked at another carb I have. Here is sa picture.
txasylum
txasylum is offline
PostPosted: Mon Dec 23, 2019 7:12 pm    Post subject: Re: Carb jetting? Car runs rough Reply with quote
So should I adjust the accelerator jet? I just read a manual on 28PICT. Doesn't look like the accelerator pump is adjustable.
Eric&Barb
PostPosted: Mon Dec 23, 2019 9:58 pm    Post subject: Re: Carb jetting? Car runs rough Reply with quote
Location does not matter, it matters if the squirt of fuel goes down the slightly open throttle valve.
That early of carb has no accelerator pump adjustment.
thomas.
thomas. is offline
PostPosted: Tue Dec 24, 2019 3:24 am    Post subject: Re: Carb jetting? Car runs rough Reply with quote
You might need to adjust the choke some now that the weather has gotten colder.
txasylum
txasylum is offline
PostPosted: Tue Dec 24, 2019 5:09 am    Post subject: Re: Carb jetting? Car runs rough Reply with quote
That's the question. How do I adjust it? What do I adjust.
andk5591
andk5591 is offline
PostPosted: Tue Dec 24, 2019 5:35 am    Post subject: Re: Carb jetting? Car runs rough Reply with quote
You loosen the 3 screws holding the choke element and rotate it slightly (mark your initial position) so that is stays open longer. Here is the question though - once the car fully warms up (like after 5 or 6 minutes) is it the same or does it improve? If it is fine after fully warming, then yeah, adjust choke. If not, I suspect you still have crap in the carb.
BTW, is this a new problem or is the car new to you?
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
txasylum
txasylum is offline
PostPosted: Tue Dec 24, 2019 6:02 am    Post subject: Re: Carb jetting? Car runs rough Reply with quote
It gets worse as the choke shuts off. I bought this car a few weeks ago and it came with this problem. I did take carb off and cleaned it.
txasylum
txasylum is offline
PostPosted: Tue Dec 24, 2019 8:13 am    Post subject: Re: Carb jetting? Car runs rough Reply with quote
Making progress. Took the carb off again inspecting and cleaning. Found the accelerator pump was blowing bubbles around the gasket. put another on there and it seems to have helped the problem. Not as bad. Going to adjust carb a bit more, maybe new plugs, points, condenser. Hope that solves it all.
Eric&Barb
PostPosted: Tue Dec 24, 2019 9:26 am    Post subject: Re: Carb jetting? Car runs rough Reply with quote
While you had the carb off, did you check if the accelerator jet shoots thru the throttle valve as it just opens?
txasylum
txasylum is offline
PostPosted: Tue Dec 24, 2019 9:32 am    Post subject: Re: Carb jetting? Car runs rough Reply with quote
Yes, I cleaned it up and made sure it was squirting fuel into the carb.
Eric&Barb
PostPosted: Tue Dec 24, 2019 9:48 am    Post subject: Re: Carb jetting? Car runs rough Reply with quote
Good, but is it AIMED properly???
txasylum
txasylum is offline
PostPosted: Tue Dec 24, 2019 10:20 am    Post subject: Re: Carb jetting? Car runs rough Reply with quote
I believe so. As it opens it should shoot down the tube, right? I'll have to verify that.
Eric&Barb
PostPosted: Tue Dec 24, 2019 10:36 am    Post subject: Re: Carb jetting? Car runs rough Reply with quote
It should shoot out the jet and down the throat of the carb. At the very bottom of the carb there is a butterfly valve that is just opening when you start pulling the throttle arm back by hand. That accelerator nozzle spray needs to hit right at that opening JUST as it opens. Not spraying on the side of the carb throat wall, not on top of that butterfly valve, or anywhere else.
txasylum
txasylum is offline
PostPosted: Tue Dec 24, 2019 11:01 am    Post subject: Re: Carb jetting? Car runs rough Reply with quote
It does seem to be doing what you described.
txasylum
txasylum is offline
PostPosted: Tue Dec 24, 2019 5:36 pm    Post subject: Re: Carb jetting? Car runs rough Reply with quote
Just when I thought it was starting to run better, well that was sitting in the garage. I just drove it down the driveway. Coming back up it I couldn't get it to run in second gear without a lot of sputtering. One thing I noticed as it sat running in the garage is that the intake frosts up. I'm not sure that has anything to do with it. Runs great when it is cold and choke is on. Once warmed up and choke kicks off is when goes downhill.
Page 1 of 4
