missmybus Samba Member
Joined: April 03, 2013 Posts: 118 Location: Mission Viejo, CA
Posted: Mon Dec 23, 2019 8:50 pm Post subject: Broken wing window post, what to do?! |
Broke my wing window post on both of them! They we very rusty and soaked in PB blaster, but still snapped when I tried removing the nut. Any suggestions to fix? Without replacing the whole frame. Thanks, Brian
_________________ 64 Deluxe |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Mon Dec 23, 2019 9:35 pm Post subject: Re: Broken wing window post, what to do?! |
The wing window as a hole is available. I’d go with that instead of sourcing a frame and swapping the glass into it. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Tue Dec 24, 2019 5:34 am Post subject: Re: Broken wing window post, what to do?! |
pyrOman wrote: |
The wing window as a hole is available. I’d go with that instead of sourcing a frame and swapping the glass into it. |
Yep, considered that _________________ 64 Deluxe |
NUTSFORBUSES Samba Member
Joined: December 08, 2016 Posts: 560 Location: I don't recognize it anymore
Posted: Tue Dec 24, 2019 6:29 am Post subject: Re: Broken wing window post, what to do?! |
If it were me, I would buy a bolt, cut up to the base, Braze & flatten sides. Braze not weld _________________ kaiser kills kids.com |
Posted: Tue Dec 24, 2019 7:13 am Post subject: Re: Broken wing window post, what to do?! |
NUTSFORBUSES wrote: |
If it were me, I would buy a bolt, cut up to the base, Braze & flatten sides. Braze not weld |
Thanks, was thinking the same thing. Braze, not weld, got it. Thanks man! _________________ 64 Deluxe |
Posted: Tue Dec 24, 2019 10:00 am Post subject: Re: Broken wing window post, what to do?! |
Hows your window frames? I have 3 full sets w glass San Clemente _________________ kaiser kills kids.com |
Posted: Tue Dec 24, 2019 10:10 am Post subject: Re: Broken wing window post, what to do?! |
Hows your window frames? I have 3 full sets w glass San Clemente |
The frame is in great shape and was painted when I had the bus painted and I have the original glass, only broke the post😩 _________________ 64 Deluxe |
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Tue Dec 24, 2019 10:11 am Post subject: Re: Broken wing window post, what to do?! |
I once tapped the threads further up the post, and shortened the spring. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
Posted: Tue Dec 24, 2019 10:45 am Post subject: Re: Broken wing window post, what to do?! |
Creative engineering makes a great alternative to the "WING" rubber. Glue it on let dry then install (with the Swoosh of course) no cutting it down.
If you decide to braze a thread on the wing, Bevel the hell out of it so you can grind it down to "Fit" correctly _________________ kaiser kills kids.com |
Posted: Tue Dec 24, 2019 12:57 pm Post subject: Re: Broken wing window post, what to do?! |
Culito wrote: |
I once tapped the threads further up the post, and shortened the spring. |
yes, just spoke to a friend on the phone and he suggested the same thing! Will give it a try👍 _________________ 64 Deluxe |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Next time you find nuts that stuck, either get a nut splitter or use a hammer and chisel to do the same, but you need the nut against a hard place like an anvil to chisel it. _________________ In Stereo, Where Available!
Posted: Tue Dec 24, 2019 12:58 pm Post subject: Re: Broken wing window post, what to do?! |
Eric&Barb wrote: |
Next time you find nuts that stuck, either get a nut splitter or use a hammer and chisel to do the same, but you need the nut against a hard place to chisel it. |
Great advice! Thanks! _________________ 64 Deluxe |
Posted: Tue Dec 24, 2019 1:15 pm Post subject: Re: Broken wing window post, what to do?! |
missmybus wrote: |
Great advice! Thanks! |
No problem. You can also use heat to loosen up nuts, bolts, studs. Welding and then cooling by pouring water works really well. Vibration can help when applying penetrating oil, then use a smaller hammer to rap on it for a few minutes each time before you apply the oil. In this particular spot, would have held a hammer to the backside of the nut away from you and with other hand rapped on the side closer to you. Rust is brittle and does not like physical or thermal shock. To do so results in the rust being broken up from a hard expanded plating (that makes the nut a pressed on fit) into dust.
Most of all you need to get a hand feel experience for how much torque to apply. If you are putting 30 Ft. Lbs. on a bolt/stud that is rated for only 20 Ft. Lbs, you are going to just break stuff like that.
Lastly if you have to loosen something like this up without splitting the nut, especially if you do not have the tools or time to wait for at least penetrating oil to seep in. Try tightening the nut FIRST ever so slightly (this helps to CRUSH the rust plating into dust in the threads), then loosen ever so slightly. Keep repeating this tightening/loosening till you feel the nut actually shift ever so slightly. Then apply more oil and little by little work the nut looser and retighten a little more looser each time. The shifting of the nut will help to get the oil down in the dry threads that would otherwise gall/weld the nut to the male threads. _________________ In Stereo, Where Available! |
Posted: Tue Dec 24, 2019 1:41 pm Post subject: Re: Broken wing window post, what to do?! |
Do invest in a good anti-seize, especially for exhaust fasteners. You can use old used grease on most anything else, but anti-seize is better. That way if using one of those you have a good chance in 10 or even 20 years from now of just being able to undo a fastener that the grease or anti-seize has kept the rust away from the threads. _________________ In Stereo, Where Available! |
Posted: Tue Dec 24, 2019 5:38 pm Post subject: Re: Broken wing window post, what to do?! |
If you decide to braze a thread on the wing, Bevel the hell out of it so you can grind it down to "Fit" correctly |
👍🏼 _________________ 64 Deluxe |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Tue Dec 24, 2019 7:53 pm Post subject: Re: Broken wing window post, what to do?! |
Why braze and not weld? _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Wed Dec 25, 2019 5:43 pm Post subject: Re: Broken wing window post, what to do?! |
Eric&Barb wrote: |
Do invest in a good anti-seize, especially for exhaust fasteners. You can use old used grease on most anything else, but anti-seize is better. That way if using one of those you have a good chance in 10 or even 20 years from now of just being able to undo a fastener that the grease or anti-seize has kept the rust away from the threads. |
Again, more great advice! Merry Christmas! _________________ 64 Deluxe |
Posted: Wed Dec 25, 2019 5:59 pm Post subject: Re: Broken wing window post, what to do?! |
missmybus wrote: |
Merry Christmas! |
Back at you! _________________ In Stereo, Where Available! |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Thu Dec 26, 2019 10:17 am Post subject: Re: Broken wing window post, what to do?! |
Riff Raff wrote: |
Why braze and not weld? |
This is really not a good application for brazing. Brazing is used when you have a fitted joint and the brass can be drawn in by capillary action.
Welding would be a superior choice here. O-A, MIG or TIG. Taper the ends to a near point, weld then grind. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Thu Dec 26, 2019 11:07 am Post subject: Re: Broken wing window post, what to do?! |
Bulli Klinik wrote: |
Riff Raff wrote: |
Welding would be a superior choice here. O-A, MIG or TIG. Taper the ends to a near point, weld then grind. |
That is what I was thinking too, similar to a repair I did on a split bus clutch pedal years ago, since finding a replacement can be a PITA. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
