Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1961 Location: Manitowoc, WI
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Mon Jan 04, 2021 8:48 pm Post subject: Re: ‘65 TOURIST PASS Beetle build |
ok yeah that looks better
started preparing a drum for paint
left these to soak
ive honestly given up at this point on the petals. i drilled the bushing like 4 times large than the original hole. applied pb blaster. heat. a puller. its not comming apart. time for a new one lol _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Tue Jan 05, 2021 5:08 pm Post subject: Re: ‘65 TOURIST PASS Beetle build |
Yeah I actually got the clutch and brake pedal to rotate round the shaft bug when it boils down to actually removing the pedals it's just not gonna happen.
Heres 17 dollars worth the wire wheels for the grinder. These are 5/8 in. Cheapest of the cheap. When I was shopping I saw some for like 80 bucks a chip.
The whole chassis has been taken down to bare metal. There are a few small corners I will have to get to by hand and sand paper but over all the wire wheels and grinder worked excellent!
Ugh, more touch up work to be done now.
'66 RIP
'69 RIP
Posted: Wed Jan 06, 2021 7:43 pm Post subject: Re: ‘65 TOURIST PASS Beetle build |
ok so i started sanding the corners i couldnt get to with 80 grit todat. that and i started straightning out the rear pan lip. had the clamp fall a foot and a half and whack me in the temple tho. dont worry, i didnt cry
this tool(whatever it is) worked well for getting the beginnings straight. but a flat edge and hammer were needed for final work. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Jan 06, 2021 8:14 pm Post subject: Re: ‘65 TOURIST PASS Beetle build |
HF has a cheap hammer and dolly set. Since there is no brute force or moving parts, it works just fine.
Make sure to hide the hammers from your wife so she doesn't use one to drive nails. |
Posted: Wed Jan 06, 2021 8:36 pm Post subject: Re: ‘65 TOURIST PASS Beetle build |
i'll note that for my future wife
unfortunately, i own most of the basic body working tools except the fenders/dollies! i have a few body working hammers if that what their called, which is what i used. but i will order some here within the next day or two. Thanks! _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Wed Jan 06, 2021 9:28 pm Post subject: Re: ‘65 TOURIST PASS Beetle build |
The dollies make the hammers work. It's actually kinda therapeutic massaging the metal back to how it's supposed to be.
But just be careful what you hit with them. The hammer faces are much softer than a standard hammer. Hence all the divots in my square head body hammer from the nail heads! |
Adriel Rowley Samba Member
Joined: October 12, 2006 Posts: 4748 Location: Mesa, Arizona
Posted: Wed Jan 06, 2021 11:22 pm Post subject: Re: ‘65 TOURIST PASS Beetle build |
I am as much a professional body man as I am a professional golfer. I don't think a better set of dollies would give me much better results akin to a better set of golf clubs would bring my handicap into a decent range.
However, I have been pretty pleased with the results I have been able to get without any training with my cheap-o HF set. Plenty good enough for a hack like me! |
AutoMechanic Samba Member
Joined: December 28, 2019 Posts: 483 Location: Roanoke Virginia
Posted: Wed Jan 06, 2021 11:43 pm Post subject: Re: ‘65 TOURIST PASS Beetle build |
Coming along nicely. I am not a fan of body work to me it’s boring but got to be done so I will be tackling that when it gets warm. My main focus right now is getting it running. |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Thu Jan 07, 2021 10:54 am Post subject: Re: ‘65 TOURIST PASS Beetle build |
oh yeah. i use goggles, ear muffs, and gloves. no long sleeves either. had one wrap itself between my sock an my ankle. not fun. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Thu Jan 07, 2021 11:49 am Post subject: Re: ‘65 TOURIST PASS Beetle build |
Chickensoup I need you to put those wire wheels and stuff away and get busy on that LED headlight you promised to build for us. |
Posted: Thu Jan 07, 2021 12:12 pm Post subject: Re: ‘65 TOURIST PASS Beetle build |
Big Bill wrote: |
Wait a second now im building them for you guys? For FREE??
I should have time tonight. im praying to god the bracket is a standard oval. otherwise its gonna take more work for the plastic version. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Thu Jan 07, 2021 4:48 pm Post subject: Re: ‘65 TOURIST PASS Beetle build |
Help? the seal is really suck in there
AND How the hell did that happen?
'66 RIP
'69 RIP
Posted: Thu Jan 07, 2021 7:35 pm Post subject: Re: ‘65 TOURIST PASS Beetle build |
yeah its kinda hard to see but it looks like the end cap was run against a barrier at freeway speeds if that was even possible. this is the same cap from the side that was missing hlaf the backing plate
it cant be stuck if its liquid! i tried the screwdriver. it says no no. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Fri Jan 08, 2021 5:57 pm Post subject: Re: ‘65 TOURIST PASS Beetle build |
success!
closer view.
You Michigan people have the worst kinda rust!! I had to beat out the old wheel cylinder with a sledge hammer mounted in the vise. anyways, i will be restoring the backing plates while i wait on axle bearings(that never came, ended up getting a refund).
'66 RIP
'69 RIP
