Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Mon Sep 06, 2021 5:30 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Me forgorts sum stuff.
I wrapped up the last brake assembly. Drum went on first push this time
The speaker wire i had collected was way to big so I think im gonna keep it for when I install the subs and amp.
I made my own clip for the e brake lever in the drum. Fits well.
And I had to temporarily move my rabbit from the barn so my in laws can spray chemicals and stuff. So now he lives in the shop. So he can inhake my chemicals dont worry, im being extra cautious. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3789 Location: San Jose, CA
Posted: Mon Sep 06, 2021 8:45 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Hecka cute (that's not something I say on The Samba much )
Is that a Netherland Dwarf? |
Posted: Tue Sep 07, 2021 3:01 am Post subject: Re: "Menace" '65 Tourist Delivery Build |
close. hes a polish. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Tue Sep 07, 2021 4:04 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
To whoever reported my comment or whoever saw my previous comment, if you were my generation you'd understand.
Anyways, I ordered some parts from summit, and I'm about to make a Wolfsburg west order.
Are the heater channel bottom plates all good quality? I see WW only sells the black klocker whatever, but cip1 sells the same as well as a bare steel more expensive version. How's the WW fitment? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Wed Sep 08, 2021 4:56 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Master cylinder got back ordered but I got the e brake 4 now.
'66 RIP
'69 RIP
Posted: Thu Sep 09, 2021 5:53 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Boy I've been busy busy busy. All I had time for today was to set a fender down on the wheel and shove a headlight in there just to see how it looked.
'66 RIP
'69 RIP
Posted: Fri Sep 10, 2021 5:34 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
'66 RIP
'69 RIP
Posted: Fri Sep 10, 2021 7:11 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
1 111801172C SIDE MEMBER, bottom plate, right, 1949-1979 standard Beetle $38.00 $38.00
1 211201557E GAS CAP GASKET, fits 70mm gas cap, made of hexane/benzene resistant material. (This does not fit vented style, spring cap.) $1.50 $1.50
1 111801145A Threaded plate at the front of heater channel. Fits all beetles through 1979. $4.00 $4.00
1 111209021G FUEL TANK OUTLET KIT, 1962-1974 Bug, 1955-1971 bus. High Quality. Made by Wolfsburg West. $12.50 $12.50
1 113721221 BRAKE PEDAL PUSH-ROD LOCK TAB, 1958-1966 (chassis 116851649), Bug $0.75 $0.75
1 311721509 ACCELERATOR PIVOT, 1958-1966 (1966 Bug through chassis # 116460613) Bug, made by Wolfsburg West $7.50 $7.50
1 113611001 Standard Beetle master cylinder mounting hardware kit, fits through 1977. $0.95 $0.95
2 113721219A BRAKE PEDAL PUSHROD PIN, fits 1958-Mid'66 Beetle (1966 Beetle through chassis # 116851649), made by Wolfsburg West $1.90 $3.80
1 113611301H BRAKE FLUID RESERVOIR, 1967 Bug, includes vented cap, metal line outlets and fittings, made by Wolfsburg West
113611829 MASTER CYLINDER MOUNTING SPACERS, 1950-1977 standard Beetle, made by Wolfsburg West, pair $5.00 $10.00
1 555MM BRAKE LINE $5.50 $5.50
1 113721335A CLUTCH CABLE, 1963 (1963 Bug starting at chassis # 5261830) -1971 Bug, OEM, 2267mm/89.25 inches $9.75 $9.75
2 111899115 BODY PAD, lower, body to front axle, Oct'52-1977 Beetle, each, Wolfsburg West reproduction $1.95 $3.90
2 111899119B BODY PAD, rear shock tower, 1949-1979 Bug, each, Wolfsburg West reproduction $1.25 $2.50
Parts Subtotal = $124.15
Tax = $11.63
ordered some mo parts. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2002 Location: Texas
Posted: Fri Sep 10, 2021 9:35 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Been there, done that, man. I found it's also a good idea to keep a spreadsheet of the parts I've ordered with a description, part #, qty, cost, and vendor name. Early on, I ended up buying parts I already had purchased (waste of money!) _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Posted: Sat Sep 11, 2021 7:50 am Post subject: Re: "Menace" '65 Tourist Delivery Build |
Yeah. I ordered another clutch cable to try out. Last one I ordered was from CB. Now imma try ww. Says its supposed to work. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Sat Sep 11, 2021 5:42 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
'66 RIP
'69 RIP
Posted: Mon Sep 13, 2021 4:58 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Warning! I am about to post too many pictures... ok now you've been warned.
My daily is half apart, while I'm replacing the balance shaft. So I had my dad drop a rim off for me.
Yup this tire size rocks. With the beam dropped all the way, everything clear perfectly. And its wide too for a 4.5in rim.
I moved the taller fronts to the rear, and vice versa because this... was fucking ugly. I still need spacers in the rear and eventually wider rims.
Lol
This is alot better, but could still be taller.
And then i professionally fastened by oil filter
And I stopped by HF the other day and bought some Zirk fitting cuz the brass ones I bought sucked.
I can't put stickers on straight
'66 RIP
'69 RIP
Posted: Thu Sep 16, 2021 4:47 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Going to a build weekend tomorrow. Should have the car driving this weekend.
Meanwhile....
'66 RIP
'69 RIP
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3987 Location: Antioch, California, a block from the hood
Posted: Fri Sep 17, 2021 9:35 am Post subject: Re: "Menace" '65 Tourist Delivery Build |
Chickensoup wrote: |
thanks.
ok, quick question. i think. Do the later speedos interchange directly? also, the later use electric senders right? do the later electric senders fit in my 65 tank?
thanks |
Yes, a later electronic sending unit will fit the older tank. Then you can use a later speedo to get the gauge in it as well.
I have a speedo I don't think I'm likely to use. I'll have to check the date stamp but I want to say its a 69, or 70. Has the gauge and vibrator on it too.
If you're interested we could work out a trade (assuming you have some junk I find useful) or something, otherwise just cover shipping. Up to you
Let me know and I'll try to get some pictures tonight. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1212 Location: So. Cal
Posted: Fri Sep 17, 2021 11:46 am Post subject: Re: "Menace" '65 Tourist Delivery Build |
Lingwendil wrote: |
thanks.
thanks |
Let me know and I'll try to get some pictures tonight. |
Nice 2 c u here bro. I appreciate the offer but I have one already. Buzzer and all although idk if it works. Idk why very many people upgrade the the later ones. They basically look the same but save room for more gauges and allow for a electric sending unit.
Thanks _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Fri Sep 17, 2021 11:47 am Post subject: Re: "Menace" '65 Tourist Delivery Build |
matthew henricks wrote: |
What did you paint your front beam bolts with? |
I think it was rustoleum self etching then rustoleum professional whatever gloss black. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Sun Sep 19, 2021 4:28 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Well I got the car running, driving, and stopping. I also did some welding, and sprayed some rock grey spray paint. Did some temporary wiring as well.
Oh and I crashed into a giant log hidden behind tall grass. Thank God it only hit the junk fender.
Here my paint for the car. Looks beautiful under light. Has tons of silver and some flake and a little pearl.
Patched the gas tank
I ended up raising the front because as you'll see in one of the videos, no front suspension is ROUGH.
https://youtube.com/shorts/m_cU--9N8f4?feature=share _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Sun Sep 19, 2021 4:52 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
So pretty
'66 RIP
'69 RIP
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sun Sep 19, 2021 5:31 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Lol. Maybe driving through your field in the dark with a flashlight isn't the best idea. But awesome you got it moving under its own power. Always fun to drive a project for the first time. love the ignition switch btw. You're making good progress. Nice work. |
