slayer61 Samba Member
Posted: Thu Nov 11, 2021 10:48 am Post subject: Re: "Menace" '65 Tourist Delivery Build |
TLDR. What's the Cliff Notes version? _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Thu Nov 11, 2021 11:17 am Post subject: Re: "Menace" '65 Tourist Delivery Build |
slayer61 wrote: |
TLDR. What's the Cliff Notes version? |
Posted: Thu Nov 11, 2021 11:18 am Post subject: Re: "Menace" '65 Tourist Delivery Build |
Bottom end;
AS41 German Case, (first over line bore, hoover mods, porsche squirters)
CB case/head hardware kit
CB oil relief piston kit
EMPI 82mm forged crank, VW journal
CB H beam 5.5 rods, VW journal
AA K 92mm liners
ICON Toyota 22re flat top forged pistons
Mahle rod bearings, STD
Metal Leve .50 over cam bearings
NOS babbit steel backed main bearings
DPR 12v 200mm light-weight flywheel
CB Chromoly gland nut
Kennedy Stage-2 PP
Oil System;
CB Maxi 30 Full flow oil pump kit
DP Oil Cooler
SCAT 2qt sump
CB Maxi-Flow deep sump oil pick-up tube
Porsche piston squirters(early smaller volume version)
EMPI cast oil filter adapter
Valve-train;
CB 2242 camshaft, (deburred lobes + stroker clearanced)
TP Tool Steel Lifters
CB Pro Series Straight cut gear kit
ACN HD aluminum push rods
CB SS Racing push-rod tubes
CB 40x35.5 Los Panchito’s, (CNC Chamber, 61mm before fly-cutting)
SCAT 1.25 slipper foot Rocker assembly Kit
CB 3-groove SS valves
Dan Rudock stage 1 beehive kit
Stock valve covers, (vented)
Home-made Tri-Y Tuned exhaust
Fuel-Delivery;
Custom Home-Made Port injection Intake manifolds
25.4 LBS GM 4.8/5.3/6.0 Injectors
Custom Home-Made Fuel Rails
VFR800 TB’s, (use stock injectors as meth injection)
Ignition;
The Dub Shop reluctor wheel kit
Modified cast iron dizzy as cam sync
5.3 GM LS Coil Packs
Speeduino V2
NGK D9EA spark plugs
Magnecor Electrosports 80 plug wires, (CB Kit)
NOS Bosch 12v Alternator
Accessories;
Late FI T1 fan shroud, (removed and welded fresh air ducts)
Andrigs fan V2
SCAT serpentine pulley system
Stock Thermostat system
Stock German supporting tins
Well, i started the master list for my 2180. Ive collected about half the parts so far. Should be a strong ol engine |
Posted: Thu Nov 11, 2021 11:42 am Post subject: Re: "Menace" '65 Tourist Delivery Build |
Toyota pistons and Honda throttle bodies. Outstanding! _________________
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Tue Nov 30, 2021 10:02 am Post subject: Re: "Menace" '65 Tourist Delivery Build |
Yesterday I got some work done.
The accel pump isnt working. Clogged from sitting. But the excessive fuel pressure makes up for it
I put some fuel in the tank, and it started right up. But with a knock I checked the oil. It was low, and Milky
So i changed the oil, still no change.
Ill look at it some more today, but im hoping its an exhaust leak. I am missing the bottom clamps going to the muffler soo...
Next up is heater channel work. Gonna find a way to turn the body on its side without a rotisserie. Maybe lots of bubble wrap _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1957 Location: Manitowoc, WI
Posted: Tue Nov 30, 2021 11:03 am Post subject: Re: "Menace" '65 Tourist Delivery Build |
Ceckert64 wrote: |
Tires with no rim on them for the body? Hay? |
yeah that'll do I got a stash. thanks _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Tue Nov 30, 2021 2:03 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
a mattress i dont want the millions of skin flakes that come with it i think i can get away without bracing. im only replacing the passanger heater channel bottom luckily. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Fri Dec 03, 2021 7:14 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Yesterday I drilled small holes in the pan(like 3 or 4). Then I started cleaning the nasty dirt pollen stuff off.
And I made this _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Mon Dec 06, 2021 6:42 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Fixed dent
Cleaned half the pan. Oh my gosh I have so many scratches from the battery and riding around on 5 gallon buckets. Oh well. I'll fix it later.
Media blasted some stuffs.
Goodbye German headlight glass
Next up on the task list.
'66 RIP
'69 RIP
Posted: Mon Dec 06, 2021 7:18 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Ceckert64 wrote: |
The fact the headlight lens made it intact from Michigan to Georgia in a box with a brake drum to be broken from being dropped the floors are looking good though! |
oh the irony i almost forgot about its sketchy journey here. oh well lol. its sibling lives. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Tue Dec 07, 2021 3:14 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Ceckert64 wrote: |
Chickensoup wrote: |
Ceckert64 wrote: |
oh the irony i almost forgot about its sketchy journey here. oh well lol. its sibling lives. |
Will it? |
i mean, it survived the 12ft it flew when I hit that fallen tree.
Here are some pictures for future samba lurkers. Original German 65 gray front mat.
'66 RIP
'69 RIP
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Tue Dec 07, 2021 7:16 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Bummer on the glass. I broke one myself a few years ago and cried a little |
Posted: Wed Dec 08, 2021 4:38 pm Post subject: Re: "Menace" '65 Tourist Delivery Build |
Yeah.. I may of shed a tear as well
'66 RIP
'69 RIP
Posted: Thu Dec 09, 2021 6:05 am Post subject: Re: "Menace" '65 Tourist Delivery Build |
WOAH! Look at what i just found,
https://ronlummusracing.com/product/polycarbonate-windshield/
I mean, why would i pay 75 bucks for a standard aftermarket windshield when i can buy this for a 100?
Well, its kinda 100 bucks. 200 with the coating. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
