gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Thu Dec 26, 2019 8:06 am Post subject: RHD Speedo cable sources? |
Typically the cable in your old bus or truck is readily available but with a RHD unit they are a bit longer. Mine is kinda tattered and I would like a new one. The factory part number for is 211 957 801F and shows in the parts list at 2577mm long.
Does any one have a source to get these made? I’ve looked for a while in the ads and never saw one for sale. _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Thu Dec 26, 2019 8:31 am Post subject: Re: RHD Speedo cable sources? |
gatorwyatt wrote: |
Does any one have a source to get these made? I’ve looked for a while in the ads and never saw one for sale. |
What year is the bus/truck?
EDIT: Meant to add that the part number might start with 214, and not 211. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Posted: Thu Dec 26, 2019 11:12 am Post subject: Re: RHD Speedo cable sources? |
11/54’ _________________ www.blastserv.com
wanted:
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Thu Jan 02, 2020 6:30 am Post subject: Re: RHD Speedo cable sources? |
I'm pretty sure I used a later split rhd speedo cable in my bus until it broke. I use a gps speedo on my phone now _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Fri Jan 03, 2020 5:56 am Post subject: Re: RHD Speedo cable sources? |
as I'm in the uk - home of the rhd - I thought I would see what was available here. I can find cables with the part number you give ( 214957801F ) but the length seems to be (when stated) 2330mm long.
but I found this from a dutch company I have used in the past
https://www.paruzzi.com/uk/volkswagen/electricity/dash-instruments/22696/
hope this is of some help _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Sun Jan 05, 2020 6:58 am Post subject: Re: RHD Speedo cable sources? |
finster wrote: |
hope this is of some help |
I took that part number and stated length right from a factory parts list. This is of great help and much appreciated. I’ll order one and see if it does the trick. Cheers!! _________________ www.blastserv.com
wanted:
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Mon Jan 06, 2020 10:07 am Post subject: Re: RHD Speedo cable sources? |
For my curiosity, does the RHD bus use the Right Side spindle/hub for driving the speedo cable? _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Blue barny ute Samba Member
Joined: December 29, 2017 Posts: 9 Location: Australia
Posted: Mon Jan 06, 2020 12:38 pm Post subject: Re: RHD Speedo cable sources? |
The RHD bus uses the left spindle hub to drive the speedo cable I use a bay window RHD speedo cable in mine it works but is too long |
Posted: Wed Jan 08, 2020 8:26 pm Post subject: Re: RHD Speedo cable sources? |
Blue barny ute wrote: |
Appreciate the response...I wondered about the bay window cable. I ordered the one from the link and will report back once it’s in the truck. _________________ www.blastserv.com
wanted:
Posted: Thu Jan 16, 2020 3:12 am Post subject: Re: RHD Speedo cable sources? |
No worries I’ve had mine in for three and a bit years driving with no issues |
Posted: Mon May 04, 2020 3:12 pm Post subject: Re: RHD Speedo cable sources? |
Is there anyone that has a nose of a RHD pre 55’ bus accessible to show where the cable routes through the lower valance? My floor has had some metal replaced and the lower nose already replaced and it been apart for some years. We just need a hole location. Any help is greatly appreciated. _________________ www.blastserv.com
wanted:
ian67 Samba Member
Posted: Tue May 05, 2020 10:50 am Post subject: Re: RHD Speedo cable sources? |
Can I ask if the cable you ordered was ok, and if you managed to source a RHD clutch cable ..I have a 52 rhd that I'm rebuilding thanks |
Posted: Tue May 05, 2020 3:39 pm Post subject: Re: RHD Speedo cable sources? |
Still not installed hence me looking for the location hole where it comes through floor... _________________ www.blastserv.com
wanted:
Posted: Fri Mar 12, 2021 4:59 am Post subject: Re: RHD Speedo cable sources? |
Cable installed and fits _________________ www.blastserv.com
wanted:
