67ctbug Samba Member
Posted: Sat Dec 28, 2019 7:47 pm Post subject: Order of Operations |
I’m at the point in my build where I’m getting ready for paint. I’m doing the priming and am having it painted at my work. So I’m wondering what order I should prime in or if I should even bother with multiple primers. I’m going Kirker SS for the topcoat. Here’s what I think-
Primer sealer over filler
2k Urethane Primer (Finish 1 FP410)
Acrylic high build (Kirker 1315)
Acrylic Urethane Single Stage paint (Kirker ultra-glo)
A) Does this sound like the right order?
B) The high build is 1K, is that fine and is it necessary?
I may work in a body shop, but I don’t paint anything so I have no idea pretty much what will work and what won’t. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Onceler Samba Member
Posted: Sat Dec 28, 2019 8:10 pm Post subject: Re: Order of Operations |
I’ve used Kirker for the past few paint jobs. I’d recommend not using the FP410 or the 1315 and just use kirkers Perfect Prime. It’s high build and sands easy and it’s a 2k product _________________ 1972 Karmann Ghia |
Posted: Sat Dec 28, 2019 8:35 pm Post subject: Re: Order of Operations |
So you would just use perfect prime, sand, them paint? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sat Dec 28, 2019 8:49 pm Post subject: Re: Order of Operations |
I’ve been using a sealer (reduced epoxy)after sanding the perfectprime just for risk reduction of the various coatings _________________ 1972 Karmann Ghia |
jspbtown Samba Member
Posted: Sun Dec 29, 2019 9:36 am Post subject: Re: Order of Operations |
I too have used Kirker on many of my builds. Here is what I would do...
1. Enduro prime
2. Apply several coats of perfect prime and let cure
3. Guidecoat and block
4. Seal with reduced Enduro prime (30 min flash time)
5. Apply top coat.
Now I guess you could skip one if you have no exposed metal on your project |
Posted: Sun Dec 29, 2019 11:20 am Post subject: Re: Order of Operations |
Yes exactly this^^^ _________________ 1972 Karmann Ghia |
Posted: Mon Dec 30, 2019 12:36 pm Post subject: Re: Order of Operations |
Thanks guys! Just ordered a gallon of perfect prime. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
