8bit Innovations Samba Member
Posted: Sat Dec 28, 2019 10:00 pm Post subject: Grinding terror correction |
Hello guys, I don’t know how I managed to score a 49 vanilla for under $8000 six months after getting my 67 vert but I feel lucky to say the least. The 49 is 95% restored, but I have trouble enjoying the ride quality due to the transmission lacking synchronizers. I have tried different angles, going easy on the stick, but none have been successful. How do you guys manage to shift gears smoothly without grinding any gears at all?? _________________ -8Bit
67 Bug Puerto Rico spec Deluxe sedan Fontana Grey (Acquired from original owner’s family)
Last edited by 8bit Innovations on Thu Jan 02, 2020 12:33 pm; edited 2 times in total |
sled Samba Member
Posted: Sun Dec 29, 2019 8:48 am Post subject: Re: Grinding terror correction |
rev match.
you need to learn how to rev match the engine to whatever RPM it needs to be in the next gear you are trying to get into. When upshifting, push the clutch in and let the RPMs drop to the required rpm, then move the gear stick and let the clutch out, there is no speed-shifting here. When down shifting it is a bit more tricky and takes practice. Push the clutch in and shift to neutral and let the clutch out, then stab the throttle to bring the RPMs up to where they need to be for the lower gear, then quickly push the clutch in and shift into the desired lower gear.
3rd and 4th gear are easier because they are helical cut, but with practice you should be able to shift into first and second just as smoothly. _________________ drive your split. |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Sun Dec 29, 2019 9:03 am Post subject: Re: Grinding terror correction |
Oh, the good thing is that there is nothing wrong with my bug, anyway thanks to everyone for the advice! _________________ -8Bit
67 Bug Puerto Rico spec Deluxe sedan Fontana Grey (Acquired from original owner’s family) |
rod_vw Samba Member
Joined: December 20, 2006 Posts: 416 Location: Shropshire, UK
Posted: Sun Dec 29, 2019 10:29 am Post subject: Re: Grinding terror correction |
The description in the link from Mr. OG Paint is perfect BUT we are all used to modern cars that will accept rapid gear changes. Our non-synchro gearboxes will not!
Take your time changing gear and you will find that after a while matching the revs comes naturally.
I forget quite often after jumping out of a modern T6 Transporter with its slick six speed box, then the Beetle quickly reminds me!!
Never the less the Beetle is a pleasure to drive once I settle down with its idiosyncrasies. _________________ Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
2016 T6 Selfbuild Camper and a LWB MAN TGE in build. |
Posted: Thu Jan 02, 2020 12:13 pm Post subject: Re: Grinding terror correction |
rod_vw wrote: |
Never the less the Beetle is a pleasure to drive once I settle down with its idiosyncrasies. |
Thanks to you too! I later discovered that indeed the transmission needs some time to shift into gear. And once again, thank you very much to everyone for helping me out!! _________________ -8Bit
Thebubblehead Samba Member
Posted: Thu Jan 02, 2020 12:37 pm Post subject: Re: Grinding terror correction |
Thebubblehead wrote: |
Pics of your 49?🤗 |
Sure
Btw, in the initial post I got confused, the vert is the 67, it has been a pain to get parts for it, I have always preferred the vanillas (base model) over deluxe and verts, follows more loyally the Volkswagen mission to create an affordable car for the people _________________ -8Bit
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24050 Location: Southeast USA
Posted: Sat Jan 04, 2020 9:44 pm Post subject: Re: Grinding terror correction |
(Hi Kent!)
One other bit of advice. Second gear shifts smoother the slower you're going. Use first just to get the car moving, and shift to second right away. It may make the driver behind you mad, but you should find the shift into second smoother.
If you get the revs up in first like you want to, it will c-r-u-u-n-c-h!
Also, as mentioned above, pause between upshifts, and let the rpms settle.
The advice is good for downshifts -- you must double clutch. However, you may do it exactly the same, and one time it will be quiet, and another time it will protest. It's just the nature of the beast. They don't like downshifts. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
fazeka Samba Member
Posted: Sun Jan 05, 2020 3:47 am Post subject: Re: Grinding terror correction |
+1.
I was taught "shift only into 1st when stopped, never downshift into it". You're slow enough at that point (from 2nd) anyway, what's the use to downshift into 1st?
I'm like that even on full synchros, too. Just a habit. YMMV.
Blue Baron wrote: |
One other bit of advice. Second gear shifts smoother the slower you're going. Use first just to get the car moving, and shift to second right away. It may make the driver behind you mad, but you should find the shift into second smoother. |
sled Samba Member
Posted: Sun Jan 05, 2020 10:17 am Post subject: Re: Grinding terror correction |
I don't find any of that advice sound. A 25hp does not have very much horsepower, and barely getting the car moving before shifting into second is a sure way to lug the engine more than needed. With practice, every gear can be navigated both up and down, without ANY crunch. If you are grinding, then you need more practice.
Also, it is possible to down shift into first, I do this all the time with very little if any crunch, once again, you need to match the RPM's (high).
The transaxle does not care how fast you are going in any gear, as long as you can spin the mainshaft up, or slow it down, to the correct rpm required. _________________ drive your split. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Mon Jan 06, 2020 9:25 am Post subject: Re: Grinding terror correction |
sled wrote: |
The transaxle does not care how fast you are going in any gear, as long as you can spin the mainshaft up, or slow it down, to the correct rpm required. |
i agree and only have this to add:
if you are in traffic where you may not have much time to mess with grinding gears, don't shift unless you need to shift. as in don't shift into 3rd for 20 feet, just leave it in the gear you are in. If you are 2nd and need to slow down to a possible stop, just leave it in 2nd until you are stopped. if your wheels are still turning, just keep on driving in 2nd. If you only shift when needed, like downshifting from 3rd into 2nd going up a hill will be much easier close to the top of 2nd than at the bottom of 2nd. it will feel natural to floor it when you are downshifting up hill.... _________________ regards
Uli
Posted: Mon Jan 06, 2020 2:50 pm Post subject: Re: Grinding terror correction |
I agree with Sled and Mandraks. Personally I never "short shift" a full crashbox, I think they work alot better if you rev them out on every gear which allows the RPM drop/rev match to work really well going to the next. That includes the 1-2 shift.
I don't want to be seem cocky, but humbly speaking I am the best crashbox driver ever to live. _________________ https://instagram.com/mr.ogpaint
Patrick Hall
52 split Samba Member
Joined: December 19, 2007 Posts: 150 Location: the best island in the world, vancouver island
Posted: Mon Jan 06, 2020 9:41 pm Post subject: Re: Grinding terror correction |
I would vouch for Patrick, as my daughter and I took a ride down the 1-5 with Patrick at the helm in his car, very smooth. any up dates on the rebuild. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Mon Jan 06, 2020 9:56 pm Post subject: Re: Grinding terror correction |
… nothing like driving my old 11G with full crash box - I never down-shifted into first either - I think of that experience, all the time and the only thing more fun and primitive is a KR-175 Messerschmitt -
I used to shift into neutral, when up-shifting, for a second, unconsciously feel things- listen to the RPMs and shift to the next gear - that worked well _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
Posted: Tue Jan 07, 2020 12:02 am Post subject: Re: Grinding terror correction |
Mine shifted smoother from 1st to 2nd at lower rpms (not slow enough to lug the engine). We're talking full crashbox, and not just first gear.
Your mileage may differ! _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
sled Samba Member
Posted: Tue Jan 07, 2020 8:09 am Post subject: Re: Grinding terror correction |
Blue Baron wrote: |
Your mileage may differ! |
yes thats what we're talking about. _________________ drive your split. |
Posted: Tue Jan 07, 2020 2:00 pm Post subject: Re: Grinding terror correction |
Well guys, because I also have a 67 beetle, I got used to speed shifting. Definitely shifting slowly makes one hell of a difference, thanks for helping me improve my driving experience!! Btw, sorry for my late response, my clutch died and could not drive for a while to test your ideas. Once again, thanks for helping out on this one!! _________________ -8Bit
Posted: Tue Jan 07, 2020 3:17 pm Post subject: Re: Grinding terror correction |
8bit Innovations wrote: |
Well guys, because I also have a 67 beetle, I got used to speed shifting. Definitely shifting slowly makes one hell of a difference, thanks for helping me improve my driving experience!! Btw, sorry for my late response, my clutch died and could not drive for a while to test your ideas. Once again, thanks for helping out on this one!! |
the biggest benefit of learning how to double clutch is that you don't actually need to use the clutch. As long as it is not slipping, of course. _________________ regards
Uli
