busey Samba Member
Joined: October 19, 2016 Posts: 420 Location: Sun City Arizona
Posted: Sun Dec 29, 2019 8:19 pm Post subject: $200 AFR Meter & Go |
Since its no longer possible to rent an AFR thru aircooled.net , word on the street is they are now sub $200 . So lets hear what the top 3 +- $200 AFR Meters are to dial in a 48 IDA 9-1cr street motor w/MagnaSpark II ignition system;
1-
2-
3- _________________ No turning back now, "Its Blow thru or No thru" baby! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9771 Location: Oregon
Posted: Sun Dec 29, 2019 8:36 pm Post subject: Re: $200 AFR Meter & Go |
Not quite under $200. But it is what I have.
http://vwparts.aircooled.net/Innovate-MTX-L-PLUS-Wideband-Kit-3918-p/innovate-3918.htm
Good Luck _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1383 Location: Southern California
Posted: Sun Dec 29, 2019 8:38 pm Post subject: Re: $200 AFR Meter & Go |
The plx use to be right at 200. Is works good. Also seconds as a volt meter. |
FullFender Samba Member
Posted: Sun Dec 29, 2019 8:44 pm Post subject: Re: $200 AFR Meter & Go |
Went through something like 4 Innovate Sensors in 6 months. Could never get it working, some not even out of the box. Clone suggested I buy a PLX and lets just say ive never had to worry about it again |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun Dec 29, 2019 9:10 pm Post subject: Re: $200 AFR Meter & Go |
I bought a PLX in May of 2014 and have over 33,000 miles on the original O2 sensor.
It's never given a problem and it never needs to be calibrated. It will also tell you how much life is left in the sensor.
I have the Gen 3 version....the Gen 4 is out and probably even better. It takes the 4.9 series O2 sensor. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Coyotemutt Samba Member
Joined: June 16, 2017 Posts: 360 Location: Pecos, New Mexico
Posted: Sun Dec 29, 2019 10:18 pm Post subject: Re: $200 AFR Meter & Go |
clonebug wrote: |
I have the Gen 3 version....the Gen 4 is out and probably even better. It takes the 4.9 series O2 sensor. |
I have the gen 4 version. I think I messed up the sensor installing it such that condensation collected on it. In a new setup it works flawlessly. I also get head temp through the same unit.
I'm not getting the O2 life meter function, but I'm not worried about it. |
jim martin Samba Member
Joined: January 14, 2004 Posts: 217 Location: Vancouver, BC
Posted: Sun Dec 29, 2019 10:20 pm Post subject: Re: $200 AFR Meter & Go |
FullFender wrote: |
Would like to know more about this , innovate uses Bosch sensors so going through 4 of them seams odd and switching to another unit does not seam like
That was the fix , what happened to the 4 sensors ?
I’ve run innovate and still run innovate products , my only issues have ever been
Due to extreme lead fowling and overheating due to placement. _________________ B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
LUCAS OIL PRODUCTS http://www.lucasoil.com
KROC head porting services
Dialedinperformance.com
Airspeedparts.com topic http://airspeedparts.com/forums/index.php?topic=914.0 |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Mon Dec 30, 2019 2:11 am Post subject: Re: $200 AFR Meter & Go |
FullFender wrote: |
Do you have excessive valve guide clearance? Is the ring seal good? Are you running very rich?
I ask because the recurring nature of the problem makes me think the engine is somehow contributing at least a little. O2 sensors don't like oil, or too much raw gas in the exhaust. If it's that kind of problem, you can try cleaning it.
But the PLX has been a good solution...what does the PLX do different from the Innovate? |
lelef Samba Member
Posted: Mon Dec 30, 2019 2:52 am Post subject: Re: $200 AFR Meter & Go |
Innovate in 2 cars with microsquirt, on the vw air cooled one sensor fail ,it is not in the best position there is a lot of heat all around the external part of the sensor but there is no way to put it in a better way,one time finished with autotune I've disabled the lambda , sometimes check if it is still working to understand what was really the problem if it fails again.
On a v8 positioned as suggested ,good ventilation around sensor and cables and never a problem.
I don't think Innovate is really good, response and precision should be better but is possible to obtain a good map using it _________________ 13b Buggy
Supercharged 1302
oprn Samba Member
Joined: November 13, 2016 Posts: 12739 Location: Western Canada
Posted: Mon Dec 30, 2019 5:49 am Post subject: Re: $200 AFR Meter & Go |
I bought my Innovative one from aircooled.net. Zero issues with it to date. But then it's the hand held model and I only use it for tuning and take the sensor back out. I see no need for me to run one all the time. |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3293 Location: Rapid City, SD
Posted: Mon Dec 30, 2019 6:40 am Post subject: Re: $200 AFR Meter & Go |
I have installed 3 AEM in different vw's. All still working great. Easy O2 sensores also.
Brian _________________ www.type-emotorsports.com |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Mon Dec 30, 2019 7:56 am Post subject: Re: $200 AFR Meter & Go |
I use a plx and works great _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
busey Samba Member
Posted: Mon Dec 30, 2019 10:44 am Post subject: Re: $200 AFR Meter & Go |
oprn wrote: |
hmmm, come to think of it, i wouldn't be opposed to that at all ... CB Performance even sells an 02 extension that gets sandwiched between the collector and muffler flange to make it all happen. _________________ No turning back now, "Its Blow thru or No thru" baby! |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Mon Dec 30, 2019 11:41 am Post subject: Re: $200 AFR Meter & Go |
shoot for 12/1 or less at WOT for best performance.. |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Mon Dec 30, 2019 1:13 pm Post subject: Re: $200 AFR Meter & Go |
From what I have read the new style 4.9 LSU is a little more prone to failure because the elemnt is thinner. Which is what makes it read more quickly than the old ones. From what I have read it is that element breaking that usually causes failure. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6620 Location: Houston, Texas
Posted: Mon Dec 30, 2019 2:05 pm Post subject: Re: $200 AFR Meter & Go |
That's a nice device.
Is there an easier one to use that doesn't require a hole in the muffler? _________________ www.vwnos.com [email protected]
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Mon Dec 30, 2019 4:47 pm Post subject: Re: $200 AFR Meter & Go |
The innovate used the Bosch 02 and it believe it is very easily messed up. I went through 2 or 3 because mine was running rich and messed them up.
Never again... _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
oprn Samba Member
Posted: Mon Dec 30, 2019 5:10 pm Post subject: Re: $200 AFR Meter & Go |
Mine has never seen richer than 11/1 or 11.5/1. That is pretty rich! I don't think you need a wide band to diagnose a condition that rich. That is where mine runs with the chokes on for starting. |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Mon Dec 30, 2019 6:41 pm Post subject: Re: $200 AFR Meter & Go |
You wouldn’t make it quite under $200, but PLX has a Bluetooth adapter to use your smartphone if not interested in adding gauges to your dash. |
Posted: Mon Dec 30, 2019 7:48 pm Post subject: Re: $200 AFR Meter & Go |
so are you saying the software is damaging the Bosch sensors cause im pretty sure all the listed above units are using the Bosch sensors except for the ngk unit which uses the expensive NTK sensor which will read richer and leaner than the Bosch LSU sensors _________________ B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
