Peter - Belgium Samba Member
Joined: December 22, 2003 Posts: 762 Location: Brussels - Belgium
Posted: Mon Dec 30, 2019 4:21 pm Post subject: 912 Fuel lines... routed correctly? If so... how to change? |
Wanted to change the fuel soft lines but they are very hard to reach (impossible actually...) so wondering if this is correct?
In the fromt it runs over the steering rack and no way to reach it to remove, renew or clamp?
At the rear is as well a pain to get to?
What is the way to replace these softlines without dismantling what is in the way?
Thanks! _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
Posted: Tue Jan 07, 2020 2:30 am Post subject: Re: 912 Fuel lines... routed correctly? If so... how to change? |
No tips anyone on the best way to approach this? dropping the steeringrack to get some access seems bit overkill to change a softline?
Joined: December 28, 2016 Posts: 279 Location: atlanta ga
Posted: Tue Jan 07, 2020 10:05 am Post subject: Re: 912 Fuel lines... routed correctly? If so... how to change? |
those look like the original factory lines, Peter, Porsche probably put them in that way, so if you cut them out of the way then use new non intrusive hose clamps and turn the fastening screw downwards you should be able to reclamp the new 7mm id cloth covered fuel lines |
Posted: Wed Jan 08, 2020 12:20 am Post subject: Re: 912 Fuel lines... routed correctly? If so... how to change? |
Thanks! issue i see it that i can not reach in that super narrow space to first remove the old line, let alone attempt to slide over the new line before even considering being able to tighten a clamp?
strange non maintenance friendly set-up in my opinion ! _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
Posted: Wed Jan 08, 2020 8:12 am Post subject: Re: 912 Fuel lines... routed correctly? If so... how to change? |
you could also unscrew the fitting from the fuel tank for more access, Peter. By the way, my wife is from Menen |
skyboy Samba Member
Posted: Mon Feb 10, 2020 11:23 pm Post subject: Re: 912 Fuel lines... routed correctly? If so... how to change? |
Just saw this, replaced my fuel lines over the summer, wasn't easy but not impossible. These make it so much more easier. With the pliers I could reach up over the rack grab the fuel line and pull it off. I then used the pliers to feed the new line. Took about an hour for the front and and 30 mins for the one in the back.
https://www.harborfreight.com/3-piece-long-reach-hose-grip-pliers-37909.html _________________ 1968 912 HWT
1991 Syncro Westfalia |
