Chathura918 Samba Member
Posted: Mon Dec 30, 2019 4:52 pm Post subject: 1959 - Beetle, Vibration |
Hi everyone ,
I'm building a 1959 vw beetle from bottom up and yesterday we did a test run. As you can see in the video, when I try to give the clutch, it makes a huge vibration and I can't complete that process(giving the clutch).
Any ideas about which causes this problem?
Thank you
Video - https://www.youtube.com/watch?v=I37E2T7iYg0 |
slalombuggy Samba Member
Posted: Mon Dec 30, 2019 5:00 pm Post subject: Re: 1959 - Beetle, Vibration |
Not enough curve on the Bowden tube can cause it, so can a bent disk, warped pressure plate or rough flywheel |
dustymojave Samba Member
Posted: Mon Dec 30, 2019 10:23 pm Post subject: Re: 1959 - Beetle, Vibration |
I have to agree with SlalomBuggy. I would give the same list of potential problems. _________________ Richard
SoCalBajas Member
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Mon Dec 30, 2019 10:34 pm Post subject: Re: 1959 - Beetle, Vibration |
One more I would add to the list is broken mounts for the clutch cable tube in the pan _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1774 Location: Winnipeg
Posted: Tue Dec 31, 2019 7:54 am Post subject: Re: 1959 - Beetle, Vibration |
I once had a beetle with a broken bowden tube retainer that shook pretty hard.
Don _________________ Better and better mistakes! |
catahoula lou Samba Member
Joined: August 30, 2008 Posts: 594 Location: south of Silver Springs, NV
Posted: Tue Dec 31, 2019 9:04 am Post subject: Re: 1959 - Beetle, Vibration |
I just helped my brother-in-law with the same problem. Turned out to be a bad pressure plate.
Pull engine and with pressure plate/clutch assembly still attached to flywheel, put a straight-edge across the ring that the throwout bearing contacts, and measure to flywheel in several directions.
If measurements are all the same - and I mean all the same - the pressure plate is good and might be one of the other suggestions mentioned above instead.
Best,
Thom _________________ 1 great wife
2 Catahoula Leopard Dogs (Mahogany Star and Spartan) - RIP Lucy, Braveheart, & Dusty!
1 1959 mango green Ragtop Bug (the "Mango")
1 1958 pantina red Lowlight Ghia (the "Chili Pepper")
Still looking for:
(1) My Dad's 1955 356 (he raced it amateur-class at Riverside and other courses during 1950s),
(2) My parent's black 1955 hardtop bug (CA license plate FWC 201 or FWG 201), and
(3) My parent's agave green 1957 ragtop bug (CA license plate LFK 734). |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Tue Dec 31, 2019 4:29 pm Post subject: Re: 1959 - Beetle, Vibration |
Is your front transmission mount good and tight? And, no broken nose cone? |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Tue Dec 31, 2019 4:57 pm Post subject: Re: 1959 - Beetle, Vibration |
MrGoodtunes wrote: |
Yup-----the way that thing is bouncing around it has to be more than a chatter
caused by a bowden tube or a funny pressure plate. The engine looks like it is trying its best to leave the car. |
