fcgadget Samba Member
Joined: August 21, 2017 Posts: 111 Location: Willow Glen, CA
Posted: Mon Dec 30, 2019 11:44 pm Post subject: vacuum advance |
has anyone cleaned or rebuilt one of these?
Having trouble getting mine apart (not working anyway)....
or has anyone found a source a "new" one VJU4BR8 |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Mon Dec 30, 2019 11:53 pm Post subject: Re: vacuum advance |
How have you tested the vac can? Has it worked previously? _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Frederik Samba Member
66brm Samba Member
Posted: Tue Dec 31, 2019 3:43 am Post subject: Re: vacuum advance |
That's why I was asking, it's not uncommon for the washers to disintegrate and the plates to not slide as they should, it's also possible for the port to be plugged with some crud as they are so small _________________ Aust. RHD 66 Type 1
modok wrote: |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Tue Dec 31, 2019 4:09 am Post subject: Re: vacuum advance |
Are you asking if the vacuum canister is rebuildable or the entire distributor.
The vacuum canisters are not but the distributor is. _________________ Glenn
Member #1009
#BlueSquare |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6593 Location: Houston, Texas
Posted: Tue Dec 31, 2019 11:13 am Post subject: Re: vacuum advance |
You can rebuild your vacuum advance but it isn't really worth it. There are plenty of NOS ones around. Just buy a new one. _________________ www.vwnos.com [email protected]
Posted: Thu Jan 02, 2020 6:32 pm Post subject: Re: vacuum advance |
definitely the can. And as far as there are plenty around...I can't find them. Anywhere. |
type241 Samba Member
Joined: June 02, 2006 Posts: 971 Location: MOSES LAKE, WA
Posted: Thu Jan 02, 2020 7:06 pm Post subject: Re: vacuum advance |
Glenn Mr. 010
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Jan 04, 2020 2:00 am Post subject: Re: vacuum advance |
I would call the NOS canisters hard to find but not in the rare category. The ones you do find are old manufacture and should be fully tested before being installed.
as far as cleaning, don't soak them in any kind of solvent. The diaphragms are made of a speaker cone like paper.
The canisters were not made to be repaired or rebuilt. It would require a can opener type tool and the final result is not aesthetically pleasing.
The interior of the canisters is very well sealed from the outside environment. I have a number of canisters from BR 2 and 3's that are still good sixty-seven years later. There is an abundance of BR 8 Beetle distributors out there. Another option is to take a good canister from one of these core distributors.
_________________ Roads Scholar &
Posted: Sat Jan 04, 2020 4:06 pm Post subject: Re: vacuum advance |
thanks..I guess I need to do an online order and hope for the best |
Posted: Fri Jan 17, 2020 10:46 pm Post subject: Re: vacuum advance |
and it IS the advance, the dizzy plates do freely turn |
