cable brake overhaul
sinclair
sinclair is offline
PostPosted: Thu Jan 02, 2020 12:29 pm    Post subject: cable brake overhaul Reply with quote
I luckily now have all the parts to return my 52 to cable brakes, so thought I'd post some progress pics.
Strip down
9secschwim
9secschwim is offline
PostPosted: Sun Jan 05, 2020 12:51 pm    Post subject: Re: cable brake overhaul Reply with quote
Had a 51 standard Wolfsburg West had everything.
Der Blitzkrieg Käfers
sinclair
sinclair is offline
PostPosted: Fri Jan 10, 2020 2:01 pm    Post subject: Re: cable brake overhaul Reply with quote
£40 later at my local painters
and a few hours in the cellar with the home plating kit.
sinclair
sinclair is offline
PostPosted: Fri Jan 10, 2020 2:04 pm    Post subject: Re: cable brake overhaul Reply with quote
Thanks. That’s good to know Very Happy
sgmalt46
sgmalt46 is offline
PostPosted: Fri Jan 10, 2020 4:45 pm    Post subject: Re: cable brake overhaul Reply with quote
They do? that's news to me. Not in there catalogue? Confused
55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back
46 beetle
sinclair
sinclair is offline
PostPosted: Mon Jan 13, 2020 11:32 am    Post subject: Re: cable brake overhaul Reply with quote
nlorntson Premium Member
Crazy VW Lady
nlorntson is offline
PostPosted: Mon Jan 13, 2020 8:23 pm    Post subject: Re: cable brake overhaul Reply with quote
Links to their cable brake parts?
sgmalt46
sgmalt46 is offline
PostPosted: Tue Jan 14, 2020 7:12 am    Post subject: Re: cable brake overhaul Reply with quote
maybe they did at one time? they got front cables .
that's it? Sad
64 crew cab
55 rag top beetle
66 beetle
71 square back
46 beetle
Crazy VW Lady
PostPosted: Tue Jan 14, 2020 7:22 am    Post subject: Re: cable brake overhaul Reply with quote
that's it? Sad
WW doesn't carry front cables either.
Peter_N
Peter_N is offline
PostPosted: Tue Jan 14, 2020 8:13 am    Post subject: Re: cable brake overhaul Reply with quote
Those brakes looks fresh!
What kind of plating is that?
My 1958 PGSG project topic
sgmalt46
sgmalt46 is offline
PostPosted: Tue Jan 14, 2020 3:39 pm    Post subject: Re: cable brake overhaul Reply with quote
nlorntson wrote:
that's it? Sad
it does not show in there catalogue.
search cable brakes and they are there.
part# 111 605 701. to 65 standard beetle. FRONT
there calling them emergency brake cables.
on a cable brake car all 4 are emergency brakes!
64 crew cab
55 rag top beetle
66 beetle
71 square back
46 beetle
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Tue Jan 14, 2020 3:41 pm    Post subject: Re: cable brake overhaul Reply with quote
If you're looking to have original cable brake shoes relined there are specialty shops. But the easiest place for many of us to source the service is at a Large (semi) truck specialist because it is still a common practice with large trucks. In the US there is a national chain called FLEETPRIDE. I went to the local FLEETPRIDE and sent out my shoes and had them relined/arched within 1 week. It was around $100.
https://instagram.com/mr_ogpaint
Patrick Hall
Mr. OGPaint
PostPosted: Tue Jan 14, 2020 3:43 pm    Post subject: Re: cable brake overhaul Reply with quote
nlorntson wrote:
that's it? Sad
I got brand new front cables from CIP1.com, I think they were $20 each and 2 days delivery. They are a BBT distributor, BBT carries/reproduces them.
Patrick Hall
sinclair
sinclair is offline
PostPosted: Thu Jan 23, 2020 12:35 pm    Post subject: Re: cable brake overhaul Reply with quote
Quick update.
New pins and bushes in the spindles. More zinc plating the fixings.
sinclair
sinclair is offline
PostPosted: Sat Jan 25, 2020 11:09 am    Post subject: Re: cable brake overhaul Reply with quote
I thought these bearing caps were too far gone having been chiselled off numerous times but a flap wheel and the zinc bath worked ok. They’re VW stamped so I want to keep them. As for the nuts, we’ll why not recycle?
sinclair
sinclair is offline
PostPosted: Wed Jan 29, 2020 10:40 am    Post subject: Re: cable brake overhaul Reply with quote
One of the drums turned out to be warped so I had it skimmed.
