Vokaro project car
Page: Previous  1, 2, 3 ... 5, 6, 7 ... 12, 13, 14  Next
oprn
oprn is offline
PostPosted: Mon Jun 14, 2021 4:36 am    Post subject: Re: Vokaro project car Reply with quote
What I am saying is that you are in territory that most of us only dream about.
We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age)
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Fri Jul 02, 2021 11:10 am    Post subject: Re: Vokaro project car Reply with quote
Well....have not gotten a lot done this past few weeks.
I was working on mount points/tabs and such last time I posted.
I did get a lot of those little things tack welded to the tube frame and the tab mounts underneath that attach to the front beam fabbed and tacked in place.
My girlie got me seat covers for the poly seats for father's day.
And some whatnots from ebay.
Thinking I am gonna try to finish the front half of the car and turn it around and start the big build on the rear fiberglass.
So now while I have the front torsion spring disconnected and can freely move the suspension I cut the front tire clearance in the body.
I had already cut 4" or more out of the wheel arches just to get the body on.
Drop spindles, adjusters, and a pie cut, plus an inch or so of body drop (moved Napoleon hat), not to mention dropped floor boards.........all have me really tight on room.
The tires are only 23 inch diameter, but are 205 wide.
A lot more cutting.
modok wrote:
And look at the SHAPE of the curves, just smooth, like gods own slingshot. .
DeathBySnuSnu
PostPosted: Fri Jul 02, 2021 11:15 am    Post subject: Re: Vokaro project car Reply with quote
So those 70's flairs are completely gone.
Now to create a wide body look.
Hacked up some fiberglass flairs.
Of course all this will be glassed in (not screwed to the body) and smoothed out.
So it looks like this.....and had about 2-1/2" of travel and turns.
MrGoodtunes
MrGoodtunes is offline
PostPosted: Fri Jul 02, 2021 1:45 pm    Post subject: Re: Vokaro project car Reply with quote
Soo awesome, most of us can only dream about making the car fit the wheels. Closest I was able to get was hacking off ~2.5" from the extreemly far out front fender flairs on my Mini-Camaro. But then, it made the opening (which was already too big) even wider! So I glass'd in a little lip to close it back down some.
Edit - Oops, dream comment already made a few posts back by Opee (he's the guy who has built exhaust systems most of us can only dream about).
DeathBySnuSnu
PostPosted: Fri Jul 02, 2021 5:57 pm    Post subject: Re: Vokaro project car Reply with quote
Well that ain't too bad.....if you were to hack the fenders out of it and remake it......well then it would not have a Camero look.
Now mine is not a look alike ....... So I'm remaking it in my image.....lol
Ok....so
Splitter or No?
I thought it would be cool......but I am iffy about it....,ain't quite as cool as imagined.
Looking at air dam ideas now.
MrGoodtunes
PostPosted: Fri Jul 02, 2021 7:35 pm    Post subject: Re: Vokaro project car Reply with quote
DeathBySnuSnu wrote:
.....if you were to hack the fenders out of it and remake it......well then it would not have a Camero look....
I pretty much already broke its Camaro look, hated the way its hood would try to lift and take flight at highway speed.
Yours is already nicely aerodynamic, but she really does need something under that shark-like nose. I'd be tempted to give it some teeth, a-la Jaws!
finefettle
finefettle is offline
PostPosted: Sat Jul 03, 2021 6:10 pm    Post subject: Re: Vokaro project car Reply with quote
The splitter is cool but just a bit to long? Not sure, iffy is a good adjective but I don’t think it’s far off. Tweak it and play with it a bit. I see sharpie lines on it that are in a good direction.
This car is sooo cool.
1979 Bug project
DeathBySnuSnu
PostPosted: Fri Jul 23, 2021 4:48 pm    Post subject: Re: Vokaro project car Reply with quote
Splitter cut down and rubber flapped.
mark tucker
mark tucker is offline
PostPosted: Thu Jul 29, 2021 4:09 pm    Post subject: Re: Vokaro project car Reply with quote
that would look so wicked with a hemi& 10-71 sticking up out of the front. Popcorn
DeathBySnuSnu
PostPosted: Fri Jul 30, 2021 6:16 pm    Post subject: Re: Vokaro project car Reply with quote
That would be cartoonist.....exhaust ports would be above "hood" level.
Besides....I don't have any Mopar stuff anymore.
Never had a "real" hemi anyway.
Did have a stroked iron block RB full of concrete and with the lugs welded in the cam galley to fit them loonymum elephant heads.
DeathBySnuSnu
PostPosted: Sat Sep 25, 2021 4:46 pm    Post subject: Re: Vokaro project car Reply with quote
Finally less hot today.
Got some work done on it today.
Body is off and chassis fitting ad welding started.
Wanting to finish the front and turn it around.
DeathBySnuSnu
PostPosted: Mon Oct 04, 2021 6:52 pm    Post subject: Re: Vokaro project car Reply with quote
Spit top spring with the load biased on the top.
Nowhere near as stiff as I expected.
DeathBySnuSnu
PostPosted: Tue Oct 12, 2021 6:53 pm    Post subject: Re: Vokaro project car Reply with quote
Fender extensions fiberglassed to the body.
Ground in the exterior and layered it in today.
Maybe tomorrow flip it and grind inside in and heavily layer it in.
DeathBySnuSnu
PostPosted: Sat Nov 20, 2021 5:36 pm    Post subject: Re: Vokaro project car Reply with quote
Still working on it.
Tube chassis.
clonebug
clonebug is offline
PostPosted: Sat Nov 20, 2021 7:17 pm    Post subject: Re: Vokaro project car Reply with quote
Looking good!!!!
vwracerdave wrote:
Take a good long look in the mirror and report back on what you see.
Paul.H wrote:
That one line on that chart is probably better info than you can get from this place in a month
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
DeathBySnuSnu
PostPosted: Thu Nov 25, 2021 6:07 pm    Post subject: Re: Vokaro project car Reply with quote
Sitting outside waiting on me.
Teeroy Premium Member
Teeroy is offline
PostPosted: Fri Nov 26, 2021 1:49 pm    Post subject: Re: Vokaro project car Reply with quote
After you extend it, is the rear body gonna tilt or be removable? Chassis is looking good.
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
DeathBySnuSnu
PostPosted: Sat Nov 27, 2021 6:15 pm    Post subject: Re: Vokaro project car Reply with quote
Yes
Backwards flip up like a 550.
I am nearly fully beetle wheelbase now.
I just welded for two days and still ain't done........
And I still gotta make the rear sub frame that holds the tail of trans and radiator.
DeathBySnuSnu
PostPosted: Sat Dec 11, 2021 3:58 pm    Post subject: Re: Vokaro project car Reply with quote
It's upside down.......
Another day of welding.
DeathBySnuSnu
PostPosted: Sat Dec 11, 2021 3:59 pm    Post subject: Re: Vokaro project car Reply with quote
Some of the suspension is done and ready.
Page 6 of 14
