DeathBySnuSnu Samba Member
Posted: Sat Jul 04, 2020 4:15 pm Post subject: Re: Vokaro project car |
Also still trying to cram a 228 clutch into this bell housing.
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
Posted: Sat Jul 04, 2020 4:20 pm Post subject: Re: Vokaro project car |
Now I gotta come up with some replacement springs.
I spose these were rusted enough to break off during the disassembly.
modok wrote: |
mark tucker Samba Member
Posted: Sun Jul 05, 2020 9:50 am Post subject: Re: Vokaro project car |
yikes!! those springs look like they were submerged in a spring... |
Posted: Sat Jul 11, 2020 6:49 pm Post subject: Re: Vokaro project car |
Got a hold of some used spring stacks and mix and matched a set up for the bottom beam.
modok wrote: |
Posted: Sat Jul 11, 2020 6:51 pm Post subject: Re: Vokaro project car |
Got all the brakes and modified them up for the metric wheels.
modok wrote: |
Posted: Fri Jul 24, 2020 7:56 pm Post subject: Re: Vokaro project car |
Front beam coming together.
modok wrote: |
Posted: Fri Jul 31, 2020 6:15 pm Post subject: Re: Vokaro project car |
Intake manifold to fit ITB's all made up except welding.
modok wrote: |
Posted: Fri Jul 31, 2020 6:16 pm Post subject: Re: Vokaro project car |
Stacks all whittled out.
modok wrote: |
Posted: Fri Jul 31, 2020 6:23 pm Post subject: Re: Vokaro project car |
And this will be the flywheel.
Odd that the original v6 flywheel is cast.....and this is an 8000 rpm motor in stock form.
I am gonna loose a lot of weight getting this thing small enough to go in the 901 bell housing.
modok wrote: |
Posted: Sat Aug 01, 2020 4:14 pm Post subject: Re: Vokaro project car |
Flywheel mostly made. Still gotta counter sink the crank holes.
Odd thing was that I started with 2 flywheels and now only have one..... _________________
modok wrote: |
Posted: Sun Aug 16, 2020 1:07 pm Post subject: Re: Vokaro project car |
Flywheel made up.
And the parts to put a VW bearing in the Porsche trans.
modok wrote: |
Posted: Sun Aug 16, 2020 1:13 pm Post subject: Re: Vokaro project car |
Fuel pieces parts.
Found a few bits in my junk piles. Regulator, boards, map sensor.
modok wrote: |
Posted: Sun Aug 16, 2020 1:14 pm Post subject: Re: Vokaro project car |
Started whittling on fuel rails.
modok wrote: |
Posted: Sun Aug 16, 2020 1:16 pm Post subject: Re: Vokaro project car |
One intake all made, welded and cleaned up
One more to go.
modok wrote: |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Sun Aug 16, 2020 6:45 pm Post subject: Re: Vokaro project car |
Purdy! |
weasel_ugs Samba Member
Joined: March 16, 2012 Posts: 721 Location: Prescott Valley,Az.
Posted: Sun Aug 16, 2020 6:52 pm Post subject: Re: Vokaro project car |
Wow, you have one hell of a junk pile! |
Posted: Mon Aug 17, 2020 5:20 pm Post subject: Re: Vokaro project car |
weasel_ugs wrote: |
What?......Ya don't have a couple boxes of misc electronic parts, pieces, sensors, boards, relays and on and on?
I use anything and everything...... eventually. _________________
modok wrote: |
Posted: Mon Aug 17, 2020 6:11 pm Post subject: Re: Vokaro project car |
DeathBySnuSnu wrote: |
weasel_ugs wrote: |
I use anything and everything...... eventually. |
I used to, had to slim down for a move and wife complains if I keep too much around |
Posted: Sat Aug 22, 2020 12:03 pm Post subject: Re: Vokaro project car |
Crud.....whole post just disappeared....
And again.
The whittled flywheel, type 1 starter ring, Mazda 228mm pressure plate, type 5 disc and throw out bearing all fit together and went on the Mazda v6 and Porsche 901 trans.
Now to get a starter to engage.
It is an odd depth to ring.
The plan is a Tdi starter and an adapter.
Anyone know the offset for a Tdi starter?
modok wrote: |
Posted: Sat Sep 05, 2020 1:45 pm Post subject: Re: Vokaro project car |
I did get that starter on there.
Tdi starter on a 901 trans with a whittled down Mazda flywheel and a type 1 ring gear.
modok wrote: |
