DeathBySnuSnu Samba Member
Posted: Sat Sep 05, 2020 1:57 pm Post subject: Re: Vokaro project car |
Working with the front end.
Was unsure of how low it would be.
Naturally I want it low.....but I do not want to drag or make sparks. May have to avoid big bumps ECT....but want to be able to fully bottom out in a corner and not touch the ground.
With only drop spindles and stock shock with bump stops it is down there.
Bottomed out.
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
Posted: Sat Sep 05, 2020 2:00 pm Post subject: Re: Vokaro project car |
Six degree head.
modok wrote: |
slalombuggy Samba Member
Posted: Sat Sep 05, 2020 4:39 pm Post subject: Re: Vokaro project car |
If you would have pie cut a 1/2" it right in front of the Napolean's hat you could have got the same caster and dropped the front of the car a couple of inches at the same time. The angle you have the control arms are at now you are going to have next to no travel in the front suspension.
brad |
Posted: Sat Sep 05, 2020 5:58 pm Post subject: Re: Vokaro project car |
Back up and read it again.
The front on assembled pic is with a six degree head, drop spindles.
And
It is sitting on the bottom out stops.
This is all the way down.....only up movement from here.
The grubs are cut......ride height not set. The angle of the arms are same as original stock at full bottom.
I am working from bottom up.
Just tentatively I was wanting the floor board 2 inches off the pavement at full bottom out ....... But it looks more like I will be around one inch.
I do not want a pan dragger. Cut at the Napoleon hat would have been too low at bottom out.
Just as a side note......that Napoleon hat is probably going away before it is over with......but the head gives me a starting point at least.
Maybe I am going about it all bass akwards.....but it is the way the brain wants to go. _________________
modok wrote: |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Sun Sep 06, 2020 1:59 pm Post subject: Re: Vokaro project car |
DeathBySnuSnu wrote: |
Six degree head.
... 6 degrees in addition to stock angle, or 6 degrees overall?
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Sun Sep 06, 2020 4:36 pm Post subject: Re: Vokaro project car |
didget69 wrote: |
Looks to me like 6° relative to garage floor (assuming floor is level), which would mean 6° overall; plus or minus however much that entire head will be tilted away from level after it's part of the final car. |
Posted: Sun Sep 06, 2020 5:37 pm Post subject: Re: Vokaro project car |
Six total.
And of course whatever error in the rest of the fabrication. _________________
modok wrote: |
Posted: Sat Sep 12, 2020 3:06 pm Post subject: Re: Vokaro project car |
A mock up to get some numbers.
Front and rear sub frames......now to make the middle.
And remember.....this is bottomed out..... Only up to go from here.
modok wrote: |
Posted: Sat Oct 10, 2020 10:40 am Post subject: Re: Vokaro project car |
Finally got a chance to work with it again.
Making those mock up numbers fit together.
And finally have one piece connecting it together.
Was a challenge getting it lined up.
I finally figured out that my front torsion beam had a twist to it.
Not bent....no curl or curve to it....but the top tube not in line with the bottom. I wound up cutting some factory welds and twisting the tubes in line. After that the numbers started working out.
modok wrote: |
Posted: Sun Nov 15, 2020 12:12 pm Post subject: Re: Vokaro project car |
Still working on the project.......just not much time lately.
No big work done....such as the chassis cage.
But have done some small whittling.
A chevy small cap hei distributor adapted in.
And a tps adapted on along with the map and iat.
modok wrote: |
Posted: Thu Nov 26, 2020 10:56 am Post subject: Re: Vokaro project car |
Not much time available for the larger chassis work.
It is going to be a tube chassis.
Have started on the body mount perimeter.
Once the body is where it is going to stay I will start bending tubing around it.
modok wrote: |
Posted: Thu Nov 26, 2020 10:59 am Post subject: Re: Vokaro project car |
Have worked on some odds and ends when I have a short time.
Mounts to attach the tubing too.
Painted the valve covers.
And made up the pedal assembly.
modok wrote: |
mark tucker Samba Member
Posted: Thu Nov 26, 2020 12:13 pm Post subject: Re: Vokaro project car |
oh shit!!!! I like that!!!!! I would probably shit can the vw front suspension...rear too and go with something like...pontaic solstice(3/4 scale vette stuff) I may do it to my 356, havent decided yet, and since I already have the car it's eazy to referance off of. or the rear could be from a newer car that has the aluminum arms&1 peice aluminum frame assy that bolts under the car and all suspension attachment points are fixed on it for eaxy bolt on and room for the engine too!!!!( either front engine like your or rear like mine, pleanty of room and better suspension that the vw stuff.much better. |
Posted: Fri Dec 04, 2020 8:34 am Post subject: Re: Vokaro project car |
Well.....ifin ya had a solstice.....you would already have a better "car"
This is supposed to be a psuedo racer from early 60's
So a lot of yestertech going on here.
Whittling on a pulley to re-route the belt how I need it to be.
modok wrote: |
BuggyFaron Samba Member
Joined: September 01, 2005 Posts: 441 Location: Canyon Lake, Texas
Posted: Tue Dec 08, 2020 8:21 am Post subject: Re: Vokaro project car |
This is a very cool project! |
Posted: Wed Jan 20, 2021 8:21 pm Post subject: Re: Vokaro project car |
So.....
I went with poly seats.
And even most of them were too high off the floor.
With a 3 inch drop to the floor boards the seat bottom is in the useful zone at 1-1/2 inch thick.
The cowl is just that low.
The summit g2100 seat is the lowest-thinnest and most up right sitting I could find.
I do have the original fiberglass shells that came with the body and they are really laid back....that laying on back with knees up to the cowl fit.
modok wrote: |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Tue Feb 16, 2021 11:36 am Post subject: Re: Vokaro project car |
I have not gotten much done lately......lots of work in the way.
Off work today for a snow day.
I am way down south and snow/ice/sleet is like a once in 10 year thing. So we don't have the road clearing equipment and the roads just stay frozen over until it melts.
So....no big progress.
After the mock up.... I moved the Napoleon hat back over a quarter inch, moved the tunnel over to match. Then shortened it all an inch in wheelbase.
Of course it is just tack welded together again.
The body set back on it and started fitting in some of my tubing bends
modok wrote: |
Posted: Tue Feb 16, 2021 11:52 am Post subject: Re: Vokaro project car |
I did find a reference this on the internet but very little detail.
Did find a post saying it was mid engine 550 style and had a 356 engine.
modok wrote: |
Posted: Tue Feb 16, 2021 12:21 pm Post subject: Re: Vokaro project car |
So that is a 205/40 tire....23-1/2 tall.
Drop spindles and adjusters.
Stock length shocks with the rubber bottom out snubbers so I don't over rotate the ball joints and the arms in the stock travel range.... albeit the low end of stock. _________________
modok wrote: |
