bad91teg Samba Member
Joined: February 13, 2007 Posts: 473 Location: florida
Posted: Tue Apr 07, 2020 4:17 pm Post subject: Re: mic lovin it , early 1964 bug project |
a lot of time spent prepping
finishing dog house
for some reason I really wanted to paint my alternator black . I thought about it over and over , a thousand times . black ? or stock finish ? . I wanted black and couldn't talk myself out of it ……….. and then I went on and on about taking the alternator apart and painting the inner metal cage red . but I couldn't talk myself out of that either so now the inner cage is red . lol
Posted: Tue Apr 07, 2020 4:23 pm Post subject: Re: mic lovin it , early 1964 bug project |
did the dip stick black . but inner edge mill finish
SANDED CYLINDER #`S
Posted: Tue Apr 07, 2020 4:24 pm Post subject: Re: mic lovin it , early 1964 bug project |
Posted: Tue Apr 07, 2020 4:26 pm Post subject: Re: mic lovin it , early 1964 bug project |
rolled it outside at the end the day . heres a outside pic
WADVR Samba Member
Joined: December 03, 2015 Posts: 105 Location: Carnation, WA
Posted: Tue Apr 07, 2020 11:21 pm Post subject: Re: mic lovin it , early 1964 bug project |
Those tins look great. Must have missed it but what paint are you using? _________________ - 67 Beetle Full Resto Project
- 66 Beetle “Parts Car” Project |
Posted: Sat Apr 11, 2020 4:15 pm Post subject: Re: mic lovin it , early 1964 bug project |
a lil more progress today . started with getting carb cleaned up , and mounted . then moved to air filter .
Posted: Sat Apr 11, 2020 4:18 pm Post subject: Re: mic lovin it , early 1964 bug project |
new air filter warning sticker . and then installed
Dibaltic Samba Member
Joined: May 06, 2007 Posts: 564 Location: Chambersburg, Pennsylvania
Posted: Sat Apr 11, 2020 4:51 pm Post subject: Re: mic lovin it , early 1964 bug project |
All your elbow grease is really paying off! Looking good |
Posted: Fri Apr 24, 2020 3:53 pm Post subject: Re: mic lovin it , early 1964 bug project |
more parts
tore engine back down after mock up . now when it goes back together it will have all new seals and gaskets everywhere .
Posted: Fri Apr 24, 2020 3:56 pm Post subject: Re: mic lovin it , early 1964 bug project |
putting good coat of engine paint on before install .
new rear tin . painted super gloss to match
Posted: Fri Apr 24, 2020 3:58 pm Post subject: Re: mic lovin it , early 1964 bug project |
then dei header wrap .
Costa66 Samba Member
Posted: Fri Apr 24, 2020 7:54 pm Post subject: Re: mic lovin it , early 1964 bug project |
Please turn your belt around so the lettering is facing you. My CDO sensor is going banana's!
Good build so far, keep up the good work!
Josh |
Posted: Sat Apr 25, 2020 4:33 am Post subject: Re: mic lovin it , early 1964 bug project |
ha ha lol that's too funny . that was just mocking up the motor . and I will spin it around . also ... clogged heat riser on intake . waiting on new intake from cip1 . I hope cip1 intake fits good .
klroger Samba Member
Joined: September 22, 2017 Posts: 149 Location: deep river, Ottawa Valley
Posted: Sat Apr 25, 2020 6:08 am Post subject: Re: mic lovin it , early 1964 bug project |
I used the CIP1 intake on my '66. It fit fine, but it has 2 ports for some unknown vacuum application. I wish I had removed them & welded them shut before I installed it. I just have them plugged with caps for now & it works fine... _________________ I Didn't know what to do, So I Didn't do anything!!!! |
Joined: August 31, 2013 Posts: 12816 Location: North Carolina
Posted: Sat Apr 25, 2020 6:38 am Post subject: Re: mic lovin it , early 1964 bug project |
About the header wrap, it does it's intended job, it keeps heat on the exhaust tubing. This leads to overheating the tubing & causes it to become brittle & crack. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Apr 25, 2020 11:09 am Post subject: Re: mic lovin it , early 1964 bug project |
yea TDCTDI I hear you . also possible corrosion or rust . I always ran this stuff on my sport bikes . never had a problem . those exhaust systems can be upwards of $1000 . but yea I hear you .always good to consider pros and cons of header wrap . but the real reason is I freakin love header wrap . lol. there was no chance of me not putting it on , I just couldn't stop myself . thanks again |
Posted: Sat Apr 25, 2020 11:11 am Post subject: Re: mic lovin it , early 1964 bug project |
klroger wrote: |
I used the CIP1 intake on my '66. It fit fine, but it has 2 ports for some unknown vacuum application. I wish I had removed them & welded them shut before I installed it. I just have them plugged with caps for now & it works fine... |
very good to hear and thanks for the heads up on those 2 ports . |
restocal63 Samba Member
Posted: Sat Apr 25, 2020 11:45 am Post subject: Re: mic lovin it , early 1964 bug project |
Excellent job done, those engine tins are amazing. Can I ask you what paint have you used? Thanks in advance. |
Posted: Sun May 10, 2020 9:19 am Post subject: Re: mic lovin it , early 1964 bug project |
new steering coupler
Posted: Sun May 10, 2020 9:27 am Post subject: Re: mic lovin it , early 1964 bug project |
cip1 intake came in so that allowed me to start re-assembly . I was worried about fitment issues , but it fit nice . and looked nice .
