EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Posted: Mon Jul 26, 2021 8:48 am Post subject: Re: mc lovin it , early 1964 bug project |
Yes, it's #50 if it's marked on the starter solenoid.
It's the power from the ignition switch / key (You probably know that)
I think the bottom post might only get power while the starter is cranking.
If I remember right, later VWs have another connection that goes back to the coil while the starter is cranking so the coil continues to get full battery power.
If that is true, it won't work hooked up on the bottom. _________________ How to Post Photos
bad91teg Samba Member
Joined: February 13, 2007 Posts: 473 Location: florida
Posted: Sat Jul 31, 2021 9:19 am Post subject: Re: mc lovin it , early 1964 bug project |
This wiring and electrical portion of this build is starting to interest me . I was scared of the wiring because its just alot .lol . Anyways I'm slowly understanding how the beetle is wired . I will disconnect the wiring for paint . So the latest project is getting switches and stuff cleaned up before permanently wiring after paint .
pittbull Samba Member
Joined: April 06, 2015 Posts: 41 Location: Nieuwegein, The Netherlands
Posted: Sat Jul 31, 2021 3:47 pm Post subject: Re: mc lovin it , early 1964 bug project |
Amazing project, really looking forward to it.
Keep it going! |
Posted: Sat Jul 31, 2021 4:36 pm Post subject: Re: mc lovin it , early 1964 bug project |
Pittbull thanks for that ! My vw brother lol
Posted: Sat Jul 31, 2021 5:39 pm Post subject: Re: mc lovin it , early 1964 bug project |
Posted: Sat Aug 14, 2021 12:59 pm Post subject: Re: mc lovin it , early 1964 bug project |
im told i have the original zoll plate from germany . it was a temporary plate put on the car so you could drive around germany before you exported the car . the birth certificate stated delivered in germany . so most likely a serviceman had it brought back when he came home .
i would love to hear a expert on this . i believe the first 3 numbers indacate the county for which it was issued . i had no luck looking at the birth certificate . i was trying to see were the first 3 numbers saying the same as delivered
Posted: Sat Aug 14, 2021 1:01 pm Post subject: Re: mc lovin it , early 1964 bug project |
yes the spring is red . why i have no clue . i dont know why ? silly . who knows . lol
Posted: Sat Aug 14, 2021 1:05 pm Post subject: Re: mc lovin it , early 1964 bug project |
while were in the engine compartment , i finished final wiring . i didnt like the wire connection to the alternator . i didnt know if a cover went there ? but what i choose to do was 2 of these porsche / vw boots . after that i secured the wire loom to the base with micro wire ties .
Posted: Sat Aug 14, 2021 1:07 pm Post subject: Re: mc lovin it , early 1964 bug project |
heat doors and retaining clips re painted
SORRY DARK PIC , HARD TO SEE .
Posted: Sat Aug 14, 2021 1:09 pm Post subject: Re: mc lovin it , early 1964 bug project |
cleaning more components .
Posted: Sat Aug 14, 2021 1:17 pm Post subject: Re: mc lovin it , early 1964 bug project |
lets checkout the wiper assembly . i had a seized wiper shaft or pivot . i decided to rebuild . ordered from wolfsburg west ,
Posted: Sat Aug 14, 2021 1:22 pm Post subject: Re: mc lovin it , early 1964 bug project |
love saving the original plastic hardware ! im tryin to keep this baby original as possible . hella bosch and vw lol . would like to get original distributer and fuel pump .
Posted: Sat Aug 14, 2021 1:25 pm Post subject: Re: mc lovin it , early 1964 bug project |
over the tunnel rubber floor mats . can i cut a small circle for shifter and heat knob ,then mount shifter base directly to rubber mat ??????????? in stead of a bigger hole that wound not require shifter removale for install ???
Posted: Sat Aug 14, 2021 1:26 pm Post subject: Re: mc lovin it , early 1964 bug project |
and one last trivia question . do you know what this clip is and where it goes ?
Posted: Sat Aug 14, 2021 1:31 pm Post subject: Re: mc lovin it , early 1964 bug project |
anyone direct me to or how to install the drop in 12 volt convertsion armature ? i have the bosch wiper motor but i want to research or learn how to do it . the armature is ordred |
Dake Samba Member
Joined: September 02, 2014 Posts: 481 Location: Georgia
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Sat Aug 14, 2021 2:54 pm Post subject: Re: mc lovin it , early 1964 bug project |
Quote: |
and one last trivia question . do you know what this clip is and where it goes ? |
Fuel line clamp. Round hole fastens it to the left side of the fan shroud where the engine tin screw (possibly an M6 hex-head bolt) runs through the upper portion of the left cylinder cover tin. BarryL gallery: |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
BSheldon Samba Member
Posted: Tue Aug 17, 2021 10:52 pm Post subject: Re: mc lovin it , early 1964 bug project |
Your attention to detail is awesome, really love the refurb on these switches and covers. _________________ "Betty" - 1966 L41 Sedan |
cricketseed Samba Member
Joined: August 10, 2015 Posts: 115 Location: North Carolina
Posted: Wed Aug 18, 2021 7:04 am Post subject: Re: mc lovin it , early 1964 bug project |
For your Zoll plate: I believe you're right about the first three digits being indicative of the plate's origin (specifically, the customs office).
There's a list of the three-digit codes here:
https://dr-herzfeld.de/kennzeichengeschichte/brdzoll.pdf
It looks like yours indicates Braunschweig/Brunswick. _________________ '66 Beetle |
