Aftermarket Seat Questions
SparksLP
SparksLP is offline
PostPosted: Mon Jan 06, 2020 4:50 pm    Post subject: Aftermarket Seat Questions Reply with quote
Hello,
I'm looking into different seats for my Bug, had a question on fitment. Anyone have rough measurements on seat height, width and depth that would fit in a '66? Trying to figure out what will fit on each side but not interfere with the parking brake handle or a roll cage in the future. Thanks for any info!
Tom
1966 VW Beetle Sunroof Sedan (Sold)
Bryan67
Bryan67 is offline
PostPosted: Mon Jan 06, 2020 8:27 pm    Post subject: Re: Aftermarket Seat Questions Reply with quote
There's lots of options. Try Corbeau, Recaro, TMI, Scat Pro Car for starters
If you`re going to do something, do it right.
WesleyGarrard
WesleyGarrard is offline
PostPosted: Tue Jan 07, 2020 8:58 am    Post subject: Re: Aftermarket Seat Questions Reply with quote
Here was what I came up with for new seats in my Beetle.
I am really happy with them. I have been able to actually see how well the car handles because now the seats hold me in place. The original seats had me sliding all over the place during autocross no matter how tight my harness was. They are EMPI Roadster seats that I dyed grey with SEM vinyl dye. After a few years, they have been holding up pretty well.
SparksLP
SparksLP is offline
PostPosted: Tue Jan 07, 2020 4:00 pm    Post subject: Re: Aftermarket Seat Questions Reply with quote
Wesley,
I've watched you videos before, you did great work on those seats! Do you have extra room on each side? I can get the dimensions for those seats online so I can make a rough guess as to max width for when I'm shopping around. Thanks!
Tom
Chickensoup
Chickensoup is offline
PostPosted: Tue Jan 07, 2020 4:32 pm    Post subject: Re: Aftermarket Seat Questions Reply with quote
i kind of want to know about this too. anyone ever fitted seats similar the the bmw e30 sports ones?
Jos.Hall
Jos.Hall is offline
PostPosted: Tue Jan 07, 2020 8:28 pm    Post subject: Re: Aftermarket Seat Questions Reply with quote
A lot of people have! BMW e30 sport seats are technically Recaro LS-c seats. If you do a search on here for recaro seats you should find plenty of examples. The other alternative that looks really good and is cheaper is the scat procar seats. They look very much like recaro seats.
Real MK2 vw GLi Recaro seats in a bug (using scat mounts)
Not a fan of the white myself but these are the Scat Procar Elite seats
Recaro seats (not e30)
Scat seats
PM ME TO ADD YOUR '67 TO THE '67 BUG REGISTRY!!!!
https://vintagejalopy.com/67bugregistry/vwbugregistry1967_view.php
'67 L41 Sedan 117333192
'67 L41 Vert 157343589
'67 L19K Vert 157452166
'67 L19K Vert ??????
'67 L282 Vert 157419653
'67 L620 Sedan 117534350 (Sold)
'67 L54 Vert 15745800 (Parted out)
'52 Split based Devin
WesleyGarrard
PostPosted: Wed Jan 08, 2020 12:56 pm    Post subject: Re: Aftermarket Seat Questions Reply with quote
SparksLP wrote:
Wesley,
Here are the dimensions I found. Would be good for you or anyone else considering the roadster seat.
https://static.speedwaymotors.com/pdf/EMPISeatDimensions.pdf
I do have more room. If I recall, these are 1.25" narrower that the stock seats. So an extra 5/8" on each side. Not a ton of room. But it does make reaching for the parking brake easier.
One thing I did notice. These seats on factory sliders are shorter than a stock seat. But, since they do not have springs, they do not collapse as much when you sit on them. So you sit a little bit higher than normal.
But they are really comfy. I have done a few hundred mile road trips in it without a sore backside.
SparksLP
SparksLP is offline
PostPosted: Wed Jan 08, 2020 8:27 pm    Post subject: Re: Aftermarket Seat Questions Reply with quote
WesleyGarrard wrote:
SparksLP wrote:
Wesley,
That helps a ton! Thanks for your feedback!
Tom
slalombuggy
slalombuggy is offline
PostPosted: Wed Jan 08, 2020 8:34 pm    Post subject: Re: Aftermarket Seat Questions Reply with quote
My Scat Procar seats in my 57 lots of room even with the cage and they sat on the floor
whatthehucks
whatthehucks is offline
PostPosted: Wed Jan 08, 2020 9:22 pm    Post subject: Re: Aftermarket Seat Questions Reply with quote
SparksLP wrote:
Hello,
I have some Scat procar low back I would be willing to trade for some good condition stock low back seats Smile
oldmanmark
oldmanmark is offline
PostPosted: Sun Jan 12, 2020 11:01 am    Post subject: Re: Aftermarket Seat Questions Reply with quote
What i would do is take the dimensions of the stock seats for reference and start from there. How tall , wide, seat depth and surface width . How much do they clear the door when closed, distance between each other, etc. etc. Then you can gauge what replacement seats will fit. I took my stock seats cut and welded the frame to fit my body seat position. Then fabricated the seat back frame to lay back further still using the stock recline adjuster on the 63 seat frames. Reupolsterd with foam cut to form fit my ass nicely. Even did away with the saggy springs in the process. Long time ago i fabricated custom wheelchairs for a brief time. Kinda same thing.
its all up to you and me to make it better...
pondoras box
pondoras box is offline
PostPosted: Sun Nov 09, 2025 10:41 am    Post subject: Re: Aftermarket Seat Questions Reply with quote
Old thread revival but that you for posting this! Opens a whole new world of seat options and not having to drill holes in the pan to mount them.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
zerotofifty
zerotofifty is offline
PostPosted: Sun Nov 09, 2025 10:47 am    Post subject: Re: Aftermarket Seat Questions Reply with quote
I have Honda DelSol seats in my VW kit car, fits well. Plenty narrow for the parking brake and tunnel. Mine makes use of the Honda DelSol seat slider tracks, removed the stock VW slider tracks. Bolt in the Honda DelSol tracks.
My floor pan is a flat plate however, not the stock VW pan half.
Take a trip to a wrecker like Pick N Pull or such, bring a tape measure and see what will work by measurement.
Small cars are your best bet as a source of small seats.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
Bobs67vwagen
Bobs67vwagen is online now
PostPosted: Sun Nov 09, 2025 10:48 am    Post subject: Re: Aftermarket Seat Questions Reply with quote
Are any of the vendors currently selling adapters to mount bmw e30 recaro into a bug?
