gbrandt Samba Member
Posted: Thu Jan 09, 2020 6:07 am Post subject: Propex at 3.2f (-16c) does not keep van warm |
Hi,
I have a propex HS2000. I just had it serviced by propex in England. With no other changes done it’s just not throwing the heat like it used to. In near 0f temps it keeps the van at 50f. That’s with window insulators, top down and minor insulation on the roof. What temp can you go down to outside and keep 70 in the van? What could my problem be?
Thanks
Gregor _________________ 'Lucky' our 1987 Red Westy, ASV 1.9 TDI ~130HP, Peloquin differential (had a GW 2.3 that we loved, but it died, we drove it hard!)
We've driven in 49 countries and 5 continents to date
Canada to Argentina and back, 2015 to 2017.
Canada to Europe and back (including Turkey, Morocco and Iceland), 2017 to 2019
Mexico 2022-2023
https://www.instagram.com/live.travel.play/
http://livetravelplay.ca |
danfromsyr Samba Member
Posted: Thu Jan 09, 2020 7:53 am Post subject: Re: Propex at 3.2f (-16c) does not keep van warm |
6ooo btus do have a comfort vs temperature (wind+temp) limit..
I opted for the HS2800 @ 9ooo btus..
close your door vents or if a later model cover your rear window vents..
and shut down the front dash fresh air inlet.
but to want to reach 70* I'd say nothing below 32* for a 6ooo btu heater. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3802 Location: VA/TN
Posted: Thu Jan 09, 2020 11:01 am Post subject: Re: Propex at 3.2f (-16c) does not keep van warm |
^ I installed snaps in this area and put snaps on a harbor freight moving blanket. Reflectix 'floating' between curtain and glass for the rest of the windows - except slider door.
At 32 degrees outside with a 5k CDH heater - I got the van to 92 degrees!!
This was just for fun. I don't sleep at that temperature. _________________ Brandon
Instagram @joannthevan |
Posted: Thu Jan 09, 2020 11:04 am Post subject: Re: Propex at 3.2f (-16c) does not keep van warm |
5Kw chinese heater is ~17ooo btus... nearly 3times as much as a propex2000 |
Irishcalifornian Samba Member
Joined: September 08, 2016 Posts: 167 Location: CaliWestyfornia
Posted: Thu Jan 09, 2020 11:28 am Post subject: Re: Propex at 3.2f (-16c) does not keep van warm |
I have to leave my poptop down with my propex or space heater. heat goes through the tent like a cheese cloth.
There are insulators for the tent but they're a pain in the ass to apply for a one nighter. |
jordauto Samba Member
Joined: August 12, 2011 Posts: 218 Location: Sorrento,BC
Posted: Thu Jan 09, 2020 3:16 pm Post subject: Re: Propex at 3.2f (-16c) does not keep van warm |
Is your LPG tank full? The propane doesn't boil off into gas that you can burn very well at colder temperatures. Also the regulator can freeze up and not supply enough pressure or maybe volume. Have you tried lighting a burner on the stove when the Propex is going? Does it seem to have a normal flame. Our Propex always kept us warm at those temps with the top down of course. You said you had it serviced, was there any issue with it before the service, and do you know what they did during the service? Welcome back to cold Canada! |
Posted: Thu Jan 09, 2020 4:43 pm Post subject: Re: Propex at 3.2f (-16c) does not keep van warm |
Sorry, didn't mean to go off topic - was trying to emphasize Dave's recommendation of blocking off front of the cab. _________________ Brandon
Timwhy Samba Member
Abscate Samba Member
Posted: Fri Jan 10, 2020 4:32 am Post subject: Re: Propex at 3.2f (-16c) does not keep van warm |
50F camping! That’s a heat wave! _________________ .ssS! |
