markf1 Samba Member
Joined: September 21, 2019 Posts: 286 Location: Telluride, Colorado
Posted: Fri Jan 10, 2020 1:48 pm Post subject: Blown Viscous Coupling? |
We have been doing lot’s of work on our 1986 Syncro. Most recently very expensive transaxle rebuild and re install with new clutch and etc. You can read about all that here if desired:
https://www.thesamba.com/vw/forum/viewtopic.php?t=727120
Now I’m getting a strong sense that the VC is not working.
Forum member Sodo recommended the following test:
Here's an easy home test that gives an idea if the VC is OK.
Couple it.
Jack up the right front tire an inch off the ground.
Other 3 tires on-ground.
Neutral or any gear, it doesn't matter.
It should be very difficult to rotate the wheel slowly by hand.
It should feel like there is a component in the driveline that behaves like a stack of alternating discs with some viscous goo between them.
....a "Viscous Coupling."
Your front wheels are driven by goo.
If the raised front wheel spins rather easy, look to see if your driveshaft is turning.
If the driveshaft is turning, then you are decoupled (= 2wd).
If the driveshaft is NOT turning, then your VC is shot.
So I just did that. Not sure if it matters but it’s pretty cold out right now, single digits F. I jacked up the front right wheel and it is difficult/stiff to rotate by hand but totally doable. When turning the wheel there is a very slight amount of free turn and I can see the drive shaft rotate ever so slightly. Then it “catches/engages” and the wheel becomes difficult to rotate. It does rotate with resistance, but I can rotate,it with one hand. While rotating the wheel the drive shaft DOES NOT turn. So... sounds like blown VC. Dang x10.
Questions:
1) is there any problem driving around with blown VC? Seems like it just means we only have rear wheel drive and maybe are losing some power and fuel efficiency by having he VC turning from the drive shaft but not actually working.
2) options are do nothing, replace VC or put in de-coupler?
3) Does a de coupler replace the VC or would de-coupler still require that the VC be working properly?
TIA for any advice and guidance. _________________ 1986 Westfalia Syncro
2.1 L Waterboxer
Some Westy supported adventure photos:
https://www.openrangeimaging.com/adventure.html |
tencentlife Samba Member
Posted: Fri Jan 10, 2020 2:12 pm Post subject: Re: Blown Viscous Coupling? |
I don't know how you conclude it's bad, your test shows the VC is OK. You should be able to turn the tire slowly and steadily against a constant resistance at low speed, which increases markedly if you try to turn it faster. Ambient temp has no palpable effect on this. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
markf1 Samba Member
Posted: Fri Jan 10, 2020 2:37 pm Post subject: Re: Blown Viscous Coupling? |
Hi tencent and thanks for you reply.
I think it’s bad based on the test recommended by Sodo in my post above.
“If the wheel turns but the drive shaft doesn’t your VC is shot”
Maybe I’m misunderstanding. He does also say “if the raised wheel spins rather easily” which is not the case. The raised wheel spins but with significant resistance.
So the raised wheel spins but not rather easily and the drive shaft does not turn. Is this an indication one way or another if the VC is working properly or not.
Also note - We do not have a de-coupler on the van.
Thanks! _________________ 1986 Westfalia Syncro
2.1 L Waterboxer
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Fri Jan 10, 2020 2:38 pm Post subject: Re: Blown Viscous Coupling? |
Another test is to put 2 x 4 in front of your front tires. Like a wheel chalk. Then put a jack under the rear with the wheels of the jack inline with the vehicle. Only just barely lift the rears off the ground. Try to drive forward. If it climbs over the 2x4 you have a working VC. If you just sit there with the rears spinning in the air and no drive transferred to the fronts, bad VC. _________________ Steve
Steve's 87 Syncro project |
markf1 Samba Member
Posted: Fri Jan 10, 2020 3:08 pm Post subject: Re: Blown Viscous Coupling? |
Thanks Steve. We also were given that second test instruction. In our case, we don't have a floor jack or pavement. And any pavement around us is snow covered and icy at the moment.
We are ultimately taking the van to a mechanic. He is experienced with synchros and says he can determine if the VC is working by putting it up on a lift and seeing if all the wheels turn. I don't quite understand how that would work, but he definitely knows alot more about this than I do.
So, I did the one test I could as posted above. Raise right front wheel......etc.
Still uncertain about status of our VC _________________ 1986 Westfalia Syncro
2.1 L Waterboxer
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Fri Jan 10, 2020 3:31 pm Post subject: Re: Blown Viscous Coupling? |
You misunderstood what Sodo meant in the front wheel lifted test so you drew the wrong conclusion.
Read what tencent then wrote, but closely.
The wheel should turn by hand, but only slowly.
If you try to make it turn faster, it SHOULD NOT speed up much if at all.
It should get harder to turn when you try to make it spin faster.
You need a new mechanic if he really thinks he can test the VC with all 4 wheels in the air spinning.
Mark
markf1 wrote: |
Still uncertain about status of our VC |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17154 Location: Retired South Florida
Posted: Fri Jan 10, 2020 3:35 pm Post subject: Re: Blown Viscous Coupling? |
If the rear wheels are on the ground, I'm having a hard time imagining the driveshaft between the front and rear turning when you turn one jacked up front wheel. Its been a long week.
There is no problem running the van with the VC not operating as designed, but obviously you won't have the 4wd effect.
Seems from reading most VC's seem to stiffen with age. I don't have the experience to say one way or the other.
I serviced my VC and the only test I did after was the 2x4 test. I realize you don't have a place to do that, but it sounds like you need to find a shop familiar with your unique ride and build a relationship when you can. _________________ ☮️ |
Posted: Fri Jan 10, 2020 3:41 pm Post subject: Re: Blown Viscous Coupling? |
Sodo said this:
If the driveshaft is NOT turning, then your VC is shot. |
but from that you needed to extract these in isolation:
If the driveshaft is NOT turning AND the raised front wheel spins rather easy, then your VC is shot.
You broke his logic by forgetting the premise "wheel spins easily" which had not been vacated.
You also established that there is a bit of free rotation at the wheel before you encounter resistance, this will be the same in either direction and can be ignored, it's the normal. What you are trying to gauge is the amount of resistance after the free play is taken up.
Your VC sounds fine. Once you establish that the front wheel can be turned slowly against steady resistance, the key test is then to try to turn the wheel faster and harder. This is best done with a long breaker bar and socket on the wheel hub nut instead of handling the tire, so you can exert some real force all at once. You can do it with the tire, it's just harder to gauge. By exerting strong turning force as fast as you can, the tire should become markedly more difficult to turn, the harder and faster you try to turn, the harder it resists. Mess around with it and feel how the resistance changes. If you have a long breaker bar, like at least 2 feet, and push on it as hard as you can all at once, it should feel almost as if you met a hard stop.
There's nothing that can be proven by putting it on a lift and running it in gear. Whether the VC is overly stiff, normally compliant, or totally wasted, the front wheels are going to spin in free air. Only by resisting the front wheels spinning can the efficacy of the VC be judged, and that would be unwise to try on a lift. The aforementioned 2x4 climbing test is a fair method to assess it if you want to go farther than the one-wheel-jacked-up test.
And I see Mark has covered the same ground already... _________________ Shop for unique Vanagon accessories at the Vanistan shop:
markf1 Samba Member
Posted: Fri Jan 10, 2020 4:09 pm Post subject: Re: Blown Viscous Coupling? |
tencentlife wrote: |
Sodo said this:
The aforementioned 2x4 climbing test is a fair method to assess it if you want to go farther than the one-wheel-jacked-up test. |
You guys are great. Thanks tencent and others.
Agreed. As you say, I misunderstood (typical) or failed to include an important part of Sodo's instruction. The front wheel DID NOT spin rather easily. So, maybe the VC is OK and I'm now encouraged. I just talked to a friend and he has a floor jack we can use. It may be possible to drive into the heated underground parking garage at the Library and do the floor jack test there. I'll see if we can get that done in the next day or two and report results. Thanks again! _________________ 1986 Westfalia Syncro
2.1 L Waterboxer
Posted: Fri Jan 10, 2020 6:37 pm Post subject: Re: Blown Viscous Coupling? |
If you have both front wheels up in the air and turn one wheel the other will just turn in the other direction unless you have a differential lock that is engaged. The driveshaft will not turn. If you only have one wheel up in the air the driveshaft still isn't going to turn unless you have a decoupler. With one wheel in the air you should feel the resistance others are speaking of.
If you make a full lock turn on dry pavement it will probably feel like the brakes are lightly on if the VC is working. If the brakes feel locked or nearly so your VC is applying too much torque. |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1002 Location: Oakland CA
Posted: Fri Jan 10, 2020 11:08 pm Post subject: Re: Blown Viscous Coupling? |
Quote: |
any pavement around us is snow covered and icy at the moment |
This sounds like the perfect condition for testing the VC. How about having a friend watch the wheels while you try to spin out on the ice. Better yet have that friend slow motion video your efforts, and watch for the front wheels turning faster than the van is moving, cause you are slipping on the ice.
Also, if the VC has failed, its possible that the seals have failed, allowing silicone goo to mix with the gear oil, and reduce the lubrication to the bearings.
_________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
markf1 Samba Member
Posted: Sun Jan 12, 2020 9:03 am Post subject: Re: Blown Viscous Coupling? |
We did the test with the floor jack. First I got her stuck backing out into the alley. It's pretty slippery out there at this pint but not glare ice. the middle zone between where the wheels of vehicles travel is also a bit soft. My 4x4 toyota was slipping around a bit but i realized I had not locked in the front hubs, duh. FWIW our subaru outback and my toyota can drive in and out of the parking/alley OK.
Once I got the van stuck GF watched wheels. Only one back tire was spinning most of time. We tested the differential locker and it definitely works and got both back wheels spinning. Front wheels never spun.
Pulled the van free with my truck and drove into underground parking garage to do the floor jack test. Reasonably flat area but broom finished concrete versus a smooth troweled surface like you might find in a shop. So more friction and rougher surface that a typical shop floor. Also borrowed floor jack was a small unit with small wheels.
Not sure any of that matters too much. Got the rear wheels jacked up off the pavement with the floor jack. Jack and jack wheels oriented same as van so it would roll correctly. Flat 2x4's on pavement in front of each front wheel. Van at idle in Granny gear, clutch out no movement, one rear wheel turning. Give it some gas, no movement, other rear wheel now spins to some extent. Engage differential lock just to further test. Both rear wheels turn same speed give more gas, van never moves. Front wheels never engage and pull van over 2x4's. It appears VC is not working correctly.
We have read that GoWesty doesn't even sell VC. They don't like them and recommend replacing with solid shaft and decoupler. Have read diverging opinions on this. We are inclined to either have ours rebuilt or replaced and get a working VC going again. We also do not think we need a decoupler. We pretty much never drive in town, generally on hiways to and from back roads.
Some questions.
1) Best to look for new VC or rebuilt VC? Or alternately maybe rebuild the one we have?
2) Is it possible to have a VC and a decoupler? Or is it such that if you add a decoupler then you must replace the VC with a solid shaft?
2.1 L Waterboxer
Posted: Sun Jan 12, 2020 9:19 am Post subject: Re: Blown Viscous Coupling? |
glad you figured this out. Van stuck in the snow with front wheels not spinning was your VC test. don't bother installing decoupler, and yes you can have VC and decoupler. with solid shaft a decoupler is required. new VCs are gone. _________________ 1987 Syncro Westfalia, stock (bought 1994)
Escorial Syncro Samba Member
Joined: May 02, 2004 Posts: 437 Location: Manitou Springs, CO
Posted: Sun Jan 12, 2020 10:40 am Post subject: Re: Blown Viscous Coupling? |
I live in snow country and a syncro with a functioning VC would be my first choice. Snow conditions seem like what this rig with a VC was designed for. When a VC is working properly it makes the van a monster in snow and ice, no need to pull knobs, it seemlessly transfers power. It's a perfect simple system that just works! Plus I think the van feels more solid on the dry highway with the stock VC system comparted to driving uncoupled. But that's just my opinion. If you search this site there are many many opinions, so there is no "right" answer, just the one that works best for you.
I think if you live near the ocean and do a lot of driving on sand a decoupler/solid shaft probably makes more sense.
Also keep in mind, some decouplers do wear out, so can be another wear item. And in my experience, I think five out of the six decouplers I have installed leaked in the first year or two of service from the actuator which I found to be a bummer.
I was glad to see the OP do the VC tests on snow and then with the rear jacked up. The jack test is the most simple, most definite, the only one I trust.
Van Cafe sells rebuilt VCs. But good luck in whatever you decide.
Joel _________________ Joel Lane
1985 Vanagon converted to syncro, ALH TDI, Reimo Primus top with Westy interior
2002 Toyota Tundra 4x4
1974 Honda CL360 Scrambler (for sale!)
Last edited by Escorial Syncro on Sun Jan 12, 2020 10:44 am; edited 1 time in total |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9615 Location: Western WA
Posted: Sun Jan 12, 2020 10:43 am Post subject: Re: Blown Viscous Coupling? |
I agree with Escorial Syncro's opinion on the Syncro AWD system.
I drove decoupled a few times.
It was a waste of a Syncro, and a waste of the "Syncro tax".
Cool markf1, glad I was able to help
I passed on knowledge that I have gathered from lots of other Syncro enthusiasts.
And what you did markf1, was create a thread with a proper, searchable title,
then quickly and methodically, tested your VC with first the "easy home test"
then the "more definitive 2x4 chock test".
And you contributed a real-world test too, (ice in your alley), a real treat!
I bet you have helped many Syncro owners to understand their VC better,
in this one example, than years of rambling, 45-page VC threads..
Because you came at it from a novice POV, with eyes wide open.
As opposed to the "expert POV" that often confuses everyone.
....as I usually do (and sometimes myself, 'cuz I'm no expert).
It's a little funny how, once you understand the system, how simple it is.
I remember when it was a puzzlement, and the more people you asked, the more confusing it became.
Because everyone had different ideas of how it worked, it added lots of confusion.
Kinda like our society with the introduction of social media.
We have more information than ever before, yet we are more confused than ever before
by the volume, and inability to vet our sources.
We don't even care who the source is anymore.
As one sage Syncro member has in her sig-line: "the information age has morphed into the age of willful ignorance".
Don't judge too harshly a mechanic, who doesn't understand the (simple) Syncro drive system. It seems that few people do.
But a mechanic who reads THIS thread should understand it.
GoWesty, who clearly understands practically EVERYTHING about Vanagons,
won't warranty their (Syncro) transmission rebuild unless a decoupler is installed.
GoWesty further encourages the Syncro owners to drive decoupled in 2WD, to preserve the Syncro transaxle.
I don't know if I should say GoWesty doesn't understand the Syncro system, but their recommendation cannot possibly preserve the transaxle.
Decoupled in 2WD will preserve the VC, but not the transaxle.
Yall probably know my advice to GoWesty... to preserve a transaxle, focus your customers on preserving lubricity....(otherwise known as "maintenance"). _________________
....KTMs, GasGas, SPOT mtb |
markf1 Samba Member
Posted: Sun Jan 12, 2020 11:22 am Post subject: Re: Blown Viscous Coupling? |
thanks Sodo and everyone else. I can't overstate the value of your input and advice.
I have found only 1 place to buy a rebuilt VC. German Transaxle of America. $495. Their site is odd in that you can't add the item to a shopping cart and buy it. I guess you need to call them to purchase.
I have been advised of a used one that apparently needs new seals and fluid $440. I can't seem to find anywhere to price/purchase the seals and fluid.
Our plan at this point is to get a workign VC installed and forgo a decoupler.
2.1 L Waterboxer
Sodo Samba Member
Posted: Sun Jan 12, 2020 11:53 am Post subject: Re: Blown Viscous Coupling? |
German Transaxle probably wants to open up your VC first, to see if it's a rebuildable core. VCs are unobtanuim, nobody just tosses them out.
Sodo wrote: |
Decoupled in 2WD will preserve the VC, but not the transaxle. |
Other details... A decoupler is a worthwhile accessory for those who like to be "prepared".
The first two conditions below would destroy the ($495/unobtanium VC) in minutes.
1) Allows you to drive the van with an "off-size tire" fitted.
2) Allows the van to be "towed" with front or rear wheels stopped (old-school towtrucks). But where do they have these old-school towtrucks? Mexico?
3) Decoupler allows completion of a dash ornament and activates a dash light too.
4) You can decouple to 2WD from time-to-time, to compare the driving difference, to reassure yourself that the thou$and$ you $pend on the $yncro tax is "worthwhile". The difference is especially apparent on gravel, somewhat on windy days. And in snow, of course!
There are other interesting things you can do with the ability to "decouple".
You can decouple and try to "skid" your rear tires on gravel, to test your "emergency brake".
You can jack one wheel off the ground and rotate the wheel or the driveshaft (when working on the van).
You can periodically “test” decoupling to keep it all lubed & limbered up. Decouplers don’t normally gum up like the rear axle locker, but might as well exercise both. This provides a valid “excuse” to show a passenger your special “Syncro Club” dash lights spectacle. Dutiful GF, who sat in the rear to allow you regale this new passenger, rolls her eyes.
A decoupler is NOT a requirement.
But it is for me......'cuz I'm committed.... _________________
Posted: Sun Jan 12, 2020 8:32 pm Post subject: Re: Blown Viscous Coupling? |
If you have a decoupler, no one is forcing anyone to use it. It is just one more option for self recovery, I like the idea of making it home so I can do repairs on my own schedule and dime verse paying some mechanic in god knows where to learn about an obscure vehicle he may never work on or even set eyes on again. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Mon Jan 13, 2020 7:12 am Post subject: Re: Blown Viscous Coupling? |
I find the decoupler worth buying for around town driving where there are tight turns into parking spaces. Seems to take a lot of stress off the front differential doing routine driving in town, but that's just my opinion.
There is some very good reading on VC's on the Tech Links of Syncro.org as well as a lot of other useful info.
http://syncro.org/how-to-fix-a-vw-syncro/ _________________ This free advice is worth exactly what you paid for it.
Posted: Mon Jan 13, 2020 1:27 pm Post subject: Re: Blown Viscous Coupling? |
I have the rebuilt "sport" VC from AA trans. Seems like it was under 500 bucks. It works great. No decoupler, and no symptoms of "sport" or drawbacks.
My original VC was a fairly stiff and aggressive one. Then it failed open with no front drive. _________________ Steve
