pechaaa Samba Member
Joined: July 05, 2017 Posts: 38 Location: Europe, Latvia
Posted: Thu Feb 20, 2020 12:27 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
How is the build going?
Dismantling my engine this weekend |
akmush Samba Member
Joined: January 16, 2012 Posts: 276 Location: Fairbanks, AK
Posted: Thu Feb 20, 2020 10:25 pm Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
Pechaa, work has gotten in the way recently. I bought some angle steel to build a tool to hold the crankshaft so I can remove the bolt. Want to try to get that done this weekend. Also just received my custom oil pump bracket.
Posted: Fri Feb 21, 2020 7:41 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
Do we really need to remove crankshaft-to change positon of crank sensor wheel?
Probably will dismantle my engine tomorrow and find my question somewhat stupid |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Fri Feb 21, 2020 8:57 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
pechaaa wrote: |
yes |
foodeater Samba Member
Joined: July 13, 2007 Posts: 1318 Location: Newburgh, NY
Posted: Fri Feb 21, 2020 9:02 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
akmush wrote: |
Awesome, I was just about to send you a message to see if it arrived. _________________ 89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP |
akmush Samba Member
Posted: Sat Feb 22, 2020 12:12 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
Attempted to remove crank pulley bolt tonight. Bent the angle steel that I used as brace to hold engine from turning and messed up threads on pulley .
akmush Samba Member
Posted: Sat Feb 22, 2020 12:18 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
Tried Milwaukie M18 High Torque 1/2 " Impact wrench with no luck as well. Suggestions?!
Thinking of going to local tire shop with socket tomorrow and paying them to put their big air wrench on it. This thing is really torqued on there... |
Tvättbjörn Samba Member
Posted: Sat Feb 22, 2020 12:47 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
akmush wrote: |
if the bolt is torqued to factory specs you will need at least a 3 ft long breaker bar and a heavy duty bracket with a long lever to bolt onto the crankshaft gear. Be sure to get a new bolt and torque the crankshaft bolt to factory specs. I have seen those bolts come lose when not torqued correctly! Do not use an extension when removing or tighten that bolt. I have broken extension and sockets ( cheap and expensive tool truck brands) while removing that bolt. It is worse on a diesel.
Not two many impact guns have the power to take off that bolt. The factory tool is not a flimsy angle iron. It looks like a horse shoe with a long handle on it. It is 8 or 10mm thick metal. Do a search and you might find a picture of it. VAS 3415
Posted: Sat Feb 22, 2020 12:52 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
one gear / bolt hole looks damaged. You have to use two 8mm bolts ( 180 degree apart ) and tighten the bolts to 20Nm. Otherwise the thread will get damaged. |
Posted: Sat Feb 22, 2020 5:59 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
I use a good 3/4” impact gun and socket to remove those bolts. You can take your crank to a local shop and pay them a few bucks to zip that off for you. |
Posted: Sat Feb 22, 2020 10:00 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
Just wondering about all that engine modification to make it work. Would it not be easier to flip the ring gear / diff unit in the transmission or is it not possible due to space? What speaks against it? |
Posted: Sat Feb 22, 2020 1:06 pm Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
Tvättbjörn wrote: |
It’s not possible with these transmissions. |
akmush Samba Member
Posted: Sat Feb 22, 2020 4:36 pm Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
Should have followed your advice from beginning Andrew. Nice tech at local tire shop used his Mac tools 1/2 " air impact and spun it right off. Didn't charge me either. Tear down resumes... |
akmush Samba Member
Posted: Sat Feb 22, 2020 7:51 pm Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
Getting ready to remove pistons for notching and remove crankshaft in order to fix crank sensor ring. I understand that I will leave pistons attached to connecting rods and know to mark pistons for replacement in correct order.
Looking for any tips about removing rod bolts and dropping pistons. This is new territory for me
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Sat Feb 22, 2020 8:49 pm Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
Keep the caps and rods together as sets and make sure the cap orientation is correct. Paint markers are handy for this. |
Posted: Sun Feb 23, 2020 12:27 pm Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
We are at the same point right now.
Dismantled mine this weekend.
I'm also thinking- which bolts I will buy new (as some of them must be strech bolts- use only one time) |
akmush Samba Member
Posted: Mon Feb 24, 2020 12:22 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
Tear down is finally complete! First I pulled the pistons and rods through -
Then out came main bearings and crankshaft. (#3 came out with crankshaft). There are "shims" on either side of #3 on the crank.
Everything labeled-
akmush Samba Member
Posted: Mon Feb 24, 2020 12:27 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
#1 crank bearing has noticeable scratch. All others look smooth. Andrew you had suggested I reuse. What do you think of this?
Posted: Mon Feb 24, 2020 9:32 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
akmush wrote: |
I'd run it but I'm sure there are many who would disagree with me. |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10367 Location: Sunshine Coast B.C.
Posted: Mon Feb 24, 2020 9:40 am Post subject: Re: Alaskan 85 Weekender, 1.8T (AWM), 5 speed conversion |
akmush wrote: |
Then out came main bearings and crankshaft. (#3 came out with crankshaft). There are "shims" on either side of #3 on the crank. |
Just a point of curiosity, but did you measure crank end play before tear down? Would be worthwhile doing when crank et al is back in.
Could't recall off the top of my head but since a new set of bearings comes with thrust washers ("shims"), I'm certain I replaced mine. But I guess if yours don't look worn or damaged, ok to re use? Personally, I'd replace the crank and rod bearings or at minimum the rod bearings.
You probably have pics of this but in case you don't....
It might seem obvious from an oiling stand point but thrust washer orientation: grooves face outward toward cylinder bores:
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
