Column Rebuild
Page: 1, 2, 3  Next
Clatter
Clatter is offline
PostPosted: Sun Jan 12, 2020 3:18 pm    Post subject: Column Rebuild Reply with quote
Digging in to rebuilding a column, it seems that there isn't one place where all info can be found.
Since I'm a newb to this, thought I'd try to compile what's what with these things.
Additionally, it -seems- that my column has never been taken apart from new.
So here we go..
Hoping our experts can chime in, and we can get one place for the whole story.
After digging around on the site here,
These threads all had good info:
https://www.thesamba.com/vw/forum/viewtopic.php?t=608438&highlight=column
https://www.thesamba.com/vw/forum/viewtopic.php?t=584876
https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=480
https://www.thesamba.com/vw/forum/viewtopic.php?t=548050&highlight=column
Big thanks to all of our posters here who have contributed their time and knowledge.
Wiring diagram, for reference:
First thing I learned, is that you're best off getting the column off and free from the car.
This is easy and straightforward; undo the bolts and take things apart.
Additionally, remove the pinch bolt and slide the column head free from the tube.
The spade terminals pull free to allow the wires to be disconnected from the wiring block,
Which is held with these two screws:
Once the wheel and horn whatnot is off,
There is a half-clip holding the main steering shaft in place,
Shown hiding behind the shaft,
As well as a spring, and a split spacer/backup washer thingie at the bottom of the spring.
The turn signal switch assembly comes off with a couple of screws,
But when you pop it apart, this little spring and it's two round seat pieces might try and fly away..!
They are supposed to be contained like this:
Underneath all that you'll find an internal circlip snap-ring,
As well as an external flat snap ring.
Mine had two thin spacer washers beneath.
Any fool can take things apart (you'd think),
But i got about this far before running into a few questions.
I'll put this intro up to here,
And we'll proceed with individual issues in separate posts..
Bus Motor Build
What’s That Noise?!?
Clatter
Clatter is offline
PostPosted: Sun Jan 12, 2020 3:43 pm    Post subject: Re: Column Rebuild Reply with quote
Many might be inclined to leave this whole thing together.
Looking again at it, that would be a great plan,
However,
By car had a problem with "Old Crispy" the big black power wire coming from the coil + side.
In my case, a PO had (poorly) re-wired the idle cut-offs and choke elements,
Which were also taken off the coil + side.
These got tangled up with the carb linkage and shorted out, melting Old Crispy in the process.
Old Crispy is NOT protected by a fuse! Mad
It also has the back-up light circuit attached, as well as being a clever place for a PO to find a hot power source,
So it's not just VW being lazy this way. Wink
This wire being melted is not uncommon.
I'm already replacing the main harness,
but,
You'll see our friend here naked of his insulation..
So this means that our column wiring must be pulled for inspection..
While i might be able to get away with just replacing that one wire,
A 50-year-old anything would likely love a cleaning/inspection/sussing/lube.
I know i sure would.. Wink
So how to get the thing apart?? Think
Factory has this to say:
They seem to like the solder melted at the terminal block here, right?
Leaving these square ones at the cylinder connected..
Column King 'ataraxia' here has suggested leaving the wires at the block connected,
And unsoldering the squares?
I'm a bit skeered of getting fragile bakelite parts too hot..
Here in Monte's great build thread,
he did this after the lock cylinder was apart..
Ssoooo...
How to best pull all of this wiring apart? Question
Bus Motor Build
rustyfastback
rustyfastback is offline
PostPosted: Sun Jan 12, 2020 6:44 pm    Post subject: Re: Column Rebuild Reply with quote
I have rebuilt at least 15 of these columns. My experience if the wires are melted like the ones on your column, just un-solder them at the back of the ignition switch. If they are in good shape it is very tricky removing the ignition switch while carefully extracting the wires from the column (very tight space for wiring). The bakelite part is more likely to come apart leaving the wires attached. Make sure to test that ignition switch as I have seen several with burnt wires that are non functional. Also the gray wire is only for a euro spec car. I can see in the photo the signal arm & wire terminal block on your column is for a USA spec, so just leave the gray wire out.
axeman569
axeman569 is offline
PostPosted: Sun Jan 12, 2020 9:16 pm    Post subject: Re: Column Rebuild Reply with quote
Nice. Getting ready to put one back together>
t3kg
t3kg is offline
PostPosted: Sun Jan 12, 2020 9:20 pm    Post subject: Re: Column Rebuild Reply with quote
If you're a member of the VW Type 3 group on Facebook you can check out Lionel Mendoza's step-by-step column rebuild tutorial: https://www.facebook.com/groups/volkswagentype3/search/?query=column&hc_location=ufi
I had to rewire most of mine. You'll get really good with a soldering iron by the time you're done.
https://www.thesamba.com/vw/forum/viewtopic.php?t=696960&highlight=
I WAS THERE! The 2017 Type 3 Rally / September 29–October 1 / Cayucos, CA
2014: The 2014 Type 3 Rally / October 3–5 / Cayucos, CA
2011: 50 Years of the VW Type 3 / September 29–October 1 / California Central Coast
Bobnotch
Bobnotch is offline
PostPosted: Mon Jan 13, 2020 1:37 pm    Post subject: Re: Column Rebuild Reply with quote
Yup, not a fun job. I had to replace the ignition switch in my T-34, and like Scott said, got very good with a soldering iron. Take detailed pics as you go to help your memory.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Username1
Username1 is offline
PostPosted: Tue Jan 14, 2020 11:33 am    Post subject: Re: Column Rebuild Reply with quote
I just completed this process last weekend - replaced all wiring in the column. If you dont use the correct gauge wiring on the ignition switch portion it will not fit back through the column very easy/at all - not a lot of room in there.
Ive replaced the wiring directly on the ignition switch with zero issues to the bakelite backing. Just desolder one at a time waiting a minute before moving on to the next. Same goes for installation - dont solder them all at once to keep things from overheating.
I did find it much easier to solder the wiring to the switch and then install the switch- not much room to get the wires in those tiny solder posts once the switch is back in the column.
ALLWAGONS
ALLWAGONS is offline
PostPosted: Wed Jan 15, 2020 9:24 am    Post subject: Re: Column Rebuild Reply with quote
[quote="t3kg"]If you're a member of the VW Type 3 group on Facebook you can check out Lionel Mendoza's step-by-step column rebuild tutorial: https://www.facebook.com/groups/volkswagentype3/search/?query=column&hc_location=ufi
What type 3 group? I thought we were all type 3 brothers here?
NON INFLUENCER APPROVED
t3kg
t3kg is offline
PostPosted: Wed Jan 15, 2020 9:40 am    Post subject: Re: Column Rebuild Reply with quote
On Facebook there are a lot of special interest groups people have created to connect over particular topics of interest. Some of them are private groups and you have to request permission to join to be able to see what people post there. VW Type 3 is one of those, and that's where Lionel happened to post his tutorial. So, you have to both be on Facebook and be a member of "VW Type 3" to be able to see it.
There are lot of other Type 3-related FB groups too:
Type 3 Underground
VW Type 3 Notchback 1961-73
Volkswagen Type 3 Swapmeet
VW Type 3 Toys and Memorabilia
T34 World
The Type 34 Registry
VW Razor's Edge (Type 34)
VW Type 3 Abarth Drivers
Type 3 Preservation Society New Mexico Chapter
etc.
etc.
You can join in too, as long as you don't mind handing over all your personal data to Mark Z.
t3kg
t3kg is offline
PostPosted: Wed Jan 15, 2020 9:51 am    Post subject: Re: Column Rebuild Reply with quote
This is exactly the way I did mine.
Clatter
Clatter is offline
PostPosted: Wed Jan 15, 2020 2:03 pm    Post subject: Re: Column Rebuild Reply with quote
Wow, great information there, gentlemen!
Much appreciated..
I guess I'll continue along with the detailed words/pics 'how to'..
Facebook is going to go away like Friendster or Myspace did.
Yeah,
Some forums have gone away, Like superbeetlesonly.com,
And Germanlook.net is on life support.
The STF sometimes seems a bit quiet as well..
But the Samba shall endure forever!
Long after Facebook is gone and forgotten about..
So, here is verification of what we have;
Tracing out the wires to see where exactly they go.
With a PO having been in there before, anything is possible.
Printed full-color copy of the wiring diagram, in conjunction with a meter, verifies where these wires end up on the other end once they disappear into the column.
Magnifying glass helps me see the tiny terminal numbers, and wiring stripe colors.
So far, it looks like my wiring colors and terminal numbers are all correct.
My column wiring may just be un-molested from factory new.
Does anyone else have these tiny wraps of electrical tape(?) around some of the wires above the junction block?
Wondering if the factory put these in for additional insulation/chafe prevention,
Or if a PO might have been at work here..
'ataraxia' NOS column doesn't seem to have these.
Lastly,
I'm surprised to see a shiny gloss finish on the column rebuilt by 't3kg' here.
An 'ataraxia' column, looking to be NOS, shows a semi-gloss black sheen, far as I can tell.
Maybe the Ghia has a shiny column?
Mine -seems- to be semi-gloss, even flat,
But,
It's all so faded/tattered,
it coulda been gloss back in the day, and one would never know.. Confused
Bus Motor Build
Clatter
Clatter is offline
PostPosted: Wed Jan 15, 2020 2:27 pm    Post subject: Re: Column Rebuild Reply with quote
About the high/low button on the turn signal stalk..
There are supposed to be screws in the holes holding it on?
Mine was just kind of floating in place, with the wiring holding it in,
As well as this little cone-shaped tan plug thingie in there..
Just one spring inside?
The end of the button has a notch on mine.
Is that supposed to be a ring, and it got broken?
Oddly enough, it did used to work.
Maybe that's how it's supposed to be?
Bus Motor Build
PostPosted: Wed Jan 15, 2020 4:35 pm    Post subject: Re: Column Rebuild Reply with quote
Here are some photos of my NOS Type 3 steering column.
It's sort of a medium gloss black
There is only one screw holding the high/low dipswitch in place but it has a riveted-on tab on the other side that I believe the switch slips under?
I didn't unscrew it to see exactly how it works and it may vary by year.
Username1
PostPosted: Wed Jan 15, 2020 7:44 pm    Post subject: Re: Column Rebuild Reply with quote
Mine also has the single screw holding the hi/lo switch in
t3kg
t3kg is offline
PostPosted: Thu Jan 16, 2020 7:05 am    Post subject: Re: Column Rebuild Reply with quote
Single screw on mine too, same as in the photo Everett posted. But before I rebuilt it there was no screw and it still worked. The paint on mine is glossy because I painted it! It was as rough or rougher than yours when I started. I used the "gray-black" paint from Wolfsburg West which is a close match to the not-quite-black color of the early columns.
That electrical tape on yours is evidence of previous work. The solder on those connections looks like later work to me too — the factory soldering is cleaner. I'd say it's had work done on it before.
BTW, not advocating for use of Facebook at all, it just that Lionel's tutorial there is really helpful!
t3kg
t3kg is offline
PostPosted: Thu Jan 16, 2020 7:30 am    Post subject: Re: Column Rebuild Reply with quote
Here's mine before I started:
I unsoldered terminal 50 on the terminal block and pressed the ignition switch out with the wires attached. After everything was cleaned up and refurbished I soldered in replacement wires on the switch before reinstalling it into the column. If the bakelite cap on your switch is fairly solid I would try to avoid unsoldering the wires with the switch still in the column. Just go slow and steady and carefully pull the wires out of the column without stressing the soldered terminals as you press out the switch.
I ended up installing an NOS dimmer switch. You can still find them out there. It's nice because the kits come with all the hardware you might be missing — screw, spring, etc. Getting those tiny wires rerouted through the housing is no fun though, so if you do it be sure to run a guide wire to pull them through.
Clatter
Clatter is offline
PostPosted: Thu Jan 16, 2020 11:51 am    Post subject: Re: Column Rebuild Reply with quote
Thanks again for all of your fine wisdom, Scott.
If you got the WW paint for this,
Then that might be what it looked like new,
And these NOS columns have faded to a flat sheen on the shelf after 50 years? Think
And..
You were right!
Look at that PO hack slicing..
At least they soldered it.
Followed y'alls advice;
Veeerrryy carefully de-soldered each ignition square one at a time, cooling between.
Soon as solder melted, wire was pried free.
Once the key went in, ignition switch came free intact. Cool
So that leads to another question...
I have an ultrasonic cleaner (that i have yet to actually use Embarassed ).
Think i should throw the entire cylinder in the soup all in one shot,
Or do i dare disassemble?
Bus Motor Build
Clatter
Clatter is offline
PostPosted: Thu Jan 16, 2020 12:52 pm    Post subject: Re: Column Rebuild Reply with quote
Here's Monte's ignition switch rebuild adventure.
Makes me want to just leave this thing together!
Maybe get a big clear plastic freezer bag and pop it apart inside so as to catch everything.. Embarassed
MonT3 wrote:
I decided to attempt putting my ignition back together. Started out by looking at the outer cover which had the wiring. I take when these units are installed into the column, the wires are fed through which I get. if they have to be replaced, I think it would be hard to get it out complete, as the wires are ran through a small spot and would have some trouble backing them out as a whole or one by one. Either way, my attempt to remove the whole thing failed and here I am looking at four springs, the outer plate and inner plate/cover and a paper shield which all have the be placed back in.
Interstingly, after recovering the springs and the inner cover which came out, no other pieces came from the ignitions back end. What you see there is how it came out. I studied Mr Wolfes reference, (thanks ataraxia) http://classicvw.org/gallery2/v/ign_switch/ whish is great help but it aslo opened alot of questions I haven't found answers to yet. I never had the opportunity to meet, chat or ask questions of Mr. Wolfe but he continues to teach. Thank you Sir.
I started by removing the wires which were soldered into the square posts. Placed the iron directly on the tops of the square, waited a little and tugged on the wire until it freed itself. After all the wires were removed, I went back to each square and applied the iron to the top until I could see the solder soften, pulled the iron back and blew out the solder from the square post. Cleaned up the end cap and contacts on the reverse side, borrowed my wife's tweezers and sat down to research as much as I could on the rebuilding of an ignition. There's not much out there. Sad
Looking at the springs, one of them is longer than the others, I noticed the plate that was in the ignition was sitting (possibly) opposite of where it should be. I only say this because the bearing which looks to make contact with certain points below would need a little pressure to keep it in place otherwise it would move, get stuck with the grease coating and not go back in place. a spring would assist the plate that was in there looks to be backwards.
The bearing is in the lower left side of the inner portion of the tube. The brown plate looks to be spun around and not in the right spot
Spinning the plate around would offer a place for the spring to remain in place.
The paper cover has some indents where the two other springs probably sat. They coincide with the holes in the plate above
The cover plate and the paper shield cover the springs and is in place but where does that straggler spring go??!!! Evil or Very Mad
The small square-like nub slips into the slot cut-out in the tube BUT that's that only one. There isn't one on the other side.
The cover shows not sign of a missing piece Maybe it's not the correct piece for this tube. Maybe this ignition was rebuilt by someone and an added spring was tossed in? IDK... Sad
Adding some pressure on the top with the tweezers as if should look this way. Unfortunately, it doesn't. I don't think the outer plastic cap would have anything to do with holding this in place. Any thoughts?
So close to finishing up but again, I'm not 100% sure I have this thing assembled correctly as I have no real reference on this. Should anyone have something like and exploded diagram, I would certainly appreciate having a look at it as I don't know if this would work. As mentioned earlier, the grey wires was not used and was tucked inside the tube. Mr. Wolfe's ignition he used didn't have a post for the grey wire on the end cap. Has anyone noticed the differences in the end caps?
Bus Motor Build
Erik G
Erik G is offline
PostPosted: Thu Jan 16, 2020 1:14 pm    Post subject: Re: Column Rebuild Reply with quote
fuck, those pics give me flashbacks. I dove head first into the ignition on my daily driver notch like 16 17ish years ago with no idea what I was doing and I should not have done it. somehow I did manage to get it back together and working Shocked just in time to get to work
Bobnotch
Bobnotch is offline
PostPosted: Thu Jan 16, 2020 5:43 pm    Post subject: Re: Column Rebuild Reply with quote
And another reason why I went with the 68 and later style ignition and column head assembly. At least on those the electrical portion of the ignition switch is self contained. Very Happy
Tram wrote:
Tram wrote:
Page: 1, 2, 3  Next
