Nifartachi Samba Member
Joined: October 19, 2008 Posts: 222 Location: Wallachia
Posted: Thu Jan 16, 2020 4:18 am Post subject: Aircraft engine |
Guys, any idea about this one?
I mean, really, ANY idea would be useful.
Thanks.
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Thu Jan 16, 2020 4:38 pm Post subject: Re: Aircraft engine |
Wow I guess not.
I was hopeful too.
I’m not familiar enough with Type 2 engines to know if the weird fuel pump or whatever pump or Oiler thingy position is original or a mod. _________________ Volkswagen!
(Compression 8.7:1) |
rstrobel Samba Member
Joined: April 05, 2018 Posts: 217 Location: Indianapolis, Indiana
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Thu Jan 16, 2020 5:59 pm Post subject: Re: Aircraft engine |
I don't know much about VW engines converted for aircraft use but that's not based on a Type 3 engine. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Thu Jan 16, 2020 10:48 pm Post subject: Re: Aircraft engine |
I'm Gonna say it's modified to mount the fuel pump there, since it doesn't run a distributor or gear the crank gear is replaced with a fuel pump cam ring to actuate the pump straight off the crank. _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Fri Jan 17, 2020 1:24 am Post subject: Re: Aircraft engine |
Okay, since my brother in law owns a light aviation repair facility, I know just enough to be dangerous. If you plan on sticking that engine (as long as it runs good), in a VW for just cruising around, you'll be fine. Just remember it WILL NOT be a power house. Light aviation engines, are designed to be ran at a steady mid range drone.
Now since the prop provides massive crank thrust compared to an automotive engine. There will be additional crank thrust bearing/ retainers, that will probably need to be removed. Depending on the manufacture, they can be on either end of the engine. Those are also motorcycle carbs. They are used for ease of tuning and also that they are less vulnerable to float bounce in turbulence (richness/hesitation).
Because of liability issues, I do not believe, that there is a sale value. If it was mine, I'd put an upright cooler on it, Remove the aircraft parts, and use it for a daily driver. Then sell the parts. There is a difference in liability between parts and a complete engine. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Posted: Fri Jan 17, 2020 2:41 am Post subject: Re: Aircraft engine |
Thank you all.
I would put that in my '57 bus, not hoping for any improvements, but just to brag about having an airplane engine on my bus. |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Fri Jan 17, 2020 12:52 pm Post subject: Re: Aircraft engine |
Chances are VERY GIID that the front of the case (the pulley end) was machined for the prop hub. This is a common mod on VW aircraft engines. Once done you can no longer use a standard pulley or it'll puke oil everywhere. The cost of un-doing this machine work is not worth the price compared to buying a new case.
Check carefully for this and other aircraft specific mods before investing money. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
Brian Samba Moderator
Posted: Fri Jan 17, 2020 2:10 pm Post subject: Re: Aircraft engine |
Lo Cash John wrote: |
Larger ID than a 'machine in' sand seal? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
stanthedog Samba Member
Joined: October 11, 2006 Posts: 357 Location: Portland,oregon.
Posted: Fri Jan 17, 2020 2:18 pm Post subject: Re: Aircraft engine |
know little to nothing about vw aircraft engines. but, I thought you mounted the prop on the bell housing end. not the pulley end. because theres nothing really supporting that end of the crank. |
Posted: Fri Jan 17, 2020 3:11 pm Post subject: Re: Aircraft engine |
stanthedog wrote: |
The prop is mounted on the side where the crank pulley was _________________ 1967 VW Beetle
1993 VW Cabriolet
My 67 build thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=716767
•(__)•
(O\!/O) <--- supposed to look like a beetle |
oprn Samba Member
Joined: November 13, 2016 Posts: 12743 Location: Western Canada
Posted: Sat Jan 18, 2020 5:38 am Post subject: Re: Aircraft engine |
I would not be too concerned about any liability issues selling that engine for aircraft use. They are used in the experimental aircraft category where the rules are looser and the builder/pilot takes full responsibility for what he hobbles together, maintains and flies.
I also see no reason that this engine would not be a decent one for use in a car other than the pulley end mod, if it even has one that is, and any good machinist should be able to fix up a pulley to fit it without touching the case/crankshaft.
Displacement is king in aircraft engines and it could well have very useful stroker crank and big bore P/C set. Expect a stock cam though as high rpm is not desirable in aircraft use.
This engine should make a sweet Bus powerplant or for someone that is not a screaming demon jock. |
Moz'z58 Samba Member
Joined: August 09, 2008 Posts: 45 Location: Near Lake Tahoe in California USA
Posted: Sat Jan 25, 2020 12:50 am Post subject: Re: Aircraft engine |
FWIW if anyone is interested - this may be a industrial with the 36hp side fuel pump on a 40 hp indstr'l case ? with boss flange in the casting.
If you really want good infos contact Great Planes (or kitplanes forum maybe) who I think was involved with the Sonerai and Sonex guy from years back to now - excellent planes and VW hot-rodders of the sky.
The accessory case on flywheel end will likely be enough to get you an accurate read from them...it may be his development.
Also the Volksplane and Ackerman's VW conversion is a possible. I have the plans for the V-plane and Ackerman was the engine machinist in that development. Another cool VW based plane is Guiseppe Vidor's ASSO Champion V, but that ran a T4 base engine as I understand.
I believe the prop hub was a interference fit heated on, not tapered, which at low rpm and light prop weight was deemed a fine way to go, but I'm guessing. Many, me included, don't like pulling the a/c off a engine case casting and small nose bearing not designed for it, and instead hassle with using the flywheel end which is also not ideal, but doable.
Anyway for VW enthusiasts wanting more arcane subject the VW aircraft is pretty neat realm to check out - The Sonerai mentioned has a long history. And in Europe back in the 50's onwards other designs like Jodel flown as ski planes for skiers in the alps etc etc. Fourneir another classic. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sat Jan 25, 2020 3:29 am Post subject: Re: Aircraft engine |
There was some discussion about one of these in the "Vintage" forum...
https://www.thesamba.com/vw/forum/viewtopic.php?t=332239
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Sat Jan 25, 2020 12:52 pm Post subject: Re: Aircraft engine |
If you zoom in to the fuel pump mounting/ case you can see welding ..i believe some one converted it some may say why ??? It looks like they wanted more air for the oil cooler that's flat if the fuel pump was in its original location it would block the air so they relocated it that's the only reason I see why they did it like that ..... |
