DcWHaT Samba Member
Joined: July 17, 2008 Posts: 116 Location: Richmond California
Posted: Thu Jan 16, 2020 9:10 pm Post subject: 1964 vw bug distributor |
hey everyone i know this topic has been beatin to a pulp, I have a 30/31 empi carb and was curious to run a bosch 009 dis..... with vacuum or no vacuum??? thank you all |
DcWHaT Samba Member
Posted: Thu Jan 16, 2020 9:16 pm Post subject: Re: 1964 vw bug distriibutor |
sorry my "I" button is messed up and i know Distributor is spelt incorrectly. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6598 Location: Houston, Texas
A 009 will work for you but you may be better off with a stock carb. You might consider a cast iron large cap Bosch 40HP.
What size engine do you have?
Is it a single or dual port? _________________ www.vwnos.com [email protected]
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Fri Jan 17, 2020 12:14 am Post subject: Re: 1964 vw bug distriibutor |
What is most commonly referenced as an "009" distributor is a mechanical-only advance unit, so there is no option for vacuum or no vacuum. The 30/31 carburetor has shown itself to work fairly well with the 009, though for best drivability and economy you'd be better off with an SVA (single vacuum advance) distributor or an SVDA (single vacuum, dual advance) distributor if you connect the latter to a compatible vacuum source. _________________ 1960 Ragtop w/Semaphores "Inga" |
glutamodo The Android
Joined: July 13, 2004 Posts: 26315 Location: Douglas, WY
Posted: Fri Jan 17, 2020 12:42 am Post subject: Re: 1964 vw bug distriibutor |
If you're talking about a single port 1200 engine, the mechanical 009 will run fine.
The H30/31PICT is a can of worms as to what distributor to use. Now you say you have an EMPI copy of the Brosol, and I've never tinkered with any of them. I suspect it's just a copy though, if it is, I think I'd go with a 205M or 205T from 68-70 with TDC static timing, 2nd choice, a 205K (which is a totally different distributor whose Bosch number ends in 009) from 66-67 with 7.5BTDC static timing. That's when you're tapping the normal vacuum advance fitting on the side of the carb. There's another fitting that's a bit awkward to get to, that can be used for an SVDA style distributor. I talk about all of this in this thread, but the SVDA info I think is on page 8 of the comments:
https://www.thesamba.com/vw/forum/viewtopic.php?t=185095 _________________ Andy T.
wcfvw69 Samba Purist
Posted: Fri Jan 17, 2020 6:37 am Post subject: Re: 1964 vw bug distriibutor |
I agree with Andy. I'd match a 113905205T to your engine vs. the 205K. Why? The 205T runs the more common tall distributor cap and rotor that was used through 1979. They are a few dollars cheaper to purchase.
I have those distributors restored if you need one. _________________ Contact me at [email protected]
The Samba member since 2004.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76912 Location: Sneaking up behind you
Posted: Fri Jan 17, 2020 6:38 am Post subject: Re: 1964 vw bug distriibutor |
205T, and I don't have any for sale. _________________ Glenn
Member #1009
#BlueSquare |
DcWHaT Samba Member
Posted: Fri Jan 17, 2020 7:36 am Post subject: Re: 1964 vw bug distriibutor |
heimlich wrote: |
Is it a single or dual port? |
I have a 1200cc engine single port. You talking about a 28 pict1? I have a nasty flat spot when I first hit my throttle |
heimlich VWNOS.com
Posted: Fri Jan 17, 2020 8:56 am Post subject: Re: 1964 vw bug distriibutor |
DcWHaT wrote: |
heimlich wrote: |
It sounds like you've got a stock engine which is nice. You probably wouldn't have to change much to get it back to full stock which would include the large cap cast iron I mentioned above.
What model 009 is currently on the car? _________________ www.vwnos.com [email protected]
Mr. Mike Samba Member
Joined: January 30, 2015 Posts: 513 Location: Shoreline, WA
Posted: Fri Jan 17, 2020 10:07 am Post subject: Re: 1964 vw bug distriibutor |
If you've a stock set up, The Old Volks Home (archived) has correct information on VW distributors, and tune up parts, throughout the years. _________________ 1964 Sedan 6 volt |
Glenn Mr. 010
Posted: Fri Jan 17, 2020 10:15 am Post subject: Re: 1964 vw bug distriibutor |
heimlich wrote: |
What model 009 is currently on the car? |
Should be a 0231 137 009 _________________ Glenn
Member #1009
#BlueSquare |
heimlich VWNOS.com
Posted: Fri Jan 17, 2020 10:26 am Post subject: Re: 1964 vw bug distriibutor |
Glenn wrote: |
heimlich wrote: |
Should be a 0231 137 009 |
He's most likely referring to the non-vacuum version as most folks do when they say 009. When I think of 009 I think of 0 231 178 009.
When Bosch says 009 they may be talking about these (among others):
0 231 137 009
0 231 172 009
0 231 173 009
0 231 174 009
0 237 022 009 _________________ www.vwnos.com [email protected]
DcWHaT Samba Member
Posted: Fri Jan 17, 2020 3:56 pm Post subject: Re: 1964 vw bug distriibutor |
Mr. Mike wrote: |
If you've a stock set up, The Old Volks Home (archived) has correct information on VW distributors, and tune up parts, throughout the years. |
the only thing that is not stock is that its a 12 volt setup. |
DcWHaT Samba Member
Posted: Fri Jan 17, 2020 3:57 pm Post subject: Re: 1964 vw bug distriibutor |
heimlich wrote: |
DcWHaT wrote: |
heimlich wrote: |
its a bosch 009 non vacuum. |
heimlich VWNOS.com
Posted: Fri Jan 17, 2020 4:15 pm Post subject: Re: 1964 vw bug distriibutor |
DcWHaT wrote: |
If it were me I'd stick with it until you could change out to an original carb. Then you could switch to the fat cap cast iron distributor.
If you have an extra $125 you could try one of the distributors mentioned earlier. Just be careful where you get them. Lately I've seen some rebuilds being sent out with repairs on the clips. They stick a pin in it and call it "professional". I personally don't ever do that so watch out if you decide to go that way. If someone sends something like that to you send it back and ask them to pay shipping for sending you junk not advertised. _________________ www.vwnos.com [email protected]
Posted: Fri Jan 17, 2020 4:16 pm Post subject: Re: 1964 vw bug distriibutor |
DcWHaT wrote: |
Mr. Mike wrote: |
They wont mind 12v, the voltage doesn't matter for your application. _________________ 1964 Sedan 6 volt |
Glenn Mr. 010
Posted: Fri Jan 17, 2020 6:41 pm Post subject: Re: 1964 vw bug distriibutor |
heimlich wrote: |
. Lately I've seen some rebuilds being sent out with repairs on the clips. They stick a pin in it and call it "professional". I personally don't ever do that so watch out if you decide to go that way. If someone sends something like that to you send it back and ask them to pay shipping for sending you junk not advertised. |
So someone sends you their sva and the cap clip retaining ear is broken.
How do you fix it? Please post pictures _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Jan 17, 2020 6:50 pm Post subject: Re: 1964 vw bug distributor |
I'm kind of divided on correcting what I consider to be a design flaw of the mid and late 60s vacuum-only distributors. I've posted images of fixes I've done, (I've NEVER personally ever sold a distributor, so these were all for my own use) and the one where I basically shoved some steel wire through there and bent it over is definitely not professional. However they can be done rather nicely, and personally, I'd rather not have the clips fall off. _________________ Andy T.
heimlich VWNOS.com
Posted: Sat Jan 18, 2020 8:12 am Post subject: Re: 1964 vw bug distriibutor |
Glenn wrote: |
heimlich wrote: |
How do you fix it? Please post pictures |
That's a different request. Fixing something for someone is one thing. Sending out a rebuilt unit with a questionable fix is something else.
I do have a nice way to fix them but I haven't engineered all the pieces. Maybe one day when I run out of good cores. _________________ www.vwnos.com [email protected]
heimlich VWNOS.com
Posted: Sat Jan 18, 2020 8:15 am Post subject: Re: 1964 vw bug distributor |
glutamodo wrote: |
I'm kind of divided on correcting what I consider to be a design flaw of the mid and late 60s vacuum-only distributors. I've posted images of fixes I've done, (I've NEVER personally ever sold a distributor, so these were all for my own use) and the one where I basically shoved some steel wire through there and bent it over is definitely not professional. However they can be done rather nicely, and personally, I'd rather not have the clips fall off. |
That first one looks nice. I think it's best to keep it as close to factory looking as possible. _________________ www.vwnos.com [email protected]
