unidenscan Samba Member
Joined: September 25, 2017 Posts: 14 Location: Rhode Island
Posted: Fri Jan 17, 2020 8:07 am Post subject: 1979 FI SB under seat wiring |
Is anyone able to take a pic of the wiring under the rear seat for a late FI super beetle. Everything in mine was cut out, I'm trying to get it back together correctly.
I need to see what is attached to the battery, and the various wiring connections on the drivers side.
Thanks! |
Starbucket Samba Member
Posted: Fri Jan 17, 2020 4:10 pm Post subject: Re: 1979 FI SB under seat wiring |
Go to technical (top of page) and look at your wiring diagram and match the wires. |
zoti Samba Member
Joined: December 26, 2007 Posts: 2061 Location: Plano, TX USA
Posted: Sun Jan 19, 2020 12:03 pm Post subject: Re: 1979 FI SB under seat wiring |
I can probably get you a picture a bit later.
Are you talking battery side or driver side? |
BugCaster Samba Member
Joined: January 19, 2015 Posts: 77 Location: North Carolina Piedmont
Posted: Mon Jan 20, 2020 8:32 am Post subject: Re: 1979 FI SB under seat wiring |
Not the best photos but see if this helps
Posted: Tue Apr 14, 2020 11:58 am Post subject: Re: 1979 FI SB under seat wiring |
This is helpful, thanks. Any pics of how the power wires are hooked up to the battery/ignition for the F/I ECU? I have found a brown wire and a red wire from the ECU which I think go to + and - on the battery??
Any other pics of the under seat area of a late fuel injected beetle will be helpful. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Tue Apr 14, 2020 1:53 pm Post subject: Re: 1979 FI SB under seat wiring |
There is nothing from the ECU that goes direct to the battery. Use the wiring diagram please so you don't fry your ECU. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
finefettle Samba Member
Joined: October 13, 2006 Posts: 699 Location: Shelburne,Vermont
Posted: Wed Apr 15, 2020 8:08 pm Post subject: Re: 1979 FI SB under seat wiring |
Brown is usually ground _________________ 1979 Bug project |
