1981 (@wileythewesty) TDI conversion, from ground up
Page: Previous  1, 2, 3, 4
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu Dec 10, 2020 3:23 pm    Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up Reply with quote
Thanks. Bear in mind though that given my foray today into auto tranny Sinka's, any rep I had is now tarnished. So, take my measurements for what they're worth. LOL. Wink Actually, I took care line up the clutch housing faces for those pics so measurements are fairly accurate.
If you ever go to a WBX tranny, but keep engine at air cooled position, some pics of how I adapted the WBX tranny to air cooled engine position. Flipped mount idea was courtesy of ?Waldo?. Rereading my notes, I would've done things differently and better but this was first time at this with beginner level fabricating skills so.....
https://goo.gl/photos/GXTagUdjdekict8R7
Even with removed material, mount is still fine afaik. e.g. no cracking.
Neil.
1981 Westy air cooled to 15º ABA swap: http://tinyurl.com/y9n4xob8
50º ABA Swap in to '88 Westy: http://tinyurl.com/yap5hpwt
Vanagon VAG GAS engine swap Google Group:
https://tinyurl.com/2f24rmh
VE7TBN
crazyvwvanman
crazyvwvanman is offline
PostPosted: Thu Dec 10, 2020 5:01 pm    Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up Reply with quote
I think it would be a much better idea to move the engine/aircooled tranny rearward to the wbx position now. Less work overall for the long term.
Mark
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Thu Dec 10, 2020 5:13 pm    Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up Reply with quote
It will give easier access to the clutch slave and starter. This is especially true if you delete the firewall.
Casey--
Volkswagens powered by Volkswagen
'01 Weekender VR6 -->2.5 TDI?
Oly Bulli
'87 300TD OM606 7mm Myna pump and HX30
charleslabri
charleslabri is offline
PostPosted: Thu Dec 10, 2020 7:50 pm    Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up Reply with quote
I cut the firewall out a few weeks ago
An example of my slave labor in action:
https://www.instagram.com/wileythewesty/
Zeitgeist 13
PostPosted: Thu Dec 10, 2020 10:06 pm    Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up Reply with quote
When Mark tells you some tips to make your project move forward, it carries a whole lot more weight than my meager suggestions. He's probably forgotten more than I'll ever know about these vans. I strongly suggest you follow his recommendations.
Casey--
Oly Bulli
charleslabri
PostPosted: Fri Dec 11, 2020 5:57 am    Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up Reply with quote
Referring to marks comment about the CVs?
Currently if I extend Greg’s brackets (which do not work for aircooled tranny position) I keep everything bone stock.
If I modify the trans location to be more like a wbx and fit Greg’s mounts, I end up changing 1) trans mount 2) shift linkage 3) CV angle 4) clutch slave position.
Seems a no brainier to keep stock locations and modify Greg’s mounts.
After being pretty active on the forum here for about a year, I agree... mark is def weighted in his knowledge of vans. A legend
Zeitgeist 13
PostPosted: Fri Dec 11, 2020 9:26 am    Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up Reply with quote
One other thought is that the 091 trans was only available here for around 2.5 years, so they're kinda rare. They're also a bit weaker than the 091/1. Your new engine produces monster level torque, so if you grenade your current trans in the future, it might be difficult to locate a similar unit as opposed to the stronger and more readily available 091/1. If you move the trans mount now, you'll be able to swap in any trans, including a five speed 094. Options.
Btw: regarding the CV angle, with the drivetrain shifted rearward my axles are now a straight run to the hubs, rather than angled forward as they were in the aircooled donor van.
Casey--
Oly Bulli
charleslabri
PostPosted: Fri Dec 11, 2020 10:27 am    Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up Reply with quote
Ive thought about this.. i did some serious beefing already to the 091 trans.
My plan is that if the trans grenades, likely ill just turn my ride into a syncro.
?Waldo?
?Waldo? is offline
PostPosted: Fri Dec 11, 2020 12:09 pm    Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up Reply with quote
In that case you will need to move the engine rearward to the later position.
HIGHEST QUALITY M-TDI PUMPS FOR SALE. PM for details.
pjn_wyo
pjn_wyo is offline
PostPosted: Fri Dec 11, 2020 12:58 pm    Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up Reply with quote
Want to buy some parts?
charleslabri
PostPosted: Fri Dec 11, 2020 2:12 pm    Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up Reply with quote
ez
charleslabri
PostPosted: Fri Dec 11, 2020 2:13 pm    Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up Reply with quote
if i had anywhere reasonable to store syncro parts, id say yes. But r/n i dont ;(
Page 4 of 4
