zpobaby Samba Member
Joined: May 06, 2004 Posts: 13 Location: Riverview Florida
Posted: Sat May 22, 2004 9:18 am Post subject: 1979 vert with 16in fuch wheels? |
What all needs to be done to put these on my vert fronts are 16 with 205/40zr toyo tires rears are 225's.
thanks Johnny |
Thornton EMPI Guru
Joined: August 27, 2001 Posts: 2107 Location: Portland to AZ back to Portland
Posted: Thu May 27, 2004 4:45 pm Post subject: |
well i had 16's on my 67 and i have 4 inch narrowed beam, porsche drilled drums all around no adapters, fit fine in the back. but a buddy of mine did the same setup and he needed short axles in the back, since you have a superbeetle looks like your going to be screwed either way
here is my car with 16's
here is my buddies 58 with the same wheels
_________________ Thornton |
Posted: Thu May 27, 2004 7:09 pm Post subject: |
what u mean I am screwed eitherway |
Thornton EMPI Guru
Posted: Fri May 28, 2004 7:29 am Post subject: |
i was meaning because your car is a super, so you cant narrow the beam, and its IRS so you cant put short axles in it, thats what i ment
but hey, guys are putting 17's on supers so i wouldnt see why 16's would fit, just wouldnt be able to slam it to the ground _________________ Thornton |
Posted: Fri May 28, 2004 2:39 pm Post subject: |
empivw wrote: |
but hey, guys are putting 17's on supers so i wouldnt see why 16's would fit, just wouldnt be able to slam it to the ground |
Allright thanks
I guess I'll ask around look at some other setups supers r using |
speed holes Samba Member
Joined: March 04, 2004 Posts: 403 Location: Fat City, USA
Posted: Fri Jun 18, 2004 10:56 pm Post subject: |
http://www.germanlook.com
look here. |
Bugorsh Samba Member
Posted: Sun Jun 20, 2004 2:02 am Post subject: |
I have a 72 Super with 15x6 fuchs in front w/195/60/15 Goodyear Eagle F1 GSD3's disc brakes and am using 5/16 offset plates, in the rear i have 16x7 fuchs w/205/55/16 Goodyear Eagle F1 GSD3's no offset plates and I just trimmed off the end of the axles past the nut to fit the centercaps. Tread is all under the fenders with just a little sidewall going past the edge. Front is lowered about 1.5-2" and it has a nice agressive stance. Topline Parts sells some MaXX Struts that allow the use of wider wheels without using offset plates. _________________ In pursuit of superior handling!
SuperBeetlesOnly.com
VeeDub Parts Unlimited
Topline Parts |
Posted: Sun Jun 20, 2004 4:35 pm Post subject: |
Bugorsh wrote: |
I have a 72 Super with 15x6 fuchs in front w/195/60/15 Goodyear Eagle F1 GSD3's disc brakes and am using 5/16 offset plates, in the rear i have 16x7 fuchs w/205/55/16 Goodyear Eagle F1 GSD3's no offset plates and I just trimmed off the end of the axles past the nut to fit the centercaps. Tread is all under the fenders with just a little sidewall going past the edge. Front is lowered about 1.5-2" and it has a nice agressive stance. Topline Parts sells some MaXX Struts that allow the use of wider wheels without using offset plates. |
do you have any pictures? |
