Lind Samba Member
Joined: November 06, 2000 Posts: 9913 Location: idaho
zimblewinder Samba Member
Joined: January 22, 2004 Posts: 893 Location: Australia
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Sat May 22, 2004 7:31 pm Post subject: |
All excellent links, Lind.
Jon's pix of that reduction box rebuild are first rate.
Better than 99% of books and manuals out there.
I hope he gives this photo treatment to other bus repairs. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sat May 22, 2004 8:18 pm Post subject: |
thanks!
i'm working to finish up that sequence of pics out to the drum, and some text as well, but the bus still isn't back from the body shop, so i have nothing to install it into.
i'm also working on pics of a few other things. any suggestions for future pictured repairs? _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Sat May 22, 2004 8:36 pm Post subject: |
hazetguy wrote: |
any suggestions for future pictured repairs? |
Front end. Link Pins, spring plates, steering box, etc. _________________ Founder and Chairman Emeritus, ECMSAS
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Sun May 23, 2004 3:01 pm Post subject: |
Thing with link pins is that unless you have access to a press they can be a bitch to do. Plus it takes a special tool to press them apart. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
Posted: Sun May 23, 2004 10:21 pm Post subject: |
DubStyle wrote: |
Thing with link pins is that unless you have access to a press they can be a bitch to do. Plus it takes a special tool to press them apart. |
That is one reason I appreciated Jon's redux. box pix. It let me know exactly what tools I would need to do the portion of the job I need to do.
For the front end, the same would apply. _________________ Founder and Chairman Emeritus, ECMSAS
Erwin vs Samba Member
Posted: Thu Jun 17, 2004 7:47 am Post subject: |
DubStyle wrote: |
This is my first post on the samba.I'm from holland and have a question.
do have anyone a picture of the tool for pressing out the link pins.
I dont know how to do it.
thanks |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2295 Location: Millwood, Wa
Posted: Thu Jul 22, 2004 10:12 pm Post subject: |
Bus link pin bushings don't need a press. You just need some round stock the same size and beat them out. _________________ ---
I have been on a treadmill drinking vodka, maybe more than once.
"No, I do not own a bleepin' leaf blower"
Buckly Samba Member
Joined: September 14, 2004 Posts: 1030 Location: Spokane, WA
Posted: Fri Oct 15, 2004 1:55 pm Post subject: |
Are you sure that it's o.k. to pound out the link pins? Like, it won't damage anything? And once they're out how do the go back in? _________________ Cool runnins,
_______________________
Bucky |
busboy Samba Member
Joined: March 23, 2003 Posts: 304 Location: Tacoma WA
Posted: Mon Oct 25, 2004 5:53 pm Post subject: |
any links on how to remove hinge pins of a door so i can get my damn mirrors on?? i cant seem to get them off. no bolt head no screw driver type ens nothin. just a pin with threads. buggin the crap outa me! |
Buckly Samba Member
Posted: Mon Oct 25, 2004 6:24 pm Post subject: |
I don't think My 67 has threads. I changed my mirrow a couple of years ago and I don't recal threads. But if there is threads: if at least a small amount of the pin is sticking out, try hacksawing a groove in one end so you can use a screwdriver or impack on it, reefing on it with Visegrips at the same time may help. If not maybe you can drive a small chisel in one end a use it to turn out the pin, or use the groove it forms (it's a long shot this will work). Even better, drill and easyout the pin. and if all else fails, just drill the damn thing out. use lots of penetrate what ever you do. Hopefully someone else will make it clear if there are threads in there or not. If not you just need to bang the pin out. _________________ Cool runnins,
Bucky |
ragtop man Samba Member
Posted: Tue Nov 09, 2004 6:24 pm Post subject: mirror arm removal |
hey, I just took both mine out of a real rusty truck. I took " pb blaster " a great pentrating spray and let it soak for about 5 minutes then started wiggiling them loose and then just worked them both out . the pb blaster works, you may have to tap on them to get them started. it didi take a lot of back and forth wiggiling but they will come out. hope this helps . |
Posted: Tue Nov 09, 2004 7:08 pm Post subject: axle removal???? |
hey guys, I have taken the trans with reduction boxes attached, out of my 63 doublcab. I have got the axle plate with the 6 nuts off. from here I dont see any way to get to the snap ring to release the axles so I can pull them out to sell the reduction boxes. any help would be appreciated, thanks!
vws forever,
D CAIN |
aah57 Samba Member
Joined: October 23, 2003 Posts: 433 Location: Roswell, Ga
Posted: Tue Jan 04, 2005 7:49 am Post subject: |
I accidently tried to restore my bus speedo before I read this post and I wiped the face with a wet cloth and it wiped off 60 and 70 mph. The link says Im screwed, does anyone know how I could fix this? What does the factory use to put these numbers on?
Any help would be greatly appreciated. _________________ Looking for white cabinets for a '61 camper
Need westy parts so-34 and so-22! |
Scotts 63 23 Samba Member
Joined: March 09, 2002 Posts: 1280 Location: Somewhere in my mind... The Real er Laguna Beach :)
Posted: Wed Feb 09, 2005 7:06 pm Post subject: |
Split Bus Steering Box Seal Replacement.
i just uploaded 10 pics to the gallery, step by step, of replacing the steering box shaft seal while the steering box is still in the vehicle. search "hazetguy" or "Bus Steering Box Seal Replacement" and you should be able to find them. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
jex_the_bug Samba Member
Posted: Sun Feb 27, 2005 3:14 am Post subject: |
this site has lots and seem that there realy goodhttp://www.type2.com |
vmachicote Samba Member
Posted: Fri Apr 01, 2005 12:18 pm Post subject: Anybody know the gear ratio in a stock '67 Westy tranny? |
Anybody know the gear ratio in a stock '67 Westy tranny? I want to remove the reduction boxes and go with a straight axle but I'm not sure if the stock tranny is worthy of good highway speeds.
Thanks for the help!!!!!! |
