Zeitgeist 13 Samba Member
Posted: Thu Jan 23, 2020 12:27 am Post subject: Re: Syncro 16 wheels |
$150 for a stamped steel wheel seems kinda absurd. Here's a perfectly decent alternative for less than half that price:
https://www.ebay.com/itm/65212-Factory-OEM-Recondi...Sww4FdeFOY _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
tjet Samba Member
Posted: Thu Jan 23, 2020 6:57 am Post subject: Re: Syncro 16 wheels |
ALIKA T3 wrote: |
The SA wheels are made for Mercedes, I posted pics elsewhere, it has the Mercedes part number on them. Oddly enough, the same part number comes up with a different offset elsewhere in the world (German supplied wheels) |
Yes. I was going to mention that fact about the South African wheels I bought from Van Cafe. I have 1 pair that's ET30 & 1 pair of ET27. The pairs were bought 2 years apart. The stamping are also different and in different location. Other than that, they look exactly the same. The gloss black powdercoating on the SA rims is high quality. It hasn't chipped or peeled at all. I put the ET27's on the rear.
I would say if you want a Syncro 16 looking rim, get the Mefro 16x6 from VC. According to Campervan, these rims are no longer being made. |
vwhammer Samba Member
Joined: May 20, 2006 Posts: 998 Location: Boulder CO.
Posted: Thu Jan 23, 2020 10:15 am Post subject: Re: Syncro 16 wheels |
Yep this is what I did.
I don't think mine came from the same place but I sent the seller a message to see if they had five of them and they even gave me a discount.
I would have to look at my records but I am pretty sure I got 5 refurb 16x7 mercedes steelies shipped to my door for about $250.
Mine came from a place called Santa Ana Wheel.
https://www.santaanawheel.com/
I think they were technically from a 2004 CLK320 if I recall but I am sure the same wheels were used on many different cars.
For the record I will be running a 320mm rotor with B5 Audi S4 calipers and those require a 7mm spacer to clear the wheel |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Thu Jan 23, 2020 10:23 am Post subject: Re: Syncro 16 wheels |
...and the Load Rating for them is what? _________________ This free advice is worth exactly what you paid for it.
Posted: Thu Jan 23, 2020 10:31 am Post subject: Re: Syncro 16 wheels |
More than enough. _________________ Casey--
y u rune klassik? |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Thu Jan 23, 2020 10:54 am Post subject: Re: Syncro 16 wheels |
I had 2 sets of Mercedes rims that I sold off before putting into use. The mefro rims are thicker gauge steel and I didn't want to waste time bending the mercedes rims off road.
FWIW with mercedes rims you need small ball seat hardware, VW hardware will not work correctly. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Thu Jan 23, 2020 11:08 am Post subject: Re: Syncro 16 wheels |
Or do what I did, go down to your local Mercedes dealer and buy new ones for $69 each, no shipping. I do wish they were silver, no black. No drilling, no machining. Need hardware though. Double check me, but M14 with 17mm radius, which is often called R12.
Also, double check, but I believe Audi TT lug bolts will work (can't remember W and/or W/O spacer) and Rien ones are $1.04 on RockAuto.
I wound up buying my hardware from Otis Inc., but only because T3 was not available at the time, else I would just go there for peace of mind and I everything else from there has been really good. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
tjet Samba Member
Posted: Thu Jan 23, 2020 1:03 pm Post subject: Re: Syncro 16 wheels |
Keep in mind that car wheels are thinner than the Mefros. If you don't plan on off-roading, you should be fine. If the MB rims are the same thickness as a Jetta rim, they will bend. I hit a pothole in New york in this pic. The good news is that it still held air.
Posted: Thu Jan 23, 2020 1:31 pm Post subject: Re: Syncro 16 wheels |
I guess if it was a real concern then you could get 8 or 10 budget car wheels for the price of a set of 4 Mefros.
In my two wheel drive I probably won't be doing to much crazy stuff off road anyway
With taller sidewalls and a proper all terrain tire I will take my chances off road with my car wheels and an spare on board. |
